PCIe driver
This needs to be installed on the host. The deb of driver v4.18.0 does not install due to an error. The same error appears when compiling from source. A PR to fix the problem has been filed on Github: Add missing function definition by jpm-canonical · Pull Request #17 · hailo-ai/hailort-drivers · GitHub
After fixing this bug I can successfully build and install the driver on the host.
rpi5-host:~$ sudo dmesg | grep hailo
[ 4.429982] hailo_pci: loading out-of-tree module taints kernel.
[ 4.429993] hailo_pci: module verification failed: signature and/or required key missing - tainting kernel
[ 4.430683] hailo: Init module. driver version 4.18.0
[ 4.430786] hailo 0000:01:00.0: Probing on: 1e60:2864...
[ 4.430790] hailo 0000:01:00.0: Probing: Allocate memory for device extension, 11632
[ 4.430799] hailo 0000:01:00.0: enabling device (0000 -> 0002)
[ 4.430805] hailo 0000:01:00.0: Probing: Device enabled
[ 4.430822] hailo 0000:01:00.0: Probing: mapped bar 0 - 000000006d6c1c9a 16384
[ 4.430828] hailo 0000:01:00.0: Probing: mapped bar 2 - 00000000f1fb8d64 4096
[ 4.430833] hailo 0000:01:00.0: Probing: mapped bar 4 - 00000000c1d6a005 16384
[ 4.430837] hailo 0000:01:00.0: Probing: Setting max_desc_page_size to 4096, (page_size=4096)
[ 4.430846] hailo 0000:01:00.0: Probing: Enabled 64 bit dma
[ 4.430848] hailo 0000:01:00.0: Probing: Using userspace allocated vdma buffers
[ 4.430852] hailo 0000:01:00.0: Disabling ASPM L0s
[ 4.430856] hailo 0000:01:00.0: Successfully disabled ASPM L0s
[ 4.456118] UBSAN: array-index-out-of-bounds in /home/jpmeijers/hailort-drivers/linux/pcie/../../common/pcie_common.c:471:53
[ 4.456151] hailo_write_app_firmware+0x10c/0x118 [hailo_pci]
[ 4.456167] hailo_pcie_write_firmware+0x6c/0x168 [hailo_pci]
[ 4.456176] hailo_pcie_probe+0xbb4/0xf70 [hailo_pci]
[ 4.456216] hailo_pcie_module_init+0x98/0xff8 [hailo_pci]
[ 4.628650] hailo 0000:01:00.0: Firmware was loaded successfully
[ 4.707141] hailo 0000:01:00.0: Probing: Added board 1e60-2864, /dev/hailo0
HailoRT on the Host
Clone, build, install:
rpi5-host:~$ git clone https://github.com/hailo-ai/hailort.git
Cloning into 'hailort'...
rpi5-host:~$ cd hailort
rpi5-host:~/hailort$ git describe --exact-match --tags
v4.18.0
rpi5-host:~/hailort$ cmake -S. -Bbuild -DCMAKE_BUILD_TYPE=Release -DHAILO_BUILD_EXAMPLES=1 && sudo cmake --build build --config release --target install
Testing:
rpi5-host:~/hailort$ hailortcli --version
HailoRT-CLI version 4.18.0
rpi5-host:~/hailort$ hailortcli fw-control identify
Identifying board
Control Protocol Version: 2
Firmware Version: 4.18.0 (release,app,extended context switch buffer)
Logger Version: 0
Board Name: Hailo-8
Device Architecture: HAILO8L
Serial Number: HLDDLBB241602838
Part Number: HM21LB1C2LAE
Forwarding hardware to Docker container
The PCIe hardware can be forwarded to the Docker container with volume mounts. This was done here: pi-ai-kit-ubuntu/docker-compose.yaml at 8f3f0dcf09ba52e8bedebec1136b8887ce6c7207 · canonical/pi-ai-kit-ubuntu · GitHub
Build the container and attach to shell
rpi5-host:~/docker-hailo$ docker compose build
rpi5-host:~/docker-hailo$ docker compose up -d
[+] Running 1/1
✔ Container docker-hailo-hailo-1 Started 0.6s
rpi5-host:~/docker-hailo$ docker compose exec hailo /bin/bash
root@container:~#
HailoRT in the container
HailoRT is cloned, built and installed during building of the container. We start the container and test hailortcli:
root@container:~# hailortcli --version
root@container:~# hailortcli fw-control identify
Identifying board
Logger Version: 0
Board Name: Hailo-8
Building TAPPAS inside container
root@container:~# cd tappas/
root@container:~/tappas/# ./install.sh --skip-hailort --target-platform rpi
[15/15] Linking target tools/gst-report-1.0
ninja: Entering directory `build'
[0/1] Installing files.
Installing libs/gst/intercept/libgstintercept.so to /opt/hailo/tappas/lib/aarch64-linux-gnu
Installing plugins/tracers/libgstinstruments.so to /opt/hailo/tappas/lib/aarch64-linux-gnu/gstreamer-1.0
Installing tools/gst-top-1.0 to /opt/hailo/tappas/bin
Installing tools/gst-report-1.0 to /opt/hailo/tappas/bin
Installing /root/tappas/sources/gst-instruments/data/pull.svg to /opt/hailo/tappas/share/gst-instruments
Installing /root/tappas/sources/gst-instruments/data/push.svg to /opt/hailo/tappas/share/gst-instruments
~/tappas/sources ~/tappas
~/tappas
ldd: /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgsthailo.so: No such file or directory
ls: cannot access '/usr/lib/libhailort.so': No such file or directory
Full log here.
We can see building TAPPAS inside the container fails (while building libgsthailo.so), because it can’ find libhailort.so
But we can check and see libhailort.so is installed and available, but at a different path than where TAPPAS is looking.
root@container:~/tappas# whereis libhailort.so
libhailort.so: /usr/local/lib/libhailort.so
Manually copying libhailort to the other location:
root@container:~/tappas# cp /usr/local/lib/libhailort.so /usr/lib/
root@container:~/tappas# ls /usr/lib/libhailort.so
Trying to compile again.
root@container:~/tappas# ./install.sh --skip-hailort --target-platform rpi
-- Build files have been written to: /root/tappas/hailort/sources/hailort/libhailort/bindings/gstreamer/build
[ 7%] Building CXX object CMakeFiles/gsthailo.dir/gst-hailo/gsthailoplugin.cpp.o
In file included from /root/tappas/hailort/sources/hailort/libhailort/bindings/gstreamer/gst-hailo/gsthailonet.hpp:34,
from /root/tappas/hailort/sources/hailort/libhailort/bindings/gstreamer/gst-hailo/gsthailoplugin.cpp:23:
/root/tappas/hailort/sources/hailort/libhailort/bindings/gstreamer/gst-hailo/gsthailo_dmabuf_allocator.hpp:24:10: fatal error: hailo/hailort_dma-heap.h: No such file or directory
24 | #include "hailo/hailort_dma-heap.h"
compilation terminated.
gmake[2]: *** [CMakeFiles/gsthailo.dir/build.make:76: CMakeFiles/gsthailo.dir/gst-hailo/gsthailoplugin.cpp.o] Error 1
gmake[1]: *** [CMakeFiles/Makefile2:83: CMakeFiles/gsthailo.dir/all] Error 2
gmake: *** [Makefile:136: all] Error 2
Again a compile error. This time around I do not know how to fix it.
