I’ve been trying to follow this guide:
and I’m not having a lot of luck. I’m finding my way on this, but here’s what I’ve done:
I trained a custom model using yolov5s. When the model completed training, this summary was printed:
75 epochs completed in 14.914 hours.
Optimizer stripped from runs/detect/train/weights/last.pt, 18.5MB
Optimizer stripped from runs/detect/train/weights/best.pt, 18.5MB
Validating runs/detect/train/weights/best.pt...
Ultralytics 8.3.162 🚀 Python-3.9.22 torch-2.7.1+cu126 CUDA:0 (NVIDIA L4, 22574MiB)
YOLOv5s summary (fused): 84 layers, 9,112,310 parameters, 0 gradients, 23.8 GFLOPs
Class Images Instances Box(P R mAP50 mAP50-95): 100%|██████████| 29/29 [00:17<00:00, 1.67it/s]
all 2854 11206 0.868 0.775 0.855 0.648
person 2693 11004 0.868 0.673 0.804 0.577
cat 184 202 0.869 0.876 0.906 0.719
Speed: 0.1ms preprocess, 1.9ms inference, 0.0ms loss, 0.7ms postprocess per image
I’ve downloaded the docker container and have a shell running in it.
I put my converted onnx file into the shared_with_docker folder. I copied hailo_model_zoo/cfg/networks/yolov5s.yaml to shared_with_docker and added the # classes. The complete file looks like:
base:
- base/yolov5.yaml
network:
network_name: yolov5s
evaluation:
classes: 2
paths:
alls_script: yolov5s.alls
network_path:
- models_files/ObjectDetection/Detection-COCO/yolo/yolov5s_spp/pretrained/2023-04-25/yolov5s.onnx
url: https://hailo-model-zoo.s3.eu-west-2.amazonaws.com/ObjectDetection/Detection-COCO/yolo/yolov5s_spp/pretrained/2023-04-25/yolov5s.zip
postprocessing:
device_pre_post_layers:
nms: true
meta_arch: yolo_v5
hpp: true
info:
task: object detection
input_shape: 640x640x3
output_shape: 80x5x80
operations: 17.44G
parameters: 7.46M
framework: pytorch
training_data: coco train2017
validation_data: coco val2017
eval_metric: mAP
full_precision_result: 35.33
source: https://github.com/ultralytics/yolov5/releases/tag/v2.0
license_url: https://github.com/ultralytics/yolov5/blob/master/LICENSE
license_name: GPL-3.0
when I try to create the hef file, i get:
(hailo_virtualenv) hailo@reddwarf:/local/shared_with_docker$ hailomz compile --yaml yolov5s.yaml --ckpt person_cat.onnx --hw-arch hailo8l --calib-path calib --classes 2
<Hailo Model Zoo INFO> Start run for network yolov5s ...
[info] Translation started on ONNX model yolov5s
[info] Restored ONNX model yolov5s (completion time: 00:00:00.08)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.29)
[info] Simplified ONNX model for a parsing retry attempt (completion time: 00:00:00.64)
[info] According to recommendations, retrying parsing with end node names: ['/model.24/Concat_3'].
[info] Restored ONNX model yolov5s (completion time: 00:00:00.06)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.27)
[info] In order to use HailoRT post-processing capabilities, these end node names should be used: /model.24/cv2.0/cv2.0.2/Conv /model.24/cv3.0/cv3.0.2/Conv /model.24/cv2.1/cv2.1.2/Conv /model.24/cv3.1/cv3.1.2/Conv /model.24/cv2.2/cv2.2.2/Conv /model.24/cv3.2/cv3.2.2/Conv.
[info] Start nodes mapped from original model: 'images': 'yolov5s/input_layer1'.
[info] End nodes mapped from original model: '/model.24/Concat_3'.
[info] Translation completed on ONNX model yolov5s (completion time: 00:00:00.57)
[info] End nodes mapped from original model: '/model.24/cv2.0/cv2.0.2/Conv', '/model.24/cv3.0/cv3.0.2/Conv', '/model.24/cv2.1/cv2.1.2/Conv', '/model.24/cv3.1/cv3.1.2/Conv', '/model.24/cv2.2/cv2.2.2/Conv', '/model.24/cv3.2/cv3.2.2/Conv'.
[info] Appending model script commands to yolov5s from string
[info] Saved HAR to: /local/shared_with_docker/yolov5s.har
[info] Loading model script commands to yolov5s from /local/workspace/hailo_model_zoo/hailo_model_zoo/cfg/alls/generic/yolov5s.alls
[info] Loading model script commands to yolov5s from string
File "/local/workspace/hailo_virtualenv/bin/hailomz", line 33, in <module>
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py", line 122, in main
run(args)
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py", line 111, in run
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 248, in compile
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 91, in _ensure_optimized
optimize_model(
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/core/main_utils.py", line 351, in optimize_model
optimize_full_precision_model(runner, calib_feed_callback, logger, model_script, resize, input_conversion, classes)
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/core/main_utils.py", line 337, in optimize_full_precision_model
runner.optimize_full_precision(calib_data=calib_feed_callback)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 2090, in optimize_full_precision
self._optimize_full_precision(data_continer)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 2093, in _optimize_full_precision
self._sdk_backend.optimize_full_precision(data_continer)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py", line 1722, in optimize_full_precision
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py", line 1610, in _apply_model_modification_commands
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/script_parser/nms_postprocess_command.py", line 404, in apply
pp_creator = create_nms_postprocess(
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/tools/core_postprocess/nms_postprocess.py", line 1824, in create_nms_postprocess
pp_creator.prepare_hn_and_weights(
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/tools/core_postprocess/nms_postprocess.py", line 1641, in prepare_hn_and_weights
super().prepare_hn_and_weights(hw_consts, engine, **kwargs)
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/tools/core_postprocess/nms_postprocess.py", line 1119, in prepare_hn_and_weights
self.add_postprocess_layer_to_hn()
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/tools/core_postprocess/nms_postprocess.py", line 1068, in add_postprocess_layer_to_hn
raise NMSConfigPostprocessException(f"The layer {encoded_layer.name} doesn't have one output layer")
hailo_sdk_client.tools.core_postprocess.nms_postprocess.NMSConfigPostprocessException: The layer yolov5s/conv55 doesn't have one output layer
Can anyone give me a hand with this? It seems like I’m just inches from the finish line and I’m stuck!
Thanks!
