Tutorial on how to implement inference (1D CNN) on Raspberry Pi5 + Hailos 8
I am trying to figure out how to implement inference of 1DCNN (Classification) on Raspberry Pi5 + Hailos 8 platform.
I have gone through the Model Zoo examples but it seems that these examples are related to video/ image inputs. However, in my case, I want to perform inference for 1D data type. Ideally, I would like to use the 1D-CNN model training using my computer and deploy it in the Pi5 platform. Furthermore, can Pytorch be used?
Hey @bijen.mali,
Yes, PyTorch can be used with Hailo. The process is as follows:
You need to convert your PyTorch file into a Hailo Executable Format (HEF) file using the Hailo Data Flow Compiler (DFC).
For more information on how to use the DFC, please check out the documentation on the Hailo Developer Zone website:
https://hailo.ai/developer-zone/documentation/
The DFC will be used on your PC to convert the PyTorch file into the HEF format.
After converting the file to HEF, you can then run it on the Raspberry Pi 5.
Best regards,
Thank you for the suggestion.
I have done the requirement
However, when I convert my ONNX file to HEF, I get the following error,
File ~/my_env/lib/python3.10/site-packages/hailo_sdk_common/hailo_nn/hn_layers/layer.py:454, in Layer._check_valid_shape(self, shape)
449 raise UnsupportedModelError(
450 f"Unexpected dimension in shape {shape} at {self.full_name_msg}. "
451 f"Dimension must be of type ‘int’ or ‘long’“,
452 )
453 if any(dim == 0 for dim in shape):
→ 454 raise UnsupportedModelError(f"Unexpected zero dimension in shape {shape} at {self.full_name_msg}”)
UnsupportedModelError: Unexpected zero dimension in shape [-1, 2, 0, 64] at base conv layer base_conv1 (translated from /conv/Conv)
I have compared the performance of the Pytorch and ONNX file and both are performing as expected.
This is the structure of my Model is that helps.
class Model(nn.Module):
    def __init__(self, input_channel, layers=[2, 2, 2, 2], num_classes=73):
        super(Model, self).__init__()
        self.inplanes3_1 = 64
        self.conv = nn.Conv1d(input_channel, 64, kernel_size=3, stride=1, padding=1, bias=False)
        self.bn = nn.BatchNorm1d(64)
        self.relu = nn.ReLU(inplace=True)
        self.maxpool = nn.MaxPool1d(kernel_size=2, stride=2, padding=0)
        self.layer3x3_11 = self._make_layer3(BasicBlock3x3, 64, layers[0], stride=2)
        self.layer3x3_12 = self._make_layer3(BasicBlock3x3, 128, layers[1], stride=2)
        self.layer3x3_21 = self._make_layer3(BasicBlock3x3, 64, layers[2], stride=2)
        self.layer3x3_22 = self._make_layer3(BasicBlock3x3, 128, layers[3], stride=2)
        self.avgpool = nn.AdaptiveAvgPool1d(1)
        self.fc = nn.Linear(128 * BasicBlock3x3.expansion, num_classes)
    def _make_layer3(self, block, planes, blocks, stride=2):
        downsample = None
        if stride != 1 or self.inplanes3_1 != planes * block.expansion:
            downsample = nn.Sequential(
                nn.Conv1d(self.inplanes3_1, planes * block.expansion,
                          kernel_size=1, stride=stride, bias=False),
                nn.BatchNorm1d(planes * block.expansion),
        layers = []
        layers.append(block(self.inplanes3_1, planes, stride, downsample))
        self.inplanes3_1 = planes * block.expansion
        for _ in range(1, blocks):
            layers.append(block(self.inplanes3_1, planes))
        return nn.Sequential(*layers)
    def forward(self, x):
        x = self.conv(x)
        x = self.bn(x)
        x = self.relu(x)
        x = self.maxpool(x)
        x = self.layer3x3_11(x)
        x = self.layer3x3_12(x)
        x = self.layer3x3_21(x)
        x = self.layer3x3_22(x)
        x = self.avgpool(x)
        x = x.flatten(start_dim=1)
        x = self.fc(x)
        return x
Hi @bijen.mali,
I’ve modified your code a bit, and not it’s ok. Please see below.
    def __init__(self, input_channel, layers=[2, 2, 2, 2], num_classes=64):
        self.fc = nn.Linear(64, num_classes)
        x = self.conv(x)
        x = self.bn(x)
        x = self.relu(x)
        x = self.maxpool(x)
        x = self.avgpool(x)
        x = self.fc(x)
        return x
I tried changed code but the problem persists.
This is the conversion code that I use.
chosen_hw_arch = 'hailo8'
onnx_model_name = 'TrainedModel6'
onnx_path = 'my_env/TrainedModel6.onnx'
onnx_path,
onnx_model_name,
start_node_names=['input'],
end_node_names=['output'],
net_input_shapes={'input': [1, 1, 200]}
However, I still get this error
[info] Translation started on ONNX model TrainedModel6
[info] Restored ONNX model TrainedModel6 (completion time: 00:00:00.01)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.01)
[info] Simplified ONNX model for a parsing retry attempt (completion time: 00:00:00.02)
UnsupportedModelError                     Traceback (most recent call last)
File ~/my_env/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py:220, in Parser.translate_onnx_model(self, model, net_name, start_node_names, end_node_names, net_input_shapes, augmented_path, disable_shape_inference, disable_rt_metadata_extraction, net_input_format, **kwargs)
    219 try:
--> 220     parsing_results = self._parse_onnx_model_to_hn(
    221         onnx_model=onnx_model,
    222         net_name=valid_net_name,
    223         start_node_names=start_node_names,
    224         end_node_names=end_node_names,
    225         net_input_shapes=net_input_shapes,
    226         disable_shape_inference=disable_shape_inference,
    227         net_input_format=net_input_format,
    228     )
    230 except Exception as e:
File ~/my_env/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py:300, in Parser._parse_onnx_model_to_hn(self, onnx_model, net_name, start_node_names, end_node_names, net_input_shapes, disable_shape_inference, net_input_format, **kwargs)
    298         self._logger.warning(f"ONNX shape inference failed: {e!s}")
--> 300 return self.parse_model_to_hn(
    301     onnx_model,
    302     None,
    303     net_name,
    304     start_node_names,
    305     end_node_names,
    306     nn_framework=NNFramework.ONNX,
    307     output_shapes=output_shapes,
    308     net_input_format=net_input_format,
    309     **kwargs,
    310 )
File ~/my_env/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py:351, in Parser.parse_model_to_hn(self, model, values, net_name, start_node_names, end_node_names, nn_framework, output_shapes, net_input_format, rename_layers_by_blocks)
    349     raise BackendRuntimeException(f"Unsupported NN framework {nn_framework}")
--> 351 fuser = HailoNNFuser(converter.convert_model(), net_name, converter.end_node_names)
    352 hailo_nn = fuser.convert_model()
File ~/my_env/lib/python3.10/site-packages/hailo_sdk_client/model_translator/translator.py:88, in HailoNNConverter.convert_model(self)
     87 self._handle_tokens_matmul()
---> 88 self._calculate_shapes(validate_shapes=False)
     89 self._add_output_layers()
File ~/my_env/lib/python3.10/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py:194, in ONNXConverter._calculate_shapes(self, validate_shapes)
    193 self._update_meta_graph()
--> 194 self._layers_graph.calculate_shapes(meta_edges_graph=self._meta_graph, validate_shapes=validate_shapes)
File ~/my_env/lib/python3.10/site-packages/hailo_sdk_common/hailo_nn/hailo_nn.py:755, in HailoNN.calculate_shapes(self, meta_edges_graph, validate_shapes)
    753     layer.output_copies = self.get_number_of_successors(layer)
--> 755 layer.update_output_shapes(hn_stage=self.net_params.stage, validate_shapes=validate_shapes)
File ~/my_env/lib/python3.10/site-packages/hailo_sdk_common/hailo_nn/hn_layers/layer.py:458, in Layer.update_output_shapes(self, **kwargs)
    457 output_shape = self._calc_output_shape()
--> 458 self.output_shapes = [output_shape[:] for _ in range(self.output_copies)]
File ~/my_env/lib/python3.10/site-packages/hailo_sdk_common/hailo_nn/hn_layers/layer.py:487, in Layer.output_shapes(self, output_shapes)
    486 for shape in output_shapes:
--> 487     self._append_output_shape(shape)
File ~/my_env/lib/python3.10/site-packages/hailo_sdk_common/hailo_nn/hn_layers/layer.py:461, in Layer._append_output_shape(self, output_shape)
    460 def _append_output_shape(self, output_shape):
--> 461     self._check_valid_shape(output_shape)
    462     self.append_output_shape(output_shape)
--> 454     raise UnsupportedModelError(f"Unexpected zero dimension in shape {shape} at {self.full_name_msg}")
UnsupportedModelError: Unexpected zero dimension in shape [-1, 4, 0, 64] at base conv layer base_conv1 (translated from /conv/Conv)
Cell In[4], line 2
      1 runner = ClientRunner(hw_arch=chosen_hw_arch)
----> 2 hn, npz = runner.translate_onnx_model(
      3 onnx_path,
      4 onnx_model_name,
      5 start_node_names=['input'],
      6 end_node_names=['output'],
      7 net_input_shapes={'input': [1, 1, 200]}
      8 )
File ~/my_env/lib/python3.10/site-packages/hailo_sdk_common/states/states.py:16, in allowed_states.<locals>.wrap.<locals>.wrapped_func(self, *args, **kwargs)
     13     raise InvalidStateException(
     14         f"The execution of {func.__name__} is not available under the state: {self._state.value}",
     15     )
---> 16 return func(self, *args, **kwargs)
File ~/my_env/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py:1158, in ClientRunner.translate_onnx_model(self, model, net_name, start_node_names, end_node_names, net_input_shapes, augmented_path, disable_shape_inference, disable_rt_metadata_extraction, net_input_format, **kwargs)
   1115 """
   1116 DFC API for parsing an ONNX model. This creates a runner with loaded HN (model) and
   1117 parameters.
   1155
   1156 """
   1157 parser = Parser()
-> 1158 parser.translate_onnx_model(
   1159     model=model,
   1160     net_name=net_name,
   1161     start_node_names=start_node_names,
   1162     end_node_names=end_node_names,
   1163     net_input_shapes=net_input_shapes,
   1164     augmented_path=augmented_path,
   1165     disable_shape_inference=disable_shape_inference,
   1166     disable_rt_metadata_extraction=disable_rt_metadata_extraction,
   1167     net_input_format=net_input_format,
   1168     **kwargs,
   1169 )
   1171 return self._finalize_parsing(parser.return_data)
File ~/my_env/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py:260, in Parser.translate_onnx_model(self, model, net_name, start_node_names, end_node_names, net_input_shapes, augmented_path, disable_shape_inference, disable_rt_metadata_extraction, net_input_format, **kwargs)
    257     milestone = self._format_time_milestone(start_time)
    258     self._logger.info(f"Simplified ONNX model for a parsing retry attempt (completion time: {milestone})")
--> 260     parsing_results = self._parse_onnx_model_to_hn(
    261         onnx_model=simplified_model,
    262         net_name=valid_net_name,
    263         start_node_names=start_node_names,
    264         end_node_names=end_node_names,
    265         net_input_shapes=net_input_shapes,
    266         disable_shape_inference=disable_shape_inference,
    267         net_input_format=net_input_format,
    268         **kwargs,
    269     )
    271 milestone = self._format_time_milestone(start_time)
    272 self._logger.info(f"Translation completed on ONNX model {valid_net_name} (completion time: {milestone})")
    297     except Exception as e:
    301     onnx_model,
    302     None,
    303     net_name,
    305     end_node_names,
    309     **kwargs,
    310 )
    348 else:
    353 hailo_nn.validate_stage(HnStage.HN)
     86 self._handle_inner_product_matmul()
     90 self._handle_fused_layers()
    192 def _calculate_shapes(self, validate_shapes=True):
    752 else:
    456 def update_output_shapes(self, **kwargs):
    485 self._output_shapes = []
    451         f"Dimension must be of type 'int' or 'long'",
    452     )
I have also attached the onnx structure I viewed using netron.
I think that you get a dimmension 0 in one of the middle tensors. Try to do onnxsim on your ONNX and see the inter layer tensors.
I have done the onnxsim.
I looked the node information using the following code.
import onnx
import onnxruntime as ort
model_path = 'SimplifiedModel.onnx'
model = onnx.load(model_path)
session = ort.InferenceSession(model_path)
input_shape = [1, 1, 200]
input_data = np.random.random(input_shape).astype(np.float32)
input_name = session.get_inputs()[0].name
outputs = session.run(None, {input_name: input_data})
def extract_tensor_shapes_from_initializer(model):
    initializer_shapes = {}
    for initializer in model.graph.initializer:
        shape = [dim for dim in initializer.dims]
        initializer_shapes[initializer.name] = shape
    return initializer_shapes
def get_tensor_shapes(model):
    tensor_shapes = {}
    initializer_shapes = extract_tensor_shapes_from_initializer(model)
    for tensor in model.graph.value_info:
        shape = [dim.dim_value for dim in tensor.type.tensor_type.shape.dim]
        tensor_shapes[tensor.name] = shape
    for output in model.graph.output:
        shape = [dim.dim_value for dim in output.type.tensor_type.shape.dim]
        tensor_shapes[output.name] = shape
    tensor_shapes.update(initializer_shapes)
    return tensor_shapes
tensor_shapes = get_tensor_shapes(model)
for node in model.graph.node:
    print(f"Node: {node.name}, OpType: {node.op_type}")
    for input in node.input:
        if input in tensor_shapes:
            print(f"  Input: {input}, Shape: {tensor_shapes[input]}")
        else:
            print(f"  Input: {input}, Shape: Unknown")
    for output in node.output:
        if output in tensor_shapes:
            print(f"  Output: {output}, Shape: {tensor_shapes[output]}")
        else:
            print(f"  Output: {output}, Shape: Unknown")
And I get the results as,
  Input: input, Shape: Unknown
  Input: onnx::Conv_17, Shape: [64, 1, 5]
  Input: onnx::Conv_18, Shape: [64]
  Output: /conv/Conv_output_0, Shape: [1, 64, 101]
Node: /relu/Relu, OpType: Relu
  Input: /conv/Conv_output_0, Shape: [1, 64, 101]
  Output: /relu/Relu_output_0, Shape: [1, 64, 101]
Node: /maxpool/MaxPool, OpType: MaxPool
  Input: /relu/Relu_output_0, Shape: [1, 64, 101]
  Output: /maxpool/MaxPool_output_0, Shape: [1, 64, 50]
Node: /avgpool/GlobalAveragePool, OpType: GlobalAveragePool
  Input: /maxpool/MaxPool_output_0, Shape: [1, 64, 50]
  Output: /avgpool/GlobalAveragePool_output_0, Shape: [1, 64, 1]
Node: /Flatten, OpType: Flatten
  Input: /avgpool/GlobalAveragePool_output_0, Shape: [1, 64, 1]
  Output: /Flatten_output_0, Shape: [1, 64]
Node: /fc/Gemm, OpType: Gemm
  Input: /Flatten_output_0, Shape: [1, 64]
  Input: fc.weight, Shape: [73, 64]
  Input: fc.bias, Shape: [73]
  Output: output, Shape: [1, 73]
Netron of the simplified ONNX is the same as the one I provided earlier.
Do you have any recommendation?
something in your shapes looks strange, please try to keep 4d vectors along the net
You were correct, I had to use the 4D vectors. For this I converter my 1D data to 4D.
The updated Model looks like this.
    def __init__(self, input_channel, num_classes=73):
        self.conv1 = nn.Conv2d(input_channel, 64, kernel_size=(1, 5), stride=(1, 2), padding=(0, 3), bias=False)
        self.bn1 = nn.BatchNorm2d(64)
        self.maxpool = nn.MaxPool2d(kernel_size=(1, 3), stride=(1, 2), padding=(0, 0))
        self.conv2 = nn.Conv2d(64, 128, kernel_size=(1, 3), stride=(1, 1), padding=(0, 1), bias=False)
        self.bn2 = nn.BatchNorm2d(128)
        self.conv3 = nn.Conv2d(128, 256, kernel_size=(1, 3), stride=(1, 1), padding=(0, 1), bias=False)
        self.bn3 = nn.BatchNorm2d(256)
        self.avgpool = nn.AdaptiveAvgPool2d((1, 1))
        self.fc = nn.Linear(256, num_classes)
        x = self.conv1(x)
        x = self.bn1(x)
        x = self.relu(x)
        x = self.maxpool(x)
        x = self.conv2(x)
        x = self.bn2(x)
        x = self.relu(x)
        x = self.conv3(x)
        x = self.bn3(x)
        x = self.relu(x)
        x = self.avgpool(x)
        x = self.fc(x)
        return x
After the restructuring, I did not even need to use onnxsim for simplification.
Next for the conversion to HAR file, optimization and the compile to HEF, I ended up using this code from
import os
#Define model information
model_name = 'Model'
onnx_path = 'my_env/Model.onnx'
start_node = 'input'
end_node = 'output'
input_shape = {'input': [1, 1, 1, 200]}
input_height = 1
input_width = 200
input_ch = 1
alls_lines = [
'model_optimization_flavor(optimization_level=0, compression_level=1)\n',
'resources_param(max_control_utilization=1.0, max_compute_utilization=1.0,max_memory_utilization=1.0)\n',
'performance_param(fps=250)\n'
#Parsing
hn, npz = runner.translate_onnx_model(onnx_path, model_name, start_node_names=[start_node], end_node_names=end_node, net_input_shapes=input_shape)
parsed_model_har_path = f'{model_name}_parsed_model.har'
runner.save_har(parsed_model_har_path)
#Optimize
calibData = np.random.randint(0, 255, (1024, input_height, input_width, input_ch)).transpose(0, 3, 2, 1)
runner.load_model_script(''.join(alls_lines))
runner.optimize(calibData)
quantized_model_har_path = f'{model_name}_quantized_model.har'
#Compile
hef = runner.compile()
file_name = f'{model_name}.hef'
with open(file_name, 'wb') as f:
    f.write(hef)
compiled_model_har_path = f'{model_name}_compiled_model.har'
runner.save_har(compiled_model_har_path)
I am not user if the output is correct because I am using 1D data and not image. So for optimization and quantization I did not find ant relevant documentations. However, conversion to HAR seems to be completed.
