Orico M2V01-C4 M.2 SSD Enclosure for Hailo-8 and Hailo-10H
This guide provides step-by-step instructions for setting up and using the Orico M2V01-C4 M.2 SSD Enclosure with Hailo-8/8L and Hailo-10H modules on devices with Thunderbolt support. Whether you’re using a laptop or desktop, this guide will help you identify the device or variant in an online store and ensure compatibility and proper installation.
Below are images to help identify the device when purchasing online.
Specifications
Here are some parameters that may help you search for or identify the adapter, or find alternative versions. These adapters are often slightly modified by the manufacturer.
- Model: M2V01-C4 M.2
- Product Name: M.2 NVME SSD Enclosure
- Chip Used: JHL7440 (Thunderbolt 3 controller from Intel)
Cable
The box includes two cables. To use the enclosure with a Hailo module, you must connect the cable with the two USB-C connectors. The USB-A type connector will not work.
Installation
Hailo-8 M.2 module
The tested adapter supports four PCIe lanes, allowing you to use a Hailo-8 M.2 module with either a key M or key B+M (two PCIe lanes). When connecting the Hailo chip to the enclosure, make sure to use the thermal pad provided in your Hailo-8 starter kit for proper heat dissipation. The enclosure is fairly massive and will allow running heavy workloads for an extended time.
Hailo-10H M.2 module
Update: The SSD enclosure also works with the Hailo-10H M.2 module. Make sure to use the thermal pad provided in your Hailo-10H starter kit for proper heat dissipation.
Thunderbolt port
Ensure that your computer supports Thunderbolt. Although Thunderbolt uses the USB-C connector, it combines PCIe and DisplayPort protocols. You can usually identify a Thunderbolt port by the lightning bolt symbol next to the connector.
Before installing the HailoRT PCIe driver, it’s recommended to test your system. The PCIe capabilities of all devices are negotiated at boot or plug-in without needing custom drivers. You should be able to see the Hailo-8 when running lspci
on Linux or in the Windows Device Manager.
Linux lspci command
04:00.0 Co-processor: Hailo Technologies Ltd. Hailo-8 AI Processor (rev 01)
or
04:00.0 Co-processor: Device 1e60:2864 (rev 01)
If you encounter any issues or have further questions, feel free to post them in the forum.
