ONNX model conversion problem
I have a simple ONNX model trained and downloaded from Microsoft CustomVision. It could work in the ONNX runtime, but after converting to HEF using DFC following the parse, optimization and compile, it can’t work (input data are the same, but output data are greatly different). I’ve no idea what’s going wrong, so post here to ask some help, thanks.
The original ONNX model:
The convention steps:
hailo parser onnx --hw-arch hailo8 models/model.onnx
hailo optimize --hw-arch hailo8 --use-random-calib-set model.har
hailo compiler --hw-arch hailo8 model_optimized.har
There are logs during the conversion:
  1. parse
[info] Current Time: 18:30:59, 11/09/24
[info] CPU: Architecture: x86_64, Model: Intel(R) Xeon(R) Platinum 8163 CPU @ 2.50GHz, Number Of Cores: 16, Utilization: 0.6%
[info] Memory: Total: 30GB, Available: 26GB
[info] System info: OS: Linux, Kernel: 5.15.0-122-generic
[info] Running `hailo parser onnx --hw-arch hailo8 models/model.onnx`
[info] Translation started on ONNX model model
[info] Restored ONNX model model (completion time: 00:00:00.38)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:01.21)
/home/hailo-test/onnx-to-hailo/venv/lib/python3.10/site-packages/tensorflow_addons/utils/tfa_eol_msg.py:23: UserWarning:
TensorFlow Addons (TFA) has ended development and introduction of new features.
TFA has entered a minimal maintenance and release mode until a planned end of life in May 2024.
Please modify downstream libraries to take dependencies from other repositories in our TensorFlow community (e.g. Keras, Keras-CV, and Keras-NLP).
For more information see: https://github.com/tensorflow/addons/issues/2807
  warnings.warn(
/home/hailo-test/onnx-to-hailo/venv/lib/python3.10/site-packages/tensorflow_addons/utils/ensure_tf_install.py:53: UserWarning: Tensorflow Addons supports using Python ops for all Tensorflow versions above or equal to 2.13.0 and strictly below 2.16.0 (nightly versions are not supported).
 The versions of TensorFlow you are currently using is 2.12.0 and is not supported.
Some things might work, some things might not.
If you were to encounter a bug, do not file an issue.
If you want to make sure you're using a tested and supported configuration, either change the TensorFlow version or the TensorFlow Addons's version.
You can find the compatibility matrix in TensorFlow Addon's readme:
  warnings.warn(
[warning] ONNX shape inference failed: Field 'type' of 'value_info' is required but missing.
[info] Start nodes mapped from original model: 'data': 'model/input_layer1'.
[info] End nodes mapped from original model: 'convolution8'.
[info] Translation completed on ONNX model model (completion time: 00:00:01.72)
[info] Saved HAR to: /home/hailo-test/onnx-to-hailo/model.har
  1. optimize
[info] Current Time: 18:32:24, 11/09/24
[info] CPU: Architecture: x86_64, Model: Intel(R) Xeon(R) Platinum 8163 CPU @ 2.50GHz, Number Of Cores: 16, Utilization: 0.5%
[info] Running `hailo optimize --hw-arch hailo8 --use-random-calib-set model.har`
[info] Mixed Precision is done (completion time is 00:00:00.10)
Calibration: 100%|████████████████████████████████████████████████████████████████████████████████████████████████████████████| 64/64 [00:09<00:00,  6.77entries/s]
[info] Statistics Collector is done (completion time is 00:00:09.84)
[info] No shifts available for layer model/conv1/conv_op, using max shift instead. delta=2.8604
[info] Adaround skipped
[info] The calibration set seems to not be normalized, because the values range is [(0.0, 1.0), (0.0, 1.0), (0.0, 1.0)].
Since the neural core works in 8-bit (between 0 to 255), a quantization will occur on the CPU of the runtime platform.
Add a normalization layer to the model to offload the normalization to the neural core.
Refer to the user guide Hailo Dataflow Compiler user guide / Model Optimization / Optimization Related Model Script Commands / model_modification_commands / normalization for details.
[info] Saved HAR to: /home/hailo-test/onnx-to-hailo/model_optimized.har
  1. compile
[info] Current Time: 18:33:52, 11/09/24
[info] Running `hailo compiler --hw-arch hailo8 model_optimized.har`
[info] Compiling network
[info] Resources optimization guidelines: Strategy -> GREEDY Objective -> MAX_FPS
[info] Resources optimization params: max_control_utilization=75%, max_compute_utilization=75%, max_compute_16bit_utilization=75%, max_memory_utilization (weights)=75%, max_input_aligner_utilization=75%, max_apu_utilization=75%
Validating context_0 layer by layer (100%)
● Finished
Context:0/0 Iteration 4: Trying parallel mapping...
          cluster_0  cluster_1  cluster_2  cluster_3  cluster_4  cluster_5  cluster_6  cluster_7  prepost
 worker0  V          V          V          V          V          V          V          V          V
 worker1  V          V          V          V          V          V          V          V          V
 worker2  V          V          V          V          V          V          X          V          V
 worker3  V          V          V          V          V          V          V          V          V
  00:34
Reverts on cluster mapping: 0
Reverts on split failed: 0
[info] Iterations: 4
[info] +-----------+---------------------+---------------------+--------------------+
[info] | Cluster   | Control Utilization | Compute Utilization | Memory Utilization |
[info] | cluster_0 | 50%                 | 46.9%               | 41.4%              |
[info] | cluster_1 | 31.3%               | 20.3%               | 27.3%              |
[info] | cluster_2 | 68.8%               | 85.9%               | 53.1%              |
[info] | cluster_3 | 100%                | 92.2%               | 68%                |
[info] | cluster_4 | 68.8%               | 60.9%               | 68%                |
[info] | cluster_5 | 81.3%               | 85.9%               | 85.2%              |
[info] | cluster_6 | 18.8%               | 7.8%                | 6.3%               |
[info] | cluster_7 | 12.5%               | 14.1%               | 17.2%              |
[info] | Total     | 53.9%               | 51.8%               | 45.8%              |
[info] Successful Mapping (allocation time: 1m 10s)
[info] Compiling context_0...
[info] Bandwidth of model inputs: 3.96094 Mbps, outputs: 0.0515747 Mbps (for a single frame)
[info] Bandwidth of inter context tensors: 0.0 Mbps (for a single frame)
[info] Building HEF...
[info] Successful Compilation (compilation time: 43s)
[info] Compilation complete
[info] Saved HEF to: /home/hailo-test/onnx-to-hailo/model.hef
[info] Saved HAR to: /home/hailo-test/onnx-to-hailo/model_compiled.har
The model after conversion:
Hey @meng.li
The discrepancy between the expected and actual outputs after converting the ONNX model to HEF format is likely due to calibration, normalization, or compatibility issues. Here’s how to address these areas to improve output fidelity on the Hailo hardware.
Steps to Improve Model Output Consistency
  1. Use a Representative Calibration Set:
    • Instead of relying on a random calibration set, use a calibration dataset that closely matches the data distribution expected during actual inference. This helps ensure that the quantization process correctly captures the range and characteristics of real input data, reducing inaccuracies.
    • Replace --use-random-calib-set with a specific calibration set in the hailo optimize command:
      hailo optimize --hw-arch hailo8 --calib-path /path/to/your_calib_data model.har
  2. Normalize Input Data:
    • The log suggests that your model’s input data may need normalization to match the Hailo hardware’s expected range of 0-255 (8-bit integer). Without proper normalization, the model may produce unexpected results.
    • Ensure that your input data is scaled correctly before it reaches the model. If needed, add a normalization layer to your ONNX model to scale inputs to the 0-255 range. This can be done by modifying the ONNX model directly before parsing.
  3. Check for Compatibility in Model Layers:
    • Some layers, like LeakyReLU, may have subtle differences in performance between the ONNX runtime and the Hailo hardware. Where possible, replace these layers with standard alternatives like ReLU that are fully supported and yield more predictable behavior on Hailo devices.
    • Modifying your model to use simpler, supported layers can sometimes resolve inconsistencies.
  4. Optimize for Accuracy:
    • If achieving accuracy is more critical than performance, consider optimizing the model specifically for accuracy. During the hailo compiler step, ensure that the optimization parameters are set to focus on accuracy rather than speed:
  5. Compare Intermediate Outputs:
    • For additional troubleshooting, perform inference on both the ONNX runtime and Hailo hardware using the same inputs, and log intermediate layer outputs if possible. This will help identify where outputs start to diverge, which can highlight specific layers or transformations that may be causing discrepancies.
I’m having the same issue… Were you able to solve it?
