I have a yolov8n model trained on a custom dataset with 1 class label. I am running the following command:
The optimization and calibration process appears to run fine until I encounter the following error:
[info] Fine Tune is done (completion time is 00:04:07.25)
Full Quant Analysis: 50%|███████████████████████████████████████████████████ | 1/2 [00:00<00:00, 7.61iterations/s]Traceback (most recent call last):
File "/root/hailo/bin/hailomz", line 33, in <module>
File "/root/hailo_model_zoo/hailo_model_zoo/main.py", line 122, in main
run(args)
File "/root/hailo_model_zoo/hailo_model_zoo/main.py", line 111, in run
File "/root/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 250, in compile
File "/root/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 91, in _ensure_optimized
optimize_model(
File "/root/hailo_model_zoo/hailo_model_zoo/core/main_utils.py", line 321, in optimize_model
File "/root/hailo/lib/python3.10/site-packages/hailo_sdk_common/states/states.py", line 16, in wrapped_func
File "/root/hailo/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 2093, in optimize
File "/root/hailo/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 1935, in _optimize
File "/root/hailo/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py", line 1045, in full_quantization
File "/root/hailo/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py", line 1229, in _full_acceleras_run
optimization_flow.run()
File "/root/hailo/lib/python3.10/site-packages/hailo_model_optimization/tools/orchestator.py", line 306, in wrapper
File "/root/hailo/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py", line 316, in run
step_func()
File "/root/hailo/lib/python3.10/site-packages/hailo_model_optimization/tools/orchestator.py", line 250, in wrapped
File "/root/hailo/lib/python3.10/site-packages/hailo_model_optimization/tools/subprocess_wrapper.py", line 111, in parent_wrapper
hailo_model_optimization.acceleras.utils.acceleras_exceptions.SubprocessTracebackFailure: Subprocess failed with traceback
File "/root/hailo/lib/python3.10/site-packages/hailo_model_optimization/tools/subprocess_wrapper.py", line 73, in child_wrapper
func(self, *args, **kwargs)
File "/root/hailo/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py", line 347, in step3
self.finalize_optimization()
File "/root/hailo/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py", line 405, in finalize_optimization
self._noise_analysis()
File "/root/hailo/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py", line 585, in _noise_analysis
algo.run()
File "/root/hailo/lib/python3.10/site-packages/hailo_model_optimization/algorithms/optimization_algorithm.py", line 50, in run
return super().run()
File "/root/hailo/lib/python3.10/site-packages/hailo_model_optimization/algorithms/algorithm_base.py", line 151, in run
self._run_int()
File "/root/hailo/lib/python3.10/site-packages/hailo_model_optimization/algorithms/hailo_layer_noise_analysis.py", line 83, in _run_int
self.analyze_full_quant_net()
File "/root/hailo/lib/python3.10/site-packages/hailo_model_optimization/algorithms/hailo_layer_noise_analysis.py", line 197, in analyze_full_quant_net
lat_model.predict_on_batch(inputs)
File "/root/hailo/lib/python3.10/site-packages/keras/engine/training.py", line 2603, in predict_on_batch
outputs = self.predict_function(iterator)
File "/root/hailo/lib/python3.10/site-packages/tensorflow/python/util/traceback_utils.py", line 153, in error_handler
File "/tmp/__autograph_generated_filenvpcgmfo.py", line 15, in tf__predict_function
retval_ = ag__.converted_call(ag__.ld(step_function), (ag__.ld(self), ag__.ld(iterator)), None, fscope)
File "/root/hailo/lib/python3.10/site-packages/keras/engine/training.py", line 2155, in step_function
outputs = model.distribute_strategy.run(run_step, args=(data,))
File "/root/hailo/lib/python3.10/site-packages/keras/engine/training.py", line 2143, in run_step
outputs = model.predict_step(data)
File "/root/hailo/lib/python3.10/site-packages/keras/engine/training.py", line 2111, in predict_step
return self(x, training=False)
File "/root/hailo/lib/python3.10/site-packages/keras/utils/traceback_utils.py", line 70, in error_handler
File "/tmp/__autograph_generated_fileau2rkomm.py", line 188, in tf__call
ag__.for_stmt(ag__.converted_call(ag__.ld(self)._model.flow.toposort, (), None, fscope), None, loop_body_5, get_state_9, set_state_9, (), {'iterate_names': 'lname'})
File "/tmp/__autograph_generated_fileau2rkomm.py", line 167, in loop_body_5
ag__.if_stmt(ag__.not_(continue__1), if_body_3, else_body_3, get_state_8, set_state_8, (), 0)
File "/tmp/__autograph_generated_fileau2rkomm.py", line 94, in if_body_3
n_ancestors = ag__.converted_call(ag__.ld(self)._native_model.flow.ancestors, (ag__.ld(lname),), None, fscope)
File "/tmp/__autograph_generated_filewueztmji.py", line 12, in tf__ancestors
retval_ = ag__.converted_call(ag__.ld(nx).ancestors, (ag__.ld(self), ag__.ld(source)), None, fscope)
TypeError: in user code:
File "/root/hailo/lib/python3.10/site-packages/keras/engine/training.py", line 2169, in predict_function *
return step_function(self, iterator)
File "/root/hailo/lib/python3.10/site-packages/keras/engine/training.py", line 2155, in step_function **
File "/root/hailo/lib/python3.10/site-packages/keras/engine/training.py", line 2143, in run_step **
TypeError: Exception encountered when calling layer 'lat_model' (type LATModel).
in user code:
File "/root/hailo/lib/python3.10/site-packages/hailo_model_optimization/algorithms/lat_utils/lat_model.py", line 340, in call *
n_ancestors = self._native_model.flow.ancestors(lname)
File "/root/hailo/lib/python3.10/site-packages/hailo_model_optimization/acceleras/model/hailo_model/model_flow.py", line 31, in ancestors *
return nx.ancestors(self, source)
TypeError: outer_factory.<locals>.inner_factory.<locals>.tf__func() missing 1 required keyword-only argument: '__wrapper'
Call arguments received by layer 'lat_model' (type LATModel):
• inputs=tf.Tensor(shape=(8, 640, 640, 3), dtype=float32)
I did search the forum for similar issues and encountered this post Problem With Model Optimization - #31 by klausk which seemed relevant to my model, since it only has one output class.
I attempted to re-run the steps with a modified yolov8n.alls file but got the same error, so I am not sure how to proceed. I also tried other model sizes and got a similar error to the above.
