The Hailo-10 is connected to a host via the PCIe interface. USB3 and Ethernet are available on the chip. However they are not connected on the M.2 module. There are several options available to connect a Hailo-10H to a PC, IPC or laptop.
Hailo-10 M.2 module
Many modern motherboards have M.2 connectors. The Hailo-10H M.2 module uses the M.2 key M with 4 PCIe lanes. When available, use the motherboard’s built-in M.2 heatsink; otherwise, attach your own cooling solution.
If no M.2 slot is available a PCIe to M.2 adapter can be used with standard PCIe slots available in many desktop and IPC systems. The adapters are widely available e.g. on Amazon and cost around USD/EURO 10-20.
Some laptops and few desktop motherboards support Thunderbolt. Thunderbolt uses the USB-C connector but combines PCIe and Display Port protocol. The connector is usually marked with a lightning bolt.
When a Thunderbolt port is available a Thunderbolt NVME adapter can be used. These are available at Amazon from different companies like Orico and Other World Computing (OWC). It is important to study the information carefully because there are many similar adapters for USB (will not work). Thunderbolt adapters are more expensive, usually above USD/EURO 100.
When the adapter comes with multiple cables you must use the one suitable for Thunderbolt. They are short and often thick because of the shielding required, have two USB-C type connectors and often a lightning bolt or 40Gbps sign. Using a USB type A port or adapter will not work. Also normal USB-C cables e.g. shipped with mobile phones do not work.
It is recommended to test your system before installing the HailoRT PCIe driver. PCIe capabilities of all devices are negotiated at boot without the need of custom drivers. You should be able to see the Hailo-10 when running lspci on Linux.
The Raspberry Pi M.2 HAT+ does not support securing M.2 modules longer than 42 mm. The current Hailo-10H M.2 module uses the 2280 form factor. If you already have the HAT, you can temporarily secure the module with a cable tie for testing.
We plan to release an Hailo-10H M.2 module in the 2242 form factor.
For now, the better option is to use a HAT that supports longer M.2 modules, such as the Geekworm X1001.
I have an application where I need to achieve at least 50 FPS with the yolo11m model. I would like to know if this is possible with the Hailo-10H + RPI 5.
There will still be a performance difference when you connect a Hailo-10H via a single PCIe lane vs a system with 4 PCIe lanes. However for larger models that use context switching you should generally see a better performance.
I measured 53 FPS for the yolov11m on the setup above.
We do not validate the Hailo-10 on the Orange Pi platforms, so we cannot say for certain whether this combination will work. However, both the HailoRT runtime and the HailoRT PCIe driver are open-source, so in principle you should be able to compile them from source for the Orange Pi’s environment.
If you decide to try it, the easiest path is likely to use a Debian- or Ubuntu-based distribution, where the installation is generally more straightforward.
I’d tried PCIe adapter with Hailo-10h, but the RT platform will show CRC error warning in every llm generation. Depends on my prompt length the warning will show 2~14 lines. I’d tried to change different adapter and modified the speed to GEN2, the warning still there. But the same module works find for m.2 slot IPC. Is this normal when using adapter? Or there’s recommendation type or spec adapter?
Every PCIe adapter is different. In general, I haven’t encountered any issues with adapters that don’t have PCIe switches, whereas some adapters with PCIe switches work without issues while others can be less reliable.
PCIe adapters for desktop PCs are often generic, no-name products, and the available models can vary by region or country.
If you mean Thunderbolt adapters (e.g., for laptops), some models seem to work better than others. I’ve tested a few of them, which you can find in the links above. If a particular model isn’t available in your region, I’ve also included the chipset used in each adapter to make it easier to find an alternative.
