Whenever I build my first tutorial library for Tappas following the directions I get the error below. I have tried several things such as moving the library to my home directory and ensuring proper permissions. I have not had any luck. I will paste my code for the meson.build and my cpp and hpp files below as well. Does anyone know why I have a successful build with no errors but my computer can’t seem to find the library even when providing an absolute path?
I am following the Tappas tutorial using the AI Software Suite Docker
version hailo_ai_sw_suite_2024-07.
error:
gst-launch-1.0 videotestsrc ! hailofilter so-path=libtutorial_post.so ! fakesink
Setting pipeline to PAUSED ...
Could not load lib libtutorial_post.so: cannot open shared object file: No such file or directory
Cannot load symbol: /opt/hailo/tappas/lib/x86_64-linux-gnu/gstreamer-1.0/libgsthailotools.so: undefined symbol: filter
Caught SIGSEGV
exec gdb failed: No such file or directory
meson.build in the postprocess directory (only my section):
# DETECTION SOURCES - Tutorial
tutorial_sources = [
'detection/tutorial.cpp',
shared_library('tutorial_post',
tutorial_sources,
include_directories: [hailo_general_inc] + xtensor_inc,
dependencies : post_deps,
gnu_symbol_visibility : 'default',
install: true,
install_dir: post_proc_install_dir,
tutorial.hpp
#ifndef TAPPAS_TUTORIAL_HPP
#define TAPPAS_TUTORIAL_HPP
#endif //TAPPAS_TUTORIAL_HPP
#pragma once
#include "hailo_objects.hpp"
#include "hailo_common.hpp"
__BEGIN_DECLS
void filter(HailoROIPtr roi);
__END_DECLS
tutorial.cpp:
#include <iostream>
#include "tutorial.hpp"
// Default filter function
std::cout << "My first postprocess!" << std::endl;
