While following this guide I get the following messages and warnings on optimization step:
[info] Model Optimization Algorithm Mixed Precision is done (completion time is 00:00:00.64)
Calibration: 100%|█████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 64/64 [00:57<00:00, 1.11entries/s]
[info] Model Optimization Algorithm Statistics Collector is done (completion time is 00:00:59.68)
[info] Model Optimization Algorithm Matmul Equalization is done (completion time is 00:00:00.02)
[info] activation fitting started for detector/reduce_sum_sftmax1/act_op
[info] Adaround skipped
Epoch 1/4
1/512 […]
Can someone please explain the following:
[warning] Reducing optimization level to 0 (the accuracy won't be optimized and compression won't be used) because there's no available GPUWhy is this happening? Can it be fixed somehow? I have an Nvidia GPU with drivers/CUDA/CUDNN installed on a system.[warning] Running model optimization with zero level of optimization is not recommended for production use and might lead to suboptimal accuracy resultsSimilarly, is this normal or should it be fixed somehow?Using dataset with 1024 entries for finetuneI have randomly selected 1024 images from training dataset, is this enough?Epoch 1/4 1/512 [..............................]What is going on at this step? Why 4 epochs?
Thanks!
