ModuleNotFoundError: No module named 'hailo_apps_infra'
Hi! I’m having issues running my converted to .hef from yolov8 model.
When I run:
python3 basic_pipelines/detection.py --hef-path resources/bestn3.hef --input rpi --labels-json resources/cytron-labels.json
I get this error below, even though I installed everything (I guess).
  File "/home/pi/Kim/hailo-rpi5-examples/basic_pipelines/detection.py", line 9, in <module>
    from hailo_apps_infra.hailo_rpi_common import (
Please, is there anything I can do to run my model without any errors?
Hi
I encountered the same problem and my way of solving this was to update from the Git repo:
cd [your-path]/hailo-rpi5-examples
git pull
And then running the install script again:
./install.sh
and starting the virtual environment with
source setup_env.sh
I think it has to do with Hailo have redone the Raspberry Pi examples using the Hailo Applications Infrastructure
Good Luck
Fredrik
As a side note, If you have installed Hailo-CLIP, GitHub - hailo-ai/hailo-CLIP: Real-time zero-shot classifier app, hailo_apps_infra is also installed in the Hailo-CLIP virtual environment at
.../hailo-CLIP/hailo_clip_venv/lib/python3.11/site-packages/hailo_apps_infra
