First time using the Hailo AI Kit so I’m really excited (and dumb).
So the problem is that I was trying to compile a face detection .onnx into a .hef file using the 4.21.0 SDK I installed on my WSL (Docker version).
This was the command I ran:
hailomz compile yolov8s --ckpt=/local/workspace/yolov8_special.onnx --hw-arch hailo8l --classes 2 --performance --calib-path /local/workspace/calib
After that, things went really really well until this error pops up:
File “/local/workspace/hailo_virtualenv/bin/hailomz”, line 33, in
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py”, line 122, in main
run(args)
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py”, line 111, in run
return handlersargs.command
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py”, line 248, in compile
ensure_optimized(runner, logger, args, network_info)
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py”, line 91, in ensure_optimized
optimize_model(
File “/local/workspace/hailo_model_zoo/hailo_model_zoo/core/main_utils.py”, line 353, in optimize_model
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py”, line 2201, in optimize
result = self.optimize(
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py”, line 2020, in optimize
checkpoint_info = self.sdk_backend.full_quantization(
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1196, in full_quantization
new_checkpoint_info = self.full_acceleras_run(
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1434, in full_acceleras_run
new_checkpoint_info = self.optimization_flow_runner(optimization_flow, checkpoint_info)
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 2088, in optimization_flow_runner
optimization_flow.run()
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/tools/orchestator.py”, line 239, in wrapper
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 357, in run
step_func()
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/tools/subprocess_wrapper.py”, line 154, in parent_wrapper
self.build_model()
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 260, in build_model
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/acceleras/model/hailo_model/hailo_model.py”, line 1153, in compute_output_shape
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/acceleras/model/hailo_model/hailo_model.py”, line 1187, in compute_and_verify_output_shape
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/keras/engine/base_layer.py”, line 917, in compute_output_shape
File “/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/keras/utils/traceback_utils.py”, line 70, in error_handler
File "/tmp/autograph_generated_file71l3aryh.py", line 41, in tf__call
outputs = ag.converted_call(ag.ld(self).call_core, (ag.ld(inputs), ag.ld(training)), dict(**ag.ld(kwargs)), fscope)
File "/tmp/autograph_generated_file7e60k_i0.py", line 90, in tf__call_core
ag.if_stmt(ag_.ld(self).postprocess_type in [ag__.ld(PostprocessType).NMS, ag__.ld(PostprocessType).BBOX_DECODER], if_body_3, else_body_3, get_state_3, set_state_3, (‘do_return’, ‘retval_’), 2)
File "/tmp/autograph_generated_file7e60k_i0.py", line 22, in if_body_3
retval = ag_.converted_call(ag__.ld(self).bbox_decoding_and_nms_call, (ag__.ld(inputs),), dict(is_bbox_decoding_only=ag__.ld(self).postprocess_type == ag__.ld(PostprocessType).BBOX_DECODER), fscope)
File "/tmp/autograph_generated_filey10zt0kk.py", line 116, in tf__bbox_decoding_and_nms_call
ag.if_stmt(ag__.ld(self).meta_arch in [ag__.ld(NMSOnCpuMetaArchitectures).YOLOV5, ag__.ld(NMSOnCpuMetaArchitectures).YOLOX], if_body_5, else_body_5, get_state_5, set_state_5, (‘decoded_bboxes’, ‘detection_score’, ‘do_return’, ‘retval_’, ‘inputs’), 4)
File "/tmp/autograph_generated_filey10zt0kk.py", line 113, in else_body_5
ag.if_stmt(ag__.ld(self).meta_arch == ag__.ld(NMSOnCpuMetaArchitectures).YOLOV5_SEG, if_body_4, else_body_4, get_state_4, set_state_4, (‘decoded_bboxes’, ‘detection_score’, ‘do_return’, ‘retval_’), 4)
File "/tmp/autograph_generated_filey10zt0kk.py", line 110, in else_body_4
ag.if_stmt(ag__.ld(self).meta_arch == ag__.ld(NMSOnCpuMetaArchitectures).YOLOV8, if_body_3, else_body_3, get_state_3, set_state_3, (‘decoded_bboxes’, ‘detection_score’), 2)
File "/tmp/autograph_generated_filey10zt0kk.py", line 69, in if_body_3
(decoded_bboxes, detection_score) = ag.converted_call(ag__.ld(self).yolov8_decoding_call, (ag__.ld(inputs),), dict(offsets=[0.5, 0.5]), fscope)
File "/tmp/autograph_generated_filezvw0788s.py", line 87, in tf__yolov8_decoding_call
decoded_bboxes = ag.converted_call(ag__.ld(tf).expand_dims, (ag__.ld(decoded_bboxes),), dict(axis=2), fscope)
ValueError: Exception encountered when calling layer “yolov8_nms_postprocess” (type HailoPostprocess).in user code:
File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/acceleras/hailo_layers/base_hailo_none_nn_core_layer.py", line 45, in call * outputs = self.call_core(inputs, training, **kwargs) File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/acceleras/hailo_layers/hailo_postprocess.py", line 123, in call_core * is_bbox_decoding_only=self.postprocess_type == PostprocessType.BBOX_DECODER, File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/acceleras/hailo_layers/hailo_postprocess.py", line 157, in bbox_decoding_and_nms_call * decoded_bboxes, detection_score = self.yolov8_decoding_call(inputs, offsets=[0.5, 0.5]) File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/acceleras/hailo_layers/hailo_postprocess.py", line 375, in yolov8_decoding_call * decoded_bboxes = tf.expand_dims(decoded_bboxes, axis=2) ValueError: Tried to convert 'input' to a tensor and failed. Error: None values not supported.Call arguments received by layer “yolov8_nms_postprocess” (type HailoPostprocess):
• inputs=[‘tf.Tensor(shape=(None, 80, 80, 64), dtype=float32)’, ‘tf.Tensor(shape=(None, 80, 80, 1), dtype=float32)’, ‘tf.Tensor(shape=(None, 40, 40, 64), dtype=float32)’, ‘tf.Tensor(shape=(None, 40, 40, 1), dtype=float32)’, ‘tf.Tensor(shape=(None, 20, 20, 64), dtype=float32)’, ‘tf.Tensor(shape=(None, 20, 20, 1), dtype=float32)’]
• training=False
• kwargs=<class ‘inspect._empty’>
I’d greatly appreciate it if anyone could provide guidance or help on this problem.
