Just updated my raspberry pi’s os version today and now my raspberry pi AI hat+ is no longer recognised when using
“hailortcli fw-control identify”
Instead getting error:
“[HailoRT] [error] Can’t find hailort driver class. Can happen if the driver is not installed, if the kernel was updated or on some driver failure (then read driver dmesg log)
[HailoRT] [error] CHECK_SUCCESS failed with status=HAILO_DRIVER_NOT_INSTALLED(64) - Failed listing hailo devices
[HailoRT CLI] [error] CHECK_SUCCESS failed with status=HAILO_DRIVER_NOT_INSTALLED(64)”
Any suggestions on a potentail fix to this issue?
Many thanks!
The first thing to check is whether the Hailo-8 is detected by the system using the lspci command. This works even without the HailoRT PCIe driver installed.
When you can see the Hailo-8 check whether there are any updates available and install them.
Turned out the PCIE cable just wasn’t installed correctly!
i have the same issue. The AI hat+ connection seems to be fine. But i am getting the exact error. Reinstalled the os multiple times. How to solve this?
HI, did you work your way around it.
i am shown:
hp@hp-engage-one-pro-g2:~/hailo_ai_sw_suite_2025-04_docker$ lspci | grep -i hailo
02:00.0 Co-processor: Hailo Technologies Ltd. Hailo-8 AI Processor (rev 01)
on the host machine but still get error inside docker:
hailortcli scan
