I am using this repository for detection. In the file object_detection_utils.py, there is a function called extract_detections. It is stated that by default, detections are extracted from a threshold of 0.5. However, when I lower this threshold in the code to 0.2, for example, nothing changes, and detections are still extracted from 0.5.
Could you please let me know if there is a way to change this threshold? In my case, NMS is set to 0.2 in the .hef file, but for some reason, I still can’t extract detections below 0.5. Is it possible to modify this threshold to a lower value?
I suspect the issue comes from the fact that the example model has the NMS built in.
The IoU is set to 0.60.
Run the following command to confirm:
hailortcli parse-hef yolov7.hef
Network group name: yolov7, Multi Context - Number of contexts: 5
Network name: yolov7/yolov7
VStream infos:
Input yolov7/input_layer1 UINT8, NHWC(640x640x3)
Output yolov5_nms_postprocess FLOAT32, HAILO NMS BY CLASS(number of classes: 80, maximum bounding boxes per class: 80, maximum frame size: 128320)
Operation:
Op YOLOV5
Score threshold: 0.001
IoU threshold: 0.60
Classes: 80
Cross classes: false
NMS results order: BY_CLASS
Max bboxes per class: 80
Image height: 640
Image width: 640
NMS is handled by HailoRT before your app gets the data. You would need to change the NMS settings inside the HEF. I do not think you can do this after creation of the HEF file. So you would need to do this during model conversion.
I think the threshold @An_ti11 is referring to is score threshold and not IoU as the object_detection_utils.py script filters based on score threshold.
OK, are you sure it is an issue with the score itself. I noted there is a min-score parameter in the draw_detections function. It is set to 0.45 by default. How do you determine that “nothing changes”? Do you look at the data or the drawing?
"Architecture HEF was compiled for: HAILO8L
Network group name: best, Multi Context - Number of contexts: 6
Network name: best/best
VStream infos:
Input best/input_layer1 UINT8, NHWC(640x640x3)
Output best/yolov8_nms_postprocess FLOAT32, HAILO NMS BY CLASS(number of classes: 1, maximum bounding boxes per class: 100, maximum frame size: 2004)
Operation:
Op YOLOV8
Score threshold: 0.200
IoU threshold: 0.70
Classes: 1
Max bboxes per class: 100
Image height: 640
Image width: 640
" This is what my header looks like. The problem is that I can’t change the NMS value during inference—it always stays at 0.5. I’ve tried many things, but I couldn’t find a solution. I don’t understand what the issue is
