Optimize Problem
I am writing a script to optimize my model, and an error raised:
(hailodfc) (base) ykl@ykl-virtual-machine:~/hailodfc$ /home/ykl/hailodfc/bin/python /home/ykl/hailodfc/paser4.py
[info] Loading model script commands to Aod-Net from string
Calibration data shape: (1449, 450, 600, 3), range: 0.0 - 255.0
[info] Model Optimization Algorithm Mixed Precision is done (completion time is 00:00:00.08)
[info] Remove layer Aod-Net/conv2 because it has no effect on the network output
[info] Remove layer Aod-Net/concat2 because it has no effect on the network output
[info] Remove layer Aod-Net/conv4 because it has no effect on the network output
  • File “/home/ykl/hailodfc/paser4.py”, line 42, in *
  • runner.optimize(calib_data_np)*
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_sdk_common/states/states.py”, line 16, in wrapped_func*
  • return func(self, *args, *kwargs)
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py”, line 2128, in optimize*
  • self._optimize(calib_data, data_type=data_type, work_dir=work_dir)*
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py”, line 1970, in _optimize*
  • self._sdk_backend.full_quantization(calib_data, data_type=data_type, work_dir=work_dir)*
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1125, in full_quantization*
  • self._full_acceleras_run(self.calibration_data, data_type)*
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1319, in _full_acceleras_run*
  • optimization_flow.run()*
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_model_optimization/tools/orchestator.py”, line 306, in wrapper*
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 335, in run*
  • step_func()*
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_model_optimization/tools/orchestator.py”, line 250, in wrapped*
  • result = method(*args, *kwargs)
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_model_optimization/tools/subprocess_wrapper.py”, line 124, in parent_wrapper*
  • func(self, *args, *kwargs)
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 351, in step1*
  • self.pre_quantization_structural()*
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 384, in pre_quantization_structural*
  • self._remove_dead_layers()*
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 512, in _remove_dead_layers*
  • algo.run()*
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_model_optimization/algorithms/optimization_algorithm.py”, line 54, in run*
  • return super().run()*
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_model_optimization/algorithms/algorithm_base.py”, line 150, in run*
  • self._run_int()*
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_model_optimization/algorithms/dead_layers_removal.py”, line 79, in _run_int*
  • new_input, new_output = self._infer_model_random_data(ref_input)*
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_model_optimization/algorithms/dead_layers_removal.py”, line 115, in _infer_model_random_data*
  • output = self._model(random_input)*
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/keras/utils/traceback_utils.py”, line 70, in error_handler*
  • raise e.with_traceback(filtered_tb) from None*
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_model_optimization/acceleras/utils/distributed_utils.py”, line 122, in wrapper*
  • res = func(self, *args, *kwargs)
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_model_optimization/acceleras/model/hailo_model/hailo_model.py”, line 1153, in build*
  • self.compute_output_shape(input_shape)*
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_model_optimization/acceleras/model/hailo_model/hailo_model.py”, line 1091, in compute_output_shape*
  • return self.compute_and_verify_output_shape(input_shape, verify_layer_inputs_shape=False)*
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_model_optimization/acceleras/model/hailo_model/hailo_model.py”, line 1125, in compute_and_verify_output_shape*
  • layer_output_shape = layer.compute_output_shape(layer_input_shapes)*
  • File “/home/ykl/hailodfc/lib/python3.10/site-packages/hailo_model_optimization/acceleras/hailo_layers/base_hailo_layer.py”, line 1572, in compute_output_shape*
  • raise ValueError(*
    ValueError: Inputs and input nodes not the same length in layer Aod-Net/concat1 - inputs: 4, nodes: 2
    So,how can I solve the problem?
Hey @olive_michael ,
You’re hitting this error during model optimization:
This happens when the DFC optimization tool tries to remove unused (“dead”) layers. In your case, it’s getting confused about the concat1 layer — it’s expecting 2 inputs, but for some reason it’s receiving 4.
Why This Happens
When layers are pruned during optimization (like conv2, concat2, or conv4), the tool tries to reconnect what’s left. Sometimes it doesn’t do that cleanly, and you end up with layers wired incorrectly — like concat1 thinking it has more inputs than it should.
How to Fix It
1. Double-check the inputs to concat1
Open your model in something like Netron or use model.summary() (if you’re using Keras) and confirm that concat1 is only receiving two inputs. In code, that should look something like:
concat1 = Concatenate()([input1, input2])
If there are more than two inputs listed there, or the wrong ones, that’s your problem.
2. Turn Off Dead Layer Removal
Since the issue is happening during that specific optimization step, a quick fix is to disable it. In your script (probably paser4.py), before runner.optimize(), add:
runner.set_optimization_param('enable_dead_layers_removal', False)
3. Manually Set Optimization Level
You’re seeing a warning about the optimization level being reduced because there’s no GPU:
[warning] Reducing optimization level to 0 ...
Go ahead and set it explicitly to avoid any surprises:
runner.set_optimization_param('optimization_level', 0)
I appreciate Omria for helping me with my previous question. However, I’ve encountered a new issue now.
  File "/home/ykl/hailodfc/paser4.py", line 44, in <module>
AttributeError: 'ClientRunner' object has no attribute 'set_optimization_param'
 'ClientRunner' object has no attribute 'set_optimization_param'.
My code is below
import os
# Define the model name and HAR file path
model_name = "Aod-Net"
hailo_model_har_name = f"{model_name}_hailo_model.har"
# Make sure the HAR file exists
assert os.path.isfile(hailo_model_har_name), f"HAR file not found: {hailo_model_har_name}"
# Initialize the ClientRunner
# Define model script commands
model_script = "\n".join([
    "model_optimization_flavor(optimization_level=1, compression_level=1, batch_size=1)",
    "performance_param(compiler_optimization_level=max)"
# Load the model script
runner.load_model_script(model_script)
# Load calibration dataset (numpy array)
calib_dataset_path = "/home/ykl/hailodfc/output/processed_calibration_data.npy"
assert os.path.isfile(calib_dataset_path), f"Calibration data not found: {calib_dataset_path}"
calib_data_np = np.load(calib_dataset_path)
# Check data shape and value range
print(f"Calibration data shape: {calib_data_np.shape}, range: {calib_data_np.min()} - {calib_data_np.max()}")
# Set optimization parameters
# Run optimization with the calibration dataset
# Save the optimized and quantized HAR file
quantized_model_har_path = f"{model_name}_quantized_model.har"
print(f"Quantized HAR file saved to: {quantized_model_har_path}")
@omria How to solve the problem : ‘ClientRunner’ object has no attribute ‘set_optimization_param’. Could you please provide guidance on how to fix this problem.
@omria Thank you. I have solved the problem.Just add the commad below in the .alls file:
alls = [
    "pre_quantization_optimization(dead_layers_removal, policy=disabled)"
