Running the detection example in Hailo-Application-Code-Examples-main results in:
/Hailo-Application-Code-Examples-main/runtime/gstreamer/detection_python
ModuleNotFoundError: No module named ‘hailo’ detection.py
I also installed pyhailoRT.
Hey @hcpark
If you’re experiencing issues, the cause may be that pyhailort isn’t correctly installed in your environment.
pyhailort within a virtual environment (venv) to streamline dependency management.Start Python:
python3
Attempt to import Hailo:
import hailo
If you encounter an error, please reinstall pyhailort in your current environment (use a venv for x86 or install directly on the base OS for Raspberry Pi).
