david
July 25, 2024, 6:33pm
In the VM I’ve got this far:
avid@ai:~$ ai/hailort/build/hailort/hailortcli/hailortcli scan
Hailo Devices:
[-] Device: 0000:06:00.0
and
[ 1.837209] hailo_pci: loading out-of-tree module taints kernel.
[ 1.838390] hailo_pci: module verification failed: signature and/or required key missing - tainting kernel
[ 1.841062] hailo: Init module. driver version 4.18.0
[ 1.841436] hailo 0000:06:00.0: Probing on: 1e60:2864...
[ 1.841853] hailo 0000:06:00.0: Probing: Allocate memory for device extension, 11632
[ 1.841951] input: PC Speaker as /devices/platform/pcspkr/input/input5
[ 1.842689] hailo 0000:06:00.0: Probing: Device enabled
[ 1.843907] hailo 0000:06:00.0: Probing: mapped bar 0 - 0000000058cf8fd0 16384
[ 1.844483] hailo 0000:06:00.0: Probing: mapped bar 2 - 00000000fe068ad9 4096
[ 1.844970] hailo 0000:06:00.0: Probing: mapped bar 4 - 00000000b7f8f4c0 16384
[ 1.845488] hailo 0000:06:00.0: Probing: Setting max_desc_page_size to 4096, (page_size=4096)
[ 1.846087] hailo 0000:06:00.0: Probing: Enabled 64 bit dma
[ 1.846468] hailo 0000:06:00.0: Probing: Using userspace allocated vdma buffers
[ 1.846999] hailo 0000:06:00.0: Disabling ASPM L0s
[ 1.847467] hailo 0000:06:00.0: Successfully disabled ASPM L0s
[ 1.847971] ACPI: button: Power Button [PWRF]
[ 1.866410] hailo 0000:06:00.0: firmware: failed to load hailo/hailo8_board_cfg.bin (-2)
[ 1.867158] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[ 1.868002] hailo 0000:06:00.0: firmware: failed to load hailo/hailo8_board_cfg.bin (-2)
[ 1.868743] hailo 0000:06:00.0: firmware: failed to load hailo/hailo8_fw_cfg.bin (-2)
[ 1.869350] hailo 0000:06:00.0: firmware: failed to load hailo/hailo8_fw_cfg.bin (-2)
[ 1.870220] hailo 0000:06:00.0: firmware: direct-loading firmware hailo/hailo8_fw.bin
So it’s not too far off.
doing a hailortcli fw-control identify hangs the VM.
I’m using libvirt/kvm with:
<devices>
<hostdev mode='subsystem' type='pci' managed='yes'>
<source>
<address domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
</source>
<address type='pci' domain='0x0000' bus='0x06' slot='0x00' function='0x0'/>
</hostdev>
</devices>
The VM starts eventually but I’m getting
[ 2348.723797] vfio-pci 0000:01:00.0: enabling device (0000 -> 0002)
[ 2350.067410] vfio-pci 0000:01:00.0: not ready 1023ms after FLR; waiting
[ 2351.123236] vfio-pci 0000:01:00.0: not ready 2047ms after FLR; waiting
[ 2353.266993] vfio-pci 0000:01:00.0: not ready 4095ms after FLR; waiting
[ 2357.618647] vfio-pci 0000:01:00.0: not ready 8191ms after FLR; waiting
[ 2366.065970] vfio-pci 0000:01:00.0: not ready 16383ms after FLR; waiting
[ 2382.704794] vfio-pci 0000:01:00.0: not ready 32767ms after FLR; waiting
david
July 26, 2024, 4:21pm
I snipped the guest dmesg a bit much. It also has:
[ 2.179770] hailo 0000:06:00.0: Firmware was loaded successfully
[ 2.226824] hailo 0000:06:00.0: Probing: Added board 1e60-2864, /dev/hailo0
So the kernel is seeing the device clearly enough in the guest for the driver module to be happy.
And the vfio-pci issues are (obviously?) in the host.
david
July 26, 2024, 4:44pm
3
so on the host
in the amd docs website under /r/en-US/pg302-qdma/Function-Level-Reset
(no links!!)
it says that
echo 1 > /sys/bus/pci/devices/$BDF/reset
Will do an FLR
If I rmmod all the vfio (and if I reboot) and try this with a “journalctl -f &” running, I get:
root@elm2:~# echo 1 > /sys/bus/pci/devices/0000\:01\:00.0/reset
Jul 26 17:37:38 elm2 kernel: pci 0000:01:00.0: not ready 1023ms after FLR; waiting
Jul 26 17:37:39 elm2 kernel: pci 0000:01:00.0: not ready 2047ms after FLR; waiting
Jul 26 17:37:41 elm2 kernel: pci 0000:01:00.0: not ready 4095ms after FLR; waiting
Jul 26 17:37:46 elm2 kernel: pci 0000:01:00.0: not ready 8191ms after FLR; waiting
Jul 26 17:37:54 elm2 kernel: pci 0000:01:00.0: not ready 16383ms after FLR; waiting
Jul 26 17:38:11 elm2 kernel: pci 0000:01:00.0: not ready 32767ms after FLR; waiting
root@elm2:~# Jul 26 17:38:46 elm2 kernel: pci 0000:01:00.0: not ready 65535ms after FLR; giving up
Is this a bug in the PCI handling of the device/firmware?
KlausK
July 26, 2024, 11:33pm
4
We do not validate HailoRT with VMs. You may be able to get this to work or it may fail.
Out of curiosity, can you share some details about your application and why you want to use a VM?
david
July 27, 2024, 12:48pm
5
Hey @KlausK
That last post was bare metal. I wanted to see if the board supported FLR there. It doesn’t. Hopefully that’s a bug
The application is in natural language speech intention analysis for automation systems - early days at the moment.
My goal is to deploy a development VM on my main VM server. It’s a Debian 12 box with a number of dev VMs on it under KVM.
The PCI passthrough should ‘just work’ and is great for GPUs.
I understand this isn’t a supported setup but it would be very useful to get it working so I’d appreciate any help that I can get!
KlausK
August 8, 2024, 12:41am
6
Since that does not seem to be the case for the Hailo-8 right now, I suspect it required some engineers to develop this capability for GPUs.
I understand that. I am not sure how I can assist you further.
Hi David,
I was wondering if there have been any new developments regarding accessing Hailo 8 on a KVM VM? I’m also looking to achieve VM access to Hailo 8 resources and would appreciate any insights or updates you may have. Thanks!"
yanivb
January 23, 2025, 1:18pm
9
Hi @yangyang.shen and @david ,
In our latest hailort release (4.20) we have added and fixed some issues which will ease your way to utilize the Hailo8 with KVM and PCI passthrough.
After running through all stages of applying the PCI passthrough
please run this cmd to clear the Hailo-8 reset mode to null, this command will prevent the system from freezing when a guest VM is started.
This action must be done at every boot of the host machine. This can be done by creating/editing the /etc/rc.local script on the host and adding the following lines to it:
#!/bin/bash
lspci -D | grep -E "Co-processor: Device 1e60:2864 \(rev 01\)|Hailo" | awk '{print $1}' | while read -r device; do
echo | sudo tee /sys/bus/pci/devices/$device/reset_method
done
please note that the hailort driver should be installed on the VM itself.
we will shortly post a full guide how to enable virtual machine
to access Hailo-8 devices, i’ll update with the relevant link was done.
Yaniv
yanivb
January 23, 2025, 2:12pm
10
Hi yanivb,
Thank you for your reply. I’m glad to hear that there is a new update for VM support.
david
January 26, 2025, 4:57pm
12
@yanivb Thanks for this!
Inside my VM:
david@ai:~$ hailortcli fw-control identify
Executing on device: 0000:06:00.0
Identifying board
Control Protocol Version: 2
Logger Version: 0
Board Name: Hailo-8
Device Architecture: HAILO8
Serial Number: ###########
Part Number: HM218B1C2LAE
Product Name: HAILO-8 AI ACC M.2 B+M KEY MODULE EXT TEMP
