I’m trying to convert my Seformer model, which I have trained. After simplification of the ONNX file and a few modifications, I have got the following error:
NetworkXUnfeasible: Graph contains a cycle or graph changed during iteration
Execution code:
runner = ClientRunner(hw_arch="hailo8")
onnx_path,
onnx_model_name,
start_node_names=INPUT_NODES_NAMES,
end_node_names=OUTPUT_NODES_NAMES,
net_input_shapes=INPUT_SHAPES,
Parameters:
INPUT_NODES_NAMES = ["input"]
OUTPUT_NODES_NAMES = ['Resize_2022']
INPUT_SHAPES = {'input': [1, 3, 800, 800]}
Could you give me any tips on where to look and what is wrong with the model, since I am stuck?
What is the convenient way to attach onnx file to the post?
Full error log:
1 runner = ClientRunner(hw_arch=chosen_hw_arch)
----> 2 hn, npz = runner.translate_onnx_model(
3 onnx_path,
4 onnx_model_name,
5 start_node_names=INPUT_NODES_NAMES,
6 end_node_names=OUTPUT_NODES_NAMES,
7 net_input_shapes=INPUT_SHAPES,
8 )
File ~/miniconda3/envs/hailo_env/lib/python3.10/site-packages/hailo_sdk_common/states/states.py:16, in allowed_states.<locals>.wrap.<locals>.wrapped_func(self, *args, **kwargs)
13 raise InvalidStateException(
14 f"The execution of {func.__name__} is not available under the state: {self._state.value}",
15 )
---> 16 return func(self, *args, **kwargs)
File ~/miniconda3/envs/hailo_env/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py:1187, in ClientRunner.translate_onnx_model(self, model, net_name, start_node_names, end_node_names, net_input_shapes, augmented_path, disable_shape_inference, disable_rt_metadata_extraction, net_input_format, **kwargs)
1144 """
1145 DFC API for parsing an ONNX model. This creates a runner with loaded HN (model) and
1146 parameters.
1184
1185 """
1186 parser = Parser()
-> 1187 parser.translate_onnx_model(
1188 model=model,
1189 net_name=net_name,
1190 start_node_names=start_node_names,
1191 end_node_names=end_node_names,
1192 net_input_shapes=net_input_shapes,
1193 augmented_path=augmented_path,
1194 disable_shape_inference=disable_shape_inference,
1195 disable_rt_metadata_extraction=disable_rt_metadata_extraction,
1196 net_input_format=net_input_format,
1197 **kwargs,
1198 )
1199 return self._finalize_parsing(parser.return_data)
File ~/miniconda3/envs/hailo_env/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py:262, in Parser.translate_onnx_model(self, model, net_name, start_node_names, end_node_names, net_input_shapes, augmented_path, disable_shape_inference, disable_rt_metadata_extraction, net_input_format, **kwargs)
260 except Exception:
261 self._logger.info(f"Unable to simplify the model: {e!s}")
--> 262 raise e from None
264 for node in simplified_model.graph.node:
265 if not node.name:
File ~/miniconda3/envs/hailo_env/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py:239, in Parser.translate_onnx_model(self, model, net_name, start_node_names, end_node_names, net_input_shapes, augmented_path, disable_shape_inference, disable_rt_metadata_extraction, net_input_format, **kwargs)
236 onnx.save_model(onnx_model, augmented_path)
238 try:
--> 239 parsing_results = self._parse_onnx_model_to_hn(
240 onnx_model=onnx_model,
241 net_name=valid_net_name,
242 start_node_names=start_node_names,
243 end_node_names=end_node_names,
244 net_input_shapes=net_input_shapes,
245 disable_shape_inference=disable_shape_inference,
246 net_input_format=net_input_format,
247 )
249 except Exception as e:
250 irrelevant_exception = isinstance(e, (MisspellNodeError, UnsupportedInputFormatError))
File ~/miniconda3/envs/hailo_env/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py:320, in Parser._parse_onnx_model_to_hn(self, onnx_model, net_name, start_node_names, end_node_names, net_input_shapes, disable_shape_inference, net_input_format, **kwargs)
317 except Exception as e:
318 self._logger.warning(f"ONNX shape inference failed: {e!s}")
--> 320 return self.parse_model_to_hn(
321 onnx_model,
322 None,
323 net_name,
324 start_node_names,
325 end_node_names,
326 nn_framework=NNFramework.ONNX,
327 output_shapes=output_shapes,
328 net_input_format=net_input_format,
329 **kwargs,
330 )
File ~/miniconda3/envs/hailo_env/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py:371, in Parser.parse_model_to_hn(self, model, values, net_name, start_node_names, end_node_names, nn_framework, output_shapes, net_input_format, rename_layers_by_blocks)
368 else:
369 raise BackendRuntimeException(f"Unsupported NN framework {nn_framework}")
--> 371 fuser = HailoNNFuser(converter.convert_model(), net_name, converter.end_node_names)
372 hailo_nn = fuser.convert_model()
373 hailo_nn.validate_stage(HnStage.HN)
File ~/miniconda3/envs/hailo_env/lib/python3.10/site-packages/hailo_sdk_client/model_translator/translator.py:85, in HailoNNConverter.convert_model(self)
83 self._create_layers()
84 self._add_layers_connections()
---> 85 self._layers_graph.set_names_and_indices()
86 self._update_input_indices()
87 self._update_output_indices()
File ~/miniconda3/envs/hailo_env/lib/python3.10/site-packages/hailo_sdk_common/hailo_nn/hailo_nn.py:849, in HailoNN.set_names_and_indices(self, force)
846 # we can't have a stable order easily without relying on indices. We try to rely on names
847 # and on insertion order
848 sort_key = "name" if all(layer.name is not None for layer in self.nodes()) else "insertion_order"
--> 849 for index, layer in enumerate(self.stable_toposort(key=sort_key)):
850 if layer.index != INDEX_NOT_SET:
851 old_index_to_layer[layer.index] = layer
File ~/miniconda3/envs/hailo_env/lib/python3.10/site-packages/networkx/algorithms/dag.py:434, in lexicographical_topological_sort(G, key)
432 if indegree_map:
433 msg = "Graph contains a cycle or graph changed during iteration"
--> 434 raise nx.NetworkXUnfeasible(msg)
