I noticed that if I insmod hailo_pcie.ko
when the accelerator is not connected, I don’t see any error.
root@board:~# insmod /lib/modules/6.1.36/kernel/drivers/misc/hailo_pci.ko
[ 79.092743] hailo: Init module. driver version 4.20.0
root@board:~# hailortcli scan
Hailo devices not found
I would expect insmod
to throw some errors given that the driver is useless without the hardware plugged in.
In the source code of the driver I see some prints that apparently don’t execute:
Note that I ported meta-hailo
on scarthgap and I’m using kernel 6.1.36.
I tested with some custom inference applications and everything works.
Is this the indentend behaviour?
Thanks
