Hey there, so idk why…but I’ve been trying to convert this har file to hef, but everytime I do it, theres an error. The model zoo is installed, tappas, suite, everythings there, but I just dont know it doesnt work. I’ve attached the error below. Thanks!!
(hailo_venv) ubuntu@ubuntu-SM2025LT0011:~/Hailo8l/sources/model_zoo$ export HAILO_MODEL_ZOO_DATA_PATH=“/home/ubuntu/.hailomz/data/models_files/coco/2023-08-03”
hailomz compile yolov8n --ckpt /home/ubuntu/Hailo8l/model/runs/detect/train8/weights/best.onnx
 Start run for network yolov8n …
[info] Restored ONNX model yolov8n (completion time: 00:00:00.05)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.19)
[info] Simplified ONNX model for a parsing retry attempt (completion time: 00:00:00.57)
[info] According to recommendations, retrying parsing with end node names: [‘/model.22/Concat_3’].
[info] Restored ONNX model yolov8n (completion time: 00:00:00.02)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.14)
[info] Start nodes mapped from original model: ‘images’: ‘yolov8n/input_layer1’.
[info] End nodes mapped from original model: ‘/model.22/Concat_3’.
[info] Translation completed on ONNX model yolov8n (completion time: 00:00:00.61)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.18)
[info] Translation completed on ONNX model yolov8n (completion time: 00:00:00.63)
[info] Saved HAR to: /home/ubuntu/Hailo8l/sources/model_zoo/yolov8n.har
 Preparing calibration data…
[info] Loading model script commands to yolov8n from /home/ubuntu/Hailo8l/sources/model_zoo/hailo_model_zoo/cfg/alls/generic/yolov8n.alls
File “/home/ubuntu/Hailo8l/hailo_venv/bin/hailomz”, line 33, in
File “/home/ubuntu/Hailo8l/sources/model_zoo/hailo_model_zoo/main.py”, line 122, in main
run(args)
File “/home/ubuntu/Hailo8l/sources/model_zoo/hailo_model_zoo/main.py”, line 111, in run
return handlersargs.command
File “/home/ubuntu/Hailo8l/sources/model_zoo/hailo_model_zoo/main_driver.py”, line 250, in compile
runner = ensure_optimized(runner, logger, args, network_info)
File “/home/ubuntu/Hailo8l/sources/model_zoo/hailo_model_zoo/main_driver.py”, line 91, in ensure_optimized
optimize_model(
File “/home/ubuntu/Hailo8l/sources/model_zoo/hailo_model_zoo/core/main_utils.py”, line 353, in optimize_model
File “/home/ubuntu/Hailo8l/hailo_venv/lib/python3.8/site-packages/hailo_sdk_common/states/states.py”, line 16, in wrapped_func
File “/home/ubuntu/Hailo8l/hailo_venv/lib/python3.8/site-packages/hailo_sdk_client/runner/client_runner.py”, line 2128, in optimize
self.optimize(calib_data, data_type=data_type, work_dir=work_dir)
File “/home/ubuntu/Hailo8l/hailo_venv/lib/python3.8/site-packages/hailo_sdk_client/runner/client_runner.py”, line 1970, in optimize
self.sdk_backend.full_quantization(calib_data, data_type=data_type, work_dir=work_dir)
File “/home/ubuntu/Hailo8l/hailo_venv/lib/python3.8/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1125, in full_quantization
self.full_acceleras_run(self.calibration_data, data_type)
File “/home/ubuntu/Hailo8l/hailo_venv/lib/python3.8/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1319, in full_acceleras_run
optimization_flow.run()
File “/home/ubuntu/Hailo8l/hailo_venv/lib/python3.8/site-packages/hailo_model_optimization/tools/orchestator.py”, line 306, in wrapper
File “/home/ubuntu/Hailo8l/hailo_venv/lib/python3.8/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 335, in run
step_func()
File “/home/ubuntu/Hailo8l/hailo_venv/lib/python3.8/site-packages/hailo_model_optimization/tools/orchestator.py”, line 250, in wrapped
File “/home/ubuntu/Hailo8l/hailo_venv/lib/python3.8/site-packages/hailo_model_optimization/tools/subprocess_wrapper.py”, line 123, in parent_wrapper
self.build_model()
File “/home/ubuntu/Hailo8l/hailo_venv/lib/python3.8/site-packages/hailo_model_optimization/flows/optimization_flow.py”, line 249, in build_model
File “/home/ubuntu/Hailo8l/hailo_venv/lib/python3.8/site-packages/hailo_model_optimization/acceleras/model/hailo_model/hailo_model.py”, line 1091, in compute_output_shape
File “/home/ubuntu/Hailo8l/hailo_venv/lib/python3.8/site-packages/hailo_model_optimization/acceleras/model/hailo_model/hailo_model.py”, line 1125, in compute_and_verify_output_shape
File “/home/ubuntu/Hailo8l/hailo_venv/lib/python3.8/site-packages/keras/engine/base_layer.py”, line 917, in compute_output_shape
File “/home/ubuntu/Hailo8l/hailo_venv/lib/python3.8/site-packages/keras/utils/traceback_utils.py”, line 70, in error_handler
File "/tmp/autograph_generated_filezzbpsesg.py", line 41, in tf__call
outputs = ag.converted_call(ag.ld(self).call_core, (ag.ld(inputs), ag.ld(training)), dict(**ag_.ld(kwargs)), fscope)
File "/tmp/autograph_generated_filexiac5vqe.py", line 90, in tf__call_core
ag.if_stmt((ag__.ld(self).postprocess_type in [ag__.ld(PostprocessType).NMS, ag__.ld(PostprocessType).BBOX_DECODER]), if_body_3, else_body_3, get_state_3, set_state_3, (‘do_return’, ‘retval_’), 2)
File "/tmp/autograph_generated_filexiac5vqe.py", line 22, in if_body_3
retval = ag_.converted_call(ag__.ld(self).bbox_decoding_and_nms_call, (ag__.ld(inputs),), dict(is_bbox_decoding_only=(ag__.ld(self).postprocess_type == ag__.ld(PostprocessType).BBOX_DECODER)), fscope)
File "/tmp/autograph_generated_file83xsmus9.py", line 116, in tf__bbox_decoding_and_nms_call
ag.if_stmt((ag__.ld(self).meta_arch in [ag__.ld(NMSOnCpuMetaArchitectures).YOLOV5, ag__.ld(NMSOnCpuMetaArchitectures).YOLOX]), if_body_5, else_body_5, get_state_5, set_state_5, (‘decoded_bboxes’, ‘detection_score’, ‘do_return’, ‘retval_’, ‘inputs’), 4)
File "/tmp/autograph_generated_file83xsmus9.py", line 113, in else_body_5
ag.if_stmt((ag__.ld(self).meta_arch == ag__.ld(NMSOnCpuMetaArchitectures).YOLOV5_SEG), if_body_4, else_body_4, get_state_4, set_state_4, (‘decoded_bboxes’, ‘detection_score’, ‘do_return’, ‘retval_’), 4)
File "/tmp/autograph_generated_file83xsmus9.py", line 110, in else_body_4
ag.if_stmt((ag__.ld(self).meta_arch == ag__.ld(NMSOnCpuMetaArchitectures).YOLOV8), if_body_3, else_body_3, get_state_3, set_state_3, (‘decoded_bboxes’, ‘detection_score’), 2)
File "/tmp/autograph_generated_file83xsmus9.py", line 69, in if_body_3
(decoded_bboxes, detection_score) = ag.converted_call(ag__.ld(self).yolov8_decoding_call, (ag__.ld(inputs),), dict(offsets=[0.5, 0.5]), fscope)
File "/tmp/autograph_generated_filexl4eht0j.py", line 87, in tf__yolov8_decoding_call
decoded_bboxes = ag.converted_call(ag__.ld(tf).expand_dims, (ag__.ld(decoded_bboxes),), dict(axis=2), fscope)
ValueError: Exception encountered when calling layer “yolov8_nms_postprocess” (type HailoPostprocess).
in user code:
File "/home/ubuntu/Hailo8l/hailo_venv/lib/python3.8/site-packages/hailo_model_optimization/acceleras/hailo_layers/base_hailo_none_nn_core_layer.py", line 45, in call  *
File "/home/ubuntu/Hailo8l/hailo_venv/lib/python3.8/site-packages/hailo_model_optimization/acceleras/hailo_layers/hailo_postprocess.py", line 122, in call_core  *
    inputs,
File "/home/ubuntu/Hailo8l/hailo_venv/lib/python3.8/site-packages/hailo_model_optimization/acceleras/hailo_layers/hailo_postprocess.py", line 157, in bbox_decoding_and_nms_call  *
    decoded_bboxes, detection_score = self.yolov8_decoding_call(inputs, offsets=[0.5, 0.5])
File "/home/ubuntu/Hailo8l/hailo_venv/lib/python3.8/site-packages/hailo_model_optimization/acceleras/hailo_layers/hailo_postprocess.py", line 375, in yolov8_decoding_call  *
Call arguments received by layer “yolov8_nms_postprocess” (type HailoPostprocess):
• inputs=[‘tf.Tensor(shape=(None, 80, 80, 64), dtype=float32)’, ‘tf.Tensor(shape=(None, 80, 80, 1), dtype=float32)’, ‘tf.Tensor(shape=(None, 40, 40, 64), dtype=float32)’, ‘tf.Tensor(shape=(None, 40, 40, 1), dtype=float32)’, ‘tf.Tensor(shape=(None, 20, 20, 64), dtype=float32)’, ‘tf.Tensor(shape=(None, 20, 20, 1), dtype=float32)’]
• training=False
• kwargs=<class ‘inspect._empty’>
