Running on Error "Missing Key Network"
Hi, when trying to compile my onnx Model, I ran into the folowing Error. Can anyone help please. Regards
(hailo_virtualenv) hailo@imm-virtual-machine:/local/shared_with_docker/doc$ hailomz compile --ckpt yolov8n.onnx --calib-path ./calibration_images/ --yaml yolov8.yaml
File “/local/workspace/hailo_virtualenv/bin/hailomz”, line 33, in
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py”, line 122, in main
run(args)
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py”, line 111, in run
return handlersargs.command
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py”, line 244, in compile
model_name = network_info.network.network_name
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/omegaconf/dictconfig.py”, line 355, in getattr
self._format_and_raise(
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/omegaconf/base.py”, line 231, in _format_and_raise
format_and_raise(
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/omegaconf/_utils.py”, line 899, in format_and_raise
_raise(ex, cause)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/omegaconf/_utils.py”, line 797, in _raise
raise ex.with_traceback(sys.exc_info()[2]) # set env var OC_CAUSE=1 for full trace
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/omegaconf/dictconfig.py”, line 351, in getattr
return self._get_impl(
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/omegaconf/dictconfig.py”, line 442, in _get_impl
node = self._get_child(
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/omegaconf/basecontainer.py”, line 73, in _get_child
child = self._get_node(
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/omegaconf/dictconfig.py”, line 480, in _get_node
raise ConfigKeyError(f"Missing key {key!s}")
omegaconf.errors.ConfigAttributeError: Missing key network
full_key: network
object_type=dict
Hey @schmitz.jochen ,
The error “Missing Key Network” indicates that the yolov8.yaml file is missing a required network key or its definition.
Can you provide more info on the yaml that you are using ?
