Our pipeline uses object detection across various classes, each requiring different IoU thresholds. For some classes, high overlap with the ground truth is crucial, while for others, it is less critical.
Currently, our object detection model (yolov5-m) applies a uniform IoU threshold in post-processing.
At the moment we use the following script_commands to convert the model to the hef format:
'nms_postprocess(meta_arch=yolov5, engine=cpu, nms_scores_th=0.25, nms_iou_th=0.45)'
Could we modify the NMS procedure on the Hailo to implement class-specific IoU thresholds for post-processing?
