The stack trace points to an issue with VDMA buffer mapping in the hailo_pci driver 4.20.1.
Hello Community,
I use Hailo8L with last beta frigate which contain hailo module developed by Hailo AI team. I use it on the QNAP TS262 storage with Debian and back ported kernel 6.12.22+bpo-amd64 with x86_64 OS. Version of the hailo pci module 4.20.1. The kernel stack trace points to an issue with VDMA buffer mapping in the hailo_pci driver. Please find below log.
best regards,
Patryk
[442539.846650] WARNING: CPU: 0 PID: 4164123 at include/linux/rwsem.h:80 find_vma+0x59/0x70
[442539.846659] Modules linked in: bluetooth msr mptcp_diag xsk_diag raw_diag unix_diag af_packet_diag netlink_diag vhost_net vhost vhost_iotlb tap tun tls tcp_diag udp_diag inet_diag veth nf_conntrack_netlink xt_nat xt_tcpudp xt_conntrack xt_MASQUERADE xt_set ip_set nft_chain_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 xt_addrtype nft_compat xfrm_user xfrm_algo squashfs overlay bridge cfg80211 rfkill softdog drivetemp sunrpc binfmt_misc nvidia_drm(POE) nvidia_modeset(POE) nvidia_uvm(POE) nls_ascii nls_cp437 vfat fat snd_ctl_led snd_soc_skl_hda_dsp snd_soc_intel_sof_board_helpers snd_soc_intel_hda_dsp_common snd_sof_probes snd_soc_dmic snd_sof_pci_intel_icl snd_sof_pci_intel_cnl snd_sof_intel_hda_generic soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda_common snd_soc_hdac_hda snd_sof_intel_hda_mlink snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_avs x86_pkg_temp_thermal snd_soc_hda_codec
[442539.846713] intel_powerclamp snd_hda_ext_core kvm_intel snd_soc_core snd_compress i915 snd_pcm_dmaengine nvidia(POE) snd_hda_codec_hdmi snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi kvm snd_hda_codec zfs(POE) snd_hda_core drm_buddy crct10dif_pclmul mei_pxp ghash_clmulni_intel snd_hwdep mei_hdcp drm_display_helper snd_pcm sha512_ssse3 intel_rapl_msr evdev sha256_ssse3 sha1_ssse3 aesni_intel snd_timer ucsi_acpi cec typec_ucsi snd gf128mul mei_me crypto_simd wdat_wdt ttm cryptd intel_cstate processor_thermal_device_pci_legacy typec ee1004 mei watchdog wmi_bmof processor_thermal_device soundcore pcspkr processor_thermal_wt_hint roles drm_kms_helper processor_thermal_rfim ir_rc6_decoder processor_thermal_rapl intel_rapl_common intel_pmc_core intel_ipu6 rc_rc6_mce ene_ir processor_thermal_wt_req processor_thermal_power_floor rc_core intel_vsec processor_thermal_mbox pmt_telemetry int340x_thermal_zone ipu_bridge pmt_class button i2c_algo_bit intel_soc_dts_iosf acpi_tad acpi_pad spl(OE) sg hailo_pci(OE) i2c_dev coretemp
[442539.846769] 8021q garp stp mrp llc macvlan drm drbd lru_cache dm_crypt nf_tables dm_mod loop nfnetlink efi_pstore configfs ip_tables x_tables autofs4 ext4 crc16 mbcache jbd2 btrfs blake2b_generic efivarfs raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c crc32c_generic raid0 raid1 md_mod sd_mod mmc_block ahci sdhci_pci libahci cqhci libata sdhci xhci_pci scsi_mod mmc_core xhci_hcd nvme usbcore nvme_core crc32_pclmul igc i2c_i801 i2c_smbus crc32c_intel nvme_auth fan usb_common video scsi_common wmi pinctrl_jasperlake
[442539.846817] CPU: 0 UID: 0 PID: 4164123 Comm: frigate.detecto Tainted: P W OE 6.12.22+bpo-amd64 #1 Debian 6.12.22-1~bpo12+1
[442539.846821] Tainted: [P]=PROPRIETARY_MODULE, [W]=WARN, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[442539.846822] Hardware name: Default string Default string/Default string, BIOS Q07RAR08 05/31/2023
[442539.846824] RIP: 0010:find_vma+0x59/0x70
[442539.846828] Code: c7 40 48 c7 c2 ff ff ff ff 48 89 e6 e8 a0 1e 91 00 48 8b 54 24 08 65 48 2b 14 25 28 00 00 00 75 0d 48 83 c4 10 c3 cc cc cc cc <0f> 0b eb d0 e8 ce 34 93 00 66 66 2e 0f 1f 84 00 00 00 00 00 0f 1f
[442539.846831] RSP: 0018:ffffa5f207af7c48 EFLAGS: 00010246
[442539.846833] RAX: 0000000000000000 RBX: ffff97bd2d7b8b80 RCX: 0000000000000000
[442539.846835] RDX: 0000000000000000 RSI: 00007f0f7f609000 RDI: ffff97bf3a10a680
[442539.846836] RBP: ffffa5f207af7cd8 R08: 0000000000000080 R09: 0000000000000000
[442539.846837] R10: ffffa5f207af7c60 R11: 0000000000000000 R12: 00007f0f7f609000
[442539.846839] R13: ffff97bd018990c8 R14: 0000000000000000 R15: 0000000000000000
[442539.846840] FS: 00007f0f837fe6c0(0000) GS:ffff97c070000000(0000) knlGS:0000000000000000
[442539.846842] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[442539.846844] CR2: 000055ab9b8e4398 CR3: 000000013ce16000 CR4: 0000000000352ef0
[442539.846846] Call Trace:
[442539.846848]
[442539.846852] ? __warn+0x89/0x130
[442539.846857] ? find_vma+0x59/0x70
[442539.846860] ? report_bug+0x164/0x190
[442539.846865] ? handle_bug+0x58/0x90
[442539.846868] ? exc_invalid_op+0x17/0x70
[442539.846870] ? asm_exc_invalid_op+0x1a/0x20
[442539.846876] ? find_vma+0x59/0x70
[442539.846880] hailo_vdma_buffer_map+0x167/0x7f0 [hailo_pci]
[442539.846888] hailo_vdma_buffer_map_ioctl+0xbd/0x270 [hailo_pci]
[442539.846894] hailo_pcie_fops_unlockedioctl+0x1d6/0x6f0 [hailo_pci]
[442539.846900] __x64_sys_ioctl+0x91/0xd0
[442539.846905] do_syscall_64+0x82/0x190
[442539.846907] ? sched_clock+0x10/0x30
[442539.846910] ? sched_clock_cpu+0xf/0x190
[442539.846914] ? psi_group_change+0x129/0x360
[442539.846916] ? finish_task_switch.isra.0+0x88/0x2d0
[442539.846919] ? __rseq_handle_notify_resume+0xa4/0x4f0
[442539.846923] ? __schedule+0x503/0xbf0
[442539.846926] ? restore_fpregs_from_fpstate+0x3c/0xa0
[442539.846929] ? switch_fpu_return+0x4f/0xd0
[442539.846932] ? clear_bhb_loop+0x25/0x80
[442539.846934] ? clear_bhb_loop+0x25/0x80
[442539.846936] ? clear_bhb_loop+0x25/0x80
[442539.846938] entry_SYSCALL_64_after_hwframe+0x76/0x7e
[442539.846941] RIP: 0033:0x7f0fb8b30d1b
[442539.846943] Code: 00 48 89 44 24 18 31 c0 48 8d 44 24 60 c7 04 24 10 00 00 00 48 89 44 24 08 48 8d 44 24 20 48 89 44 24 10 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1c 48 8b 44 24 18 64 48 2b 04 25 28 00 00
[442539.846945] RSP: 002b:00007f0f837fc550 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[442539.846948] RAX: ffffffffffffffda RBX: 00007f0f837fc850 RCX: 00007f0fb8b30d1b
[442539.846949] RDX: 00007f0f837fc600 RSI: 00000000c0287604 RDI: 000000000000003f
[442539.846950] RBP: 00000000159d6e90 R08: 0000000000000001 R09: 0000000000000000
[442539.846951] R10: 00000000159d6f70 R11: 0000000000000246 R12: 00000000159d6f20
[442539.846953] R13: 0000000000000001 R14: 00000000159d6e90 R15: 00000000159d6f48
[442539.846955]
[442539.846956] —[ end trace 0000000000000000 ]—
Hey @pat_ko ,
Can you go down to kernel 6.12.20 and re try this ?
Hello. Its quite critical private storage and I can find in the repo only 6.12.22 and 6.12.12 but second one have a critical CVEs. If you like I can add to the module debugs. I have already tested module and it looks like sophisticated problem with DMA or mapped memory to /dev/zero.
My currents debugs:
          dev_dbg(dev, "hailo_vdma_buffer_map: user_address=0x%lx\n", user_address);
>         dev_dbg(dev, "current->mm = %p\n", current->mm);
>         dev_dbg(dev, "user_address = 0x%lx\n", user_address);
>         dev_dbg(dev, "vma flags: 0x%lx\n", vma->vm_flags);
>         if (!current->mm) {
>             dev_err(dev, "current->mm is NULL\n");
>             ret = -EFAULT;
>             goto cleanup;
>         vma = find_vma(current->mm, user_address);
>         dev_dbg(dev, "hailo_vdma_buffer_map: vma=%p\n", vma);
>         //if (IS_ENABLED(HAILO_SUPPORT_MMIO_DMA_MAPPING)) {
>         if (!vma) {
>             dev_err(dev, "no vma found for user_address=0x%lx\n", user_address);
>             ret = -EFAULT;
>             goto cleanup;
maps from debugs:
 cat /proc/416981/maps | grep 7f1ddc002000
7f1ddc001000-7f1ddc002000 rw-s 00000000 00:63 269                        /dev/shm/out-taras1
7f1ddc002000-7f1ddc00c000 rw-s 00000000 00:01 4077948                    /dev/zero (deleted)
And in the makefile I can see
ifeq ($(shell (test $(VERSION) -ge 6 && test $(PATCHLEVEL) -ge 9) && echo 1 || echo 0), 0)
# MMIO_DMA_MAPPING is not supported on kernels above 6.9 (since follow_pfn was removed).
ccflags-y      += -DHAILO_SUPPORT_MMIO_DMA_MAPPING
endif
best regards,
Hey @pat_ko,
Thanks for the info!
We’re currently working on a solution for the kernel issue. I’ll update you once we have a fix ready or at least a timeline for when it should be resolved.
Can you downgrade to 6.11 or 6.6 ?
The kernel panic with the same exact stack trace got occurred on the 6.12.17 as well. 6.12.17-ti, Texas Instrument’s forked version of the 6.12.17 Kernel to be exact. Since my company has been implementing several custom drivers with the Kernel in question, I’m afraid downgrading to 6.11 or 6.6 would not be an option for us.
Is there any specific timeline for the fix? (or on going status of the issue?)
I’m guessing this is dead in the water, it’s been a year since this was reported and there has been no movement.
Pretty poor show if you ask me.
