Hello!
I’ve been trying for over two weeks now to use a Raspberry PI 5 with Hailo8l to process multiple RTSP streams and then send a message to an MQTT broker. It should then receive something like “house/{camera name}/{person, face}” and create an image every x seconds to send to MQTT to see if the recognition works.
It just doesn’t work… I’m using Home Assistant on an N100 via ProxMox, and I’m really desperate. I’ve been thinking for a long time about whether I want to bother you with this, but unfortunately, neither ChatGPT, Gemini, nor Claude.ai can help me with my problem. They all provide completely bloated scripts that ultimately require new corrections, which then lead to another correction.
I’ve already tried Frigate, but unfortunately, it just doesn’t mount Hailo8 successfully. So it reverts to the CPU, and the Rasp5 starts whining!
Thank you in advance for any help you can give me!
Best regards from Germany
