I have installed hailort-4.21.0-cp310-cp310-linux_x86_64.whl, .deb + hailo-model-zoo-2.15.0 from cloned git repo.
I’m using Python 3.10.12.
Hailo Model Zoo INFO> Start run for network yolov8n ...
[info] Restored ONNX model yolov8n (completion time: 00:00:00.03)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.15)
[info] Start nodes mapped from original model: 'images': 'yolov8n/input_layer1'.
[info] End nodes mapped from original model: '/model.22/cv2.0/cv2.0.2/Conv', '/model.22/cv3.0/cv3.0.2/Conv', '/model.22/cv2.1/cv2.1.2/Conv', '/model.22/cv3.1/cv3.1.2/Conv', '/model.22/cv2.2/cv2.2.2/Conv', '/model.22/cv3.2/cv3.2.2/Conv'.
[info] Translation completed on ONNX model yolov8n (completion time: 00:00:00.40)
  File "/home/user1/Lalit/ek/export_hailo/hailo_model_zoo/exp_hailo/bin/hailomz", line 33, in <module>
  File "/home/user1/Lalit/ek/export_hailo/hailo_model_zoo/hailo_model_zoo/main.py", line 122, in main
    run(args)
  File "/home/user1/Lalit/ek/export_hailo/hailo_model_zoo/hailo_model_zoo/main.py", line 111, in run
  File "/home/user1/Lalit/ek/export_hailo/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 248, in compile
  File "/home/user1/Lalit/ek/export_hailo/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 73, in _ensure_optimized
  File "/home/user1/Lalit/ek/export_hailo/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 108, in _ensure_parsed
  File "/home/user1/Lalit/ek/export_hailo/hailo_model_zoo/hailo_model_zoo/core/main_utils.py", line 148, in parse_model
    runner.save_har(results_dir / f"{network_info.network.network_name}.har")
  File "/home/user1/Lalit/ek/export_hailo/hailo_model_zoo/exp_hailo/lib/python3.10/site-packages/hailo_sdk_common/states/states.py", line 13, in wrapped_func
    raise InvalidStateException(
hailo_sdk_common.states.states.InvalidStateException: The execution of save_har is not available under the state: uninitialized
command used :
hailomz compile yolov8n \
    --ckpt best.onnx \
    --calib-path "/media/user1/Local storage 10/data/ek/v0_lp_dataset/images/train/" \
    --hw-arch hailo8l \
    --end-node-names /model.22/cv2.0/cv2.0.2/Conv /model.22/cv3.0/cv3.0.2/Conv /model.22/cv2.1/cv2.1.2/Conv /model.22/cv3.1/cv3.1.2/Conv /model.22/cv2.2/cv2.2.2/Conv /model.22/cv3.2/cv3.2.2/Conv
another run:
(exp_hailo) user1@dell-X670E-AORUS-MASTER:~/Lalit/ek/export_hailo/hailo_model_zoo$ hailomz compile yolov8n --ckpt best.onnx --calib-path "/media/user1/Local storage 10/data/ek/v0_lp_dataset/images/train/" --hw-arch hailo8l
<Hailo Model Zoo INFO> Start run for network yolov8n ...
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.12)
[info] Simplified ONNX model for a parsing retry attempt (completion time: 00:00:00.34)
[info] According to recommendations, retrying parsing with end node names: ['/model.22/Concat_3'].
[info] Restored ONNX model yolov8n (completion time: 00:00:00.02)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.09)
[info] End nodes mapped from original model: '/model.22/Concat_3'.
[info] Translation completed on ONNX model yolov8n (completion time: 00:00:00.38)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.11)
    run(args)
