Hey, I’m trying to convert a Tensorflow model I created to .hef format for inference on a Raspberry Pi. The model is based off of ssd_mobilenet_v2 – but I did add some modifications to the pipeline.config and ran it on a dataset of a few hundred images. Inference works great on the Tensorflow model. The idea is that input images of 640x640 are given and outputs are bounding boxes, confidence scores, etc. I’m on Windows using WSL, and in a Docker container. Downloaded the software suite image and everything is installed successfully. I’ll add the pipeline.config used to build the original Tensorflow model here:
model {
ssd {
num_classes: 1
image_resizer {
keep_aspect_ratio_resizer {
min_dimension: 640
max_dimension: 640
pad_to_max_dimension: true
feature_extractor {
type: "ssd_mobilenet_v2_fpn_keras"
depth_multiplier: 1.0
min_depth: 16
conv_hyperparams {
regularizer {
l2_regularizer {
weight: 3.9999998989515007e-05
initializer {
random_normal_initializer {
mean: 0.0
stddev: 0.009999999776482582
activation: RELU_6
batch_norm {
decay: 0.996999979019165
scale: true
epsilon: 0.0010000000474974513
use_depthwise: true
override_base_feature_extractor_hyperparams: true
fpn {
min_level: 3
max_level: 7
additional_layer_depth: 128
box_coder {
faster_rcnn_box_coder {
y_scale: 10.0
x_scale: 10.0
height_scale: 5.0
width_scale: 5.0
matcher {
argmax_matcher {
matched_threshold: 0.5
unmatched_threshold: 0.5
ignore_thresholds: false
negatives_lower_than_unmatched: true
force_match_for_each_row: true
use_matmul_gather: true
similarity_calculator {
iou_similarity {
box_predictor {
weight_shared_convolutional_box_predictor {
conv_hyperparams {
regularizer {
l2_regularizer {
initializer {
mean: 0.0
activation: RELU_6
batch_norm {
scale: true
depth: 128
num_layers_before_predictor: 4
kernel_size: 3
class_prediction_bias_init: -4.599999904632568
share_prediction_tower: true
use_depthwise: true
anchor_generator {
multiscale_anchor_generator {
min_level: 3
max_level: 7
anchor_scale: 4.0
aspect_ratios: 1.0
aspect_ratios: 2.0
aspect_ratios: 0.5
scales_per_octave: 2
post_processing {
batch_non_max_suppression {
score_threshold: 9.99999993922529e-09
iou_threshold: 0.6000000238418579
max_detections_per_class: 100
max_total_detections: 100
use_static_shapes: false
score_converter: SIGMOID
normalize_loss_by_num_matches: true
loss {
localization_loss {
weighted_smooth_l1 {
classification_loss {
weighted_sigmoid_focal {
gamma: 2.0
alpha: 0.25
classification_weight: 1.0
localization_weight: 1.0
encode_background_as_zeros: true
normalize_loc_loss_by_codesize: true
inplace_batchnorm_update: true
freeze_batchnorm: false
train_config {
batch_size: 2
data_augmentation_options {
random_horizontal_flip {
random_crop_image {
min_object_covered: 0.0
min_aspect_ratio: 0.75
max_aspect_ratio: 3.0
min_area: 0.75
max_area: 1.0
overlap_thresh: 0.0
random_rgb_to_gray {
random_adjust_brightness {
random_adjust_contrast {
sync_replicas: true
optimizer {
momentum_optimizer {
learning_rate {
cosine_decay_learning_rate {
learning_rate_base: 0.001
total_steps: 40000
warmup_learning_rate: 0.0009
warmup_steps: 2000
momentum_optimizer_value: 0.8999999761581421
use_moving_average: false
fine_tune_checkpoint: "checkpoint"
num_steps: 40000
startup_delay_steps: 0.0
replicas_to_aggregate: 8
max_number_of_boxes: 200
unpad_groundtruth_tensors: false
fine_tune_checkpoint_type: "detection"
fine_tune_checkpoint_version: V2
I converted the model to both savedmodel format and tflite format. I then successfully converted the model to .onnx format and ran the validator on the .onnx which came back valid. I’m having major issues converting the .onnx to .hef format now.
Things I’ve tried:
- hailomz compile --yaml model.yaml --ckpt ./model.onnx --hw-arch hailo8l --calib-path /images
Using this YAML file (I checked the input and output names are correct in Netron):
network:
network_name: ssd_mobilenet_v2_fpn_640x640_custom
paths:
network_path:
- /workspace/conversion_project/model.onnx
inputs:
- name: serving_default_input:0
shape: [1, 3, 640, 640]
outputs:
- name: StatefulPartitionedCall:1
shape: [1, 100, 4] # Assuming detection_boxes
- name: StatefulPartitionedCall:3
shape: [1, 100] # Assuming detection_scores
- name: StatefulPartitionedCall:0
shape: [1] # Assuming num_detections
- name: StatefulPartitionedCall:2
shape: [1, 100] # Assuming detection_classes
parser:
type: onnx
normalization_params:
normalize_in_net: true
mean_list: [127.5, 127.5, 127.5]
std_list: [127.5, 127.5, 127.5]
start_node_shapes:
serving_default_input:0: [1, 3, 640, 640]
nodes:
- serving_default_input:0
- - StatefulPartitionedCall:1
- StatefulPartitionedCall:3
- StatefulPartitionedCall:0
- StatefulPartitionedCall:2
preprocessing:
input_resolution: [640, 640]
padding_color: 0
postprocessing:
type: ssd_mobilenet_v2
num_classes: 1
nms_iou_threshold: 0.6
score_threshold: 1e-8
max_detections: 100
quantization:
calib_set: /images
The error message I get for this is:
<Hailo Model Zoo INFO> Start run for network ssd_mobilenet_v2_fpn_640x640_custom ...
File "/local/workspace/hailo_virtualenv/bin/hailomz", line 33, in <module>
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py", line 122, in main
run(args)
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py", line 111, in run
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 248, in compile
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 73, in _ensure_optimized
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 108, in _ensure_parsed
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/core/main_utils.py", line 126, in parse_model
raise Exception(f"Encountered error during parsing: {err}") from None
Exception: Encountered error during parsing: Expecting value: line 1 column 1 (char 0)
Seems to be some kind of JSON parsing issue. Incredibly cryptic error.
- I tried running a custom script to compile the model:
from pathlib import Path
import os
def convert_onnx_to_hef(onnx_model_path, output_hef_path):
onnx_model_path = Path(onnx_model_path).resolve() # Resolve symlinks
print(f"ONNX path (Posix): {onnx_model_path.as_posix()}")
# Validate file access
if not onnx_model_path.exists():
raise FileNotFoundError(f"File {onnx_model_path} does not exist")
os.access(onnx_model_path, os.R_OK) # Explicit read check
client = ClientRunner()
# Using the suggested nodes from the error message
try:
translated_model = client.translate_onnx_model(
str(onnx_model_path),
"weed_model",
start_node_names=['concat'],
end_node_names=['Exp__1013', 'Slice__1007'],
net_input_shapes={'concat': [1, 640, 640, 3]} # Match input shape key with start_node_names
# Compile the translated model to HEF
print(f"Translation successful, compiling to HEF: {output_hef_path}")
client.compile_model(translated_model, target_platform="hailo8", output_path=output_hef_path)
print(f"Compilation successful, HEF saved to: {output_hef_path}")
return translated_model
except TypeError as e:
print(f"Parameter name error: {e}")
return None
except Exception as e:
print(f"Error during translation: {e}")
# Try alternative approach with just one output node at a time
print("Attempting fallback approach with individual output nodes...")
for output_node in ['Exp__1013', 'Slice__1007']:
try:
print(f"Trying with single output node: {output_node}")
"weed_model",
end_node_names=[output_node],
# If successful, compile and return
output_path=f"{output_hef_path.rstrip('.hef')}_{output_node.replace(':', '_')}.hef")
print(f"Partial compilation successful with output node {output_node}")
except Exception as inner_e:
print(f"Failed with output node {output_node}: {inner_e}")
return None
if __name__ == "__main__":
# Use full path to ensure no ambiguity
input_model_path = "/workspace/conversion_project/model_simplified.onnx"
output_hef_path = "/workspace/conversion_project/weeds.hef"
convert_onnx_to_hef(input_model_path, output_hef_path)
Again, I verified the input and output names are correct. In this case the model conversion runs silently for about 10 minutes before kicking out with the following error:
[info] Translation started on ONNX model weed_model
[info] Restored ONNX model weed_model (completion time: 00:00:00.07)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.67)
[warning] ONNX shape inference failed: [ONNXRuntimeError] : 2 : INVALID_ARGUMENT : Invalid model. Node input 'ssd_mobile_net_v2_fpn_keras_feature_extractor/FeatureMaps/top_down/projection_3/BiasAdd;WeightSharedConvolutionalBoxPredictor/WeightSharedConvolutionalClassHead/ClassPredictor/separable_conv2d_4/depthwise;ssd_mobile_net_v2_fpn_keras_feature_extractor/FeatureMaps/top_down/projection_3/Conv2D;ssd_mobile_net_v2_fpn_keras_feature_extractor/FeatureMaps/top_down/projection_3/BiasAdd/ReadVariableOp' is not a graph input, initializer, or output of a previous node.
[info] Unable to simplify the model: cannot reshape array of size 4 into shape (1,1,640,1)
Error during translation: cannot reshape array of size 4 into shape (1,1,640,1)
Is there something obvious I’m missing or is there a simpler way to do this? My model is actually really simple (like 7MB) and I feel like it shouldn’t be this hard to get it working on the Hailo8L. Are there simpler/less problematic options like converting model to different intermediary format?
Thanks!
