Help needed, convert ONNX Resnet34 to .hef
Hello All,
for some weeks I tried to convert a pretrained Model to a usable hef for an University Project so it can run on the hailo8l. I used the DFC Tutorial to parse the onnx, then Optimize it with a Dataset of relevant Pictures and compiled it.
Now I try to run it on the pi. When I try it with an onnx the results are accurate:
import onnxruntime as ort
from PIL import Image
def preprocess_image(image_path, input_size):
    image = Image.open(image_path).convert("RGB")
    image = image.resize(input_size)
    image_array = np.asarray(image).astype(np.float32)
    image_array /= 255.0
    image_array = np.transpose(image_array, (2, 0, 1))
    image_array = np.expand_dims(image_array, axis=0)
    return image_array
# Modell laden
onnx_model_path = "bird-resnet34.onnx"
session = ort.InferenceSession(onnx_model_path)
# Bild vorbereiten
image_path = "snowly-owl-migration.webp"
input_size = (250, 250)  # Modellabhängig
input_data = preprocess_image(image_path, input_size)
print(f"Input shape: {input_data.shape}")
# Vorhersagen
input_name = session.get_inputs()[0].name
output_name = session.get_outputs()[0].name
predictions = session.run([output_name], {input_name: input_data})[0]
# Höchstwahrscheinlichkeit und Klasse
predicted_class = np.argmax(predictions)
print(f"Vorhergesagte Klasse: {predicted_class} ({bird_name_map[predicted_class]})")
Now I want to use the converted Onnx as a hef file on the Pi.
The Problem is that the result of the model is a 450 long array with the probability of every bird as a float. The Problem I think is that the hailo 8l only uses uint8 and now my output looks like this for example:
[ 45 124 132  60 124  52 150 168  96  37  50 119  73   4  11  91  88  53
   95  59  24 123  77  57  89 103  26  74  26 131 140 102 106  93  89  78
  105 138 171 110 194 148 106 100 140  70  78 127  69  63 116 100  95  97
  169 221  68  16  11   0 139 151   6 108 112 123  37 104 190  98 155  66
   22  45  98  86  80  50  80  16  32  83  91 116 116 126 124 141 134 180
  128   8  97  90 146  77  84   0  68  81 112 120  63 130 112  95  52  63
  116 139  69 130 145  79  63 134  70  65  49  79 206  90  57 139 136  43
  133  72 114 140  92  67  30 144  77  99 179 116  10   0 173  62  17  22
  134  37 218 120 112  38 131 161  66  56 151 136 115 147  81 149  85 137
   51  91 160 105   4 109 117 166 100  79 132  49 122 170 115  44 143 143
  164 106  34 126 118 162  68 110 152  70  96 163 174 145 119 186 147  92
  168 144 106 137 160 179 146 150 145  16  52  70 111 123 127   0 135 122
  174 149  50  72 145 116 131  51 154  48  64  54 132  80 164 107 145 140
  105 140 189  78 142 188  76  83 138 153 128 113 144 106  98 127  72 174
   86 112 126 161 108  93  76  74  94  92  21  29 235 116 123 122  79  64
   81 173 142   0 119 119 127  29 108  32 135 161 110  72 145  62  46 110
  127 173  47 103  22  98 102  54 100 127 103 116 152 101 176 116  73 106
  169   0 103 173  55 103  78  86  70 201  58  72  47  70  50 127  59 115
   68  45 113 138 143 128  78 114  53 100 148  30 111  98 110  57 101 142
  111  77   0  38 112  28  83  26 104 126 112  98 141 112  59 120  70 128
  103  65  42 146 170 162 146  85  64 180  82  82  65  86  38  86 163  22
  127  86  79  56   4 127 186 135  79 109  77  90 126 107 113  99  94 123
  136 138  69  92  71  86 124 138  31   0 121  55  26  97 101  84 115  70
  158 128  56 120 145  60 147  15  54  18  70  59  74  14 132   2 149   0
  151 128 117 116 179  75 152 118  98  57  87  58  81 112 157  71 146  46]
but even when I just look for the Max number, it isnt a remotlyy correct answer. I used this code:
import cv2
from hailo_platform import (VDevice, HEF, ConfigureParams, InferVStreams, InputVStreamParams, OutputVStreamParams,
                            FormatType, HailoStreamInterface)
def initialize_hailo(hef_path):
    # Initialisiere das Hailo-Gerät
    target = VDevice()
    hef = HEF(hef_path)
    # Netzwerkgruppen konfigurieren
    return target, hef, network_groups[0]
def create_vstreams(network_group):
    # Eingabe- und Ausgabe-Streams erstellen
    input_vstreams_params = InputVStreamParams.make(network_group, format_type=FormatType.UINT8)
    output_vstreams_params = OutputVStreamParams.make(network_group, format_type=FormatType.UINT8)
    return input_vstreams_params, output_vstreams_params
def preprocess_image(image_path, input_shape, mean, std):
    # Lade und transformiere das Bild
    image = cv2.imread(image_path)
    height, width, _ = input_shape  # Entpacke Höhe, Breite und Kanäle
    resized = cv2.resize(image, (width, height))  # Breite und Höhe für OpenCV
    normalized = (resized / 255.0 - mean) / std
    return normalized.astype(np.uint8)
def preprocess_frame(frame, input_shape):
    resized = cv2.resize(frame, (width, height))  # Breite und Höhe für OpenCV
    normalized = resized / 255.0  # Normalisiere die Pixelwerte
def run_inference(network_group, input_vstreams_params, output_vstreams_params, input_data):
        input_vstream_info = network_group.get_input_vstream_infos()[0]
        output_vstream_info = network_group.get_output_vstream_infos()[0]
        # Eingabedaten verpacken
        input_data_dict = {input_vstream_info.name: np.expand_dims(input_data, axis=0)}
        # Netzwerkgruppe aktivieren
        with network_group.activate():
            infer_results = infer_pipeline.infer(input_data_dict)
        # Ergebnisse extrahieren
        return infer_results[output_vstream_info.name]
def interpret_results(results, labels):
    # Höchste Wahrscheinlichkeit finden
    predicted_class = np.argmax(results)
    confidence = results[0][predicted_class]
    return labels[predicted_class], confidence
bird_name_map= {0: 'ABBOTTS BABBLER', ...}
hef_path = "/home/vogelscheuche/Vogelscheuche/bird-resnet34_v3.hef"
image_path = "snowy-owl-migration.webp"
# Normalisierungswerte
mean = np.array([0.4758, 0.4685, 0.3870])  # Mittelwerte für R, G, B
std = np.array([0.2376, 0.2282, 0.2475])   # Standardabweichungen für R, G, B
#Initialisiere Hailo
target, hef, network_group = initialize_hailo(hef_path)
input_vstreams_params, output_vstreams_params = create_vstreams(network_group)
input_shape = input_vstream_info.shape
print('input shape',input_shape)
input_data = preprocess_image(image_path, input_shape,mean,std)
print('input data shape', input_data.shape)
results = run_inference(network_group, input_vstreams_params, output_vstreams_params, input_data)
print(results)
predicted_bird, confidence = interpret_results(results, bird_name_map)
print(f"Erkannter Vogel: {predicted_bird} mit {confidence * 100:.2f}% Sicherheit")
Is my error because I use the results wrong, or could it be that I butchered the Conversion from onnx to hef?
Any help would be appreciated
Thank You Very much,
Till
Hi @Till,
Conversion of a resnet34 should be fairly straight forward. I recommend taking a look at our resnet18 conversion tutorial that should be very close to what you need. You can either launch it with the command hailo tutrial whereever your DFC is installed, or have a look at it’s static version in the DFC doc.
Hi Nadav,
thank you for the reply, I tried to do the steps with the example resnet onnx. I got the hef and it should be compiled, but Im not sure how to use the Hef on the Pi. I used the Tutorial for Inference, it uses the right input and gets the right output shape. But the Output Data are some ints in the range 0-5. I dont think I can extract useful results out of it. Do you know if there is a Tutorial or file for Inference, where an Input Picture and labels are used and the image gets classified by the resnet model which is used in the Tutorial?
Thank you and Best regards
Till
Hey @Till,
If you already have a working HEF (Hailo Executable Format) file, I recommend the following steps:
  1. Run the command hailortcli run {hef} to check if the model runs correctly and to determine the FPS (frames per second) it achieves.
  2. Take a look at our C++ classifier example located at Hailo-Application-Code-Examples/runtime/cpp/classifier at main · hailo-ai/Hailo-Application-Code-Examples · GitHub. This example uses ResNet v1 50. While it’s not specifically optimized for the Raspberry Pi, it will still work on that platform. You can refer to this example to see how we use classifiers.
  3. For optimal performance on the Raspberry Pi, I recommend creating your own pipeline. You can find instructions on how to do this in our documentation at hailo-rpi5-examples/doc/basic-pipelines.md at main · hailo-ai/hailo-rpi5-examples · GitHub.
    To create your own pipeline, you’ll need to write a custom callback function that handles the model’s pre-processing and post-processing steps according to your requirements. This will allow you to run the model in an optimized manner on the Raspberry Pi.
If you need assistance creating your pipeline or have any other questions, please don’t hesitate to ask!
Best regards,
Omri
