Hi together,
I ran into a roadblock when compiling my optimzied semantic segmentation model.
This is the error code from the Tutorial Notebook that I followed.
Does Anyone (Admins) have an Idea with this kind of error and can point me in the right direction?
Thank you!
[info] Iteration #1 - Contexts: 3
[info] Iteration #2 - Contexts: 3
[info] Iteration #3 - Contexts: 3
[info] Iteration #4 - Contexts: 3
[info] Iteration #5 - Contexts: 3
[info] Iteration #6 - Contexts: 3
[info] Iteration #7 - Contexts: 3
[info] Iteration #8 - Contexts: 3
[info] Iteration #9 - Contexts: 3
[info] Iteration #10 - Contexts: 3
[info] Iteration #11 - Contexts: 3
[info] Iteration #12 - Contexts: 3
[info] Iteration #13 - Contexts: 3
[info] Iteration #14 - Contexts: 3
[info] Iteration #15 - Contexts: 3
[info] Iteration #16 - Contexts: 3
[info] Iteration #17 - Contexts: 3
[info] Iteration #18 - Contexts: 3
[info] Iteration #19 - Contexts: 3
[info] Iteration #20 - Contexts: 3
[info] Iteration #21 - Contexts: 3
[info] Iteration #22 - Contexts: 3
[info] Iteration #23 - Contexts: 3
[info] Iteration #24 - Contexts: 3
[info] Iteration #25 - Contexts: 3
[info] Iteration #26 - Contexts: 3
[info] Iteration #27 - Contexts: 3
[info] Iteration #28 - Contexts: 3
[info] Iteration #29 - Contexts: 3
[info] Iteration #30 - Contexts: 3
[info] Iteration #31 - Contexts: 3
[info] Iteration #32 - Contexts: 3
[info] Iteration #33 - Contexts: 3
[info] Iteration #34 - Contexts: 3
[info] Iteration #35 - Contexts: 3
[info] Iteration #36 - Contexts: 3
[info] Iteration #37 - Contexts: 3
[info] Iteration #38 - Contexts: 3
[info] Iteration #39 - Contexts: 3
[info] Iteration #40 - Contexts: 3
[info] Iteration #41 - Contexts: 3
[info] Iteration #42 - Contexts: 3
[info] Iteration #43 - Contexts: 3
[info] Iteration #44 - Contexts: 3
[info] Iteration #45 - Contexts: 3
[info] Iteration #46 - Contexts: 3
[info] Iteration #47 - Contexts: 3
[info] Iteration #48 - Contexts: 3
[info] Iteration #49 - Contexts: 3
[info] Iteration #50 - Contexts: 3
[info] Iteration #51 - Contexts: 3
compiler: …/src/allocator/network_graph_appender.cpp:396: Status<network_graph::ShortcutNetworkNode*> allocator::NetworkGraphAppender::AddShortcut(std::string, network_graph::NetworkNode&, std::vector<network_graph::NetworkNode*>): Assertion src_node.output_format() == (*first_succ)->input_format()' failed. compiler: ../src/allocator/network_graph_appender.cpp:396: Status<network_graph::ShortcutNetworkNode*> allocator::NetworkGraphAppender::AddShortcut(std::string, network_graph::NetworkNode&, std::vector<network_graph::NetworkNode*>): Assertion src_node.output_format() == (*first_succ)->input_format()’ failed.
BackendAllocatorException Traceback (most recent call last)
Cell In[4], line 1
----> 1 hef = runner.compile()
3 file_name = f"{model_name}.hef"
4 with open(file_name, “wb”) as f:
File ~/miniconda3/envs/hailoenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py:886, in ClientRunner.compile(self)
874 def compile(self):
875 “”"
876 DFC API for compiling current model to Hailo hardware.
877
884
885 “”"
→ 886 return self._compile()
File ~/miniconda3/envs/hailoenv/lib/python3.10/site-packages/hailo_sdk_common/states/states.py:16, in allowed_states..wrap..wrapped_func(self, *args, **kwargs)
13 raise InvalidStateException(
14 f"The execution of {func.name} is not available under the state: {self._state.value}",
15 )
—> 16 return func(self, *args, **kwargs)
File ~/miniconda3/envs/hailoenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py:1094, in ClientRunner._compile(self, fps, mapping_timeout, allocator_script_filename)
1088 self._logger.warning(
1089 f"Taking model script commands from {allocator_script_filename} and ignoring "
1090 f"previous allocation script commands",
1091 )
1092 self.load_model_script(allocator_script_filename)
→ 1094 serialized_hef = self._sdk_backend.compile(fps, self.model_script, mapping_timeout)
1096 self._auto_model_script = self._sdk_backend.get_auto_alls()
1097 self._state = States.COMPILED_SLIM_MODEL if orig_state in SLIM_STATES else States.COMPILED_MODEL
File ~/miniconda3/envs/hailoenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py:1669, in SdkBackendCompilation.compile(self, fps, allocator_script, mapping_timeout)
1667 def compile(self, fps, allocator_script=None, mapping_timeout=None):
1668 self._model.fill_default_quantization_params(logger=self._logger)
→ 1669 hef, mapped_graph_file = self._compile(fps, allocator_script, mapping_timeout)
1670 # TODO: Jira
1671 if not SDKPaths().is_internal:
File ~/miniconda3/envs/hailoenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py:1663, in SdkBackendCompilation._compile(self, fps, allocator_script, mapping_timeout)
1657 if not model_params and self.requires_quantized_weights:
1658 raise BackendRuntimeException(
1659 "Model requires quantized weights in order to run on HW, but none were given. "
1660 “Did you forget to quantize?”,
1661 )
→ 1663 hef, mapped_graph_file, auto_alls = self.hef_full_build(fps, mapping_timeout, model_params, allocator_script)
1664 self._auto_alls = auto_alls
1665 return hef, mapped_graph_file
File ~/miniconda3/envs/hailoenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py:1639, in SdkBackendCompilation.hef_full_build(self, fps, mapping_timeout, params, allocator_script)
1637 config_paths = ConfigPaths(self._hw_arch, self._model.name)
1638 config_paths.set_stage(“inference”)
→ 1639 auto_alls, self._hef_data, self._integrated_graph = allocator.create_mapping_and_full_build_hef(
1640 config_paths.get_path(“network_graph”),
1641 config_paths.get_path(“mapped_graph”),
1642 config_paths.get_path(“compilation_output_proto”),
1643 params=params,
1644 allocator_script=allocator_script,
1645 compiler_statistics_path=config_paths.get_path(“compiler_statistics”),
1646 nms_metadata=self._nms_metadata,
1647 har=self.har,
1648 alls_ignore_invalid_cmds=self._alls_ignore_invalid_cmds,
1649 )
1651 return self._hef_data, config_paths.get_path(“mapped_graph”), auto_alls
File ~/miniconda3/envs/hailoenv/lib/python3.10/site-packages/hailo_sdk_client/allocator/hailo_tools_runner.py:761, in HailoToolsRunner.create_mapping_and_full_build_hef(self, network_graph_path, output_path, compilation_output_proto, agent, strategy, auto_mapping, params, expected_output_tensor, expected_pre_acts, network_inputs, network_outputs, allocator_script, allocator_script_mode, compiler_statistics_path, nms_metadata, har, alls_ignore_invalid_cmds)
756 if self.hn.net_params.clusters_placement != []:
757 assert (
758 len(self.hn.net_params.clusters_placement) <= self._number_of_clusters
759 ), “Number of clusters in layer placements is larger than allowed number of clusters”
→ 761 self.call_builder(
762 network_graph_path,
763 output_path,
764 compilation_output_proto=compilation_output_proto,
765 agent=agent,
766 strategy=strategy,
767 exit_point=BuilderExitPoint.POST_CAT,
768 params=params,
769 expected_output_tensor=expected_output_tensor,
770 expected_pre_acts=expected_pre_acts,
771 network_inputs=network_inputs,
772 network_outputs=network_outputs,
773 allocator_script=allocator_script,
774 allocator_script_mode=allocator_script_mode,
775 compiler_statistics_path=compiler_statistics_path,
776 nms_metadata=nms_metadata,
777 har=har,
778 alls_ignore_invalid_cmds=alls_ignore_invalid_cmds,
779 )
781 return self._auto_alls, self._output_hef_data, self._output_integrated_pb_graph
File ~/miniconda3/envs/hailoenv/lib/python3.10/site-packages/hailo_sdk_client/allocator/hailo_tools_runner.py:693, in HailoToolsRunner.call_builder(self, network_graph_path, output_path, blind_deserialize, **kwargs)
691 sys.excepthook = _hailo_tools_exception_hook
692 try:
→ 693 self.run_builder(network_graph_path, output_path, **kwargs)
694 except BackendInternalException:
695 try:
File ~/miniconda3/envs/hailoenv/lib/python3.10/site-packages/hailo_sdk_client/allocator/hailo_tools_runner.py:569, in HailoToolsRunner.run_builder(self, network_graph_filename, output_filename, compilation_output_proto, agent, strategy, exit_point, params, expected_output_tensor, expected_pre_acts, network_inputs, network_outputs, allocator_script, allocator_script_mode, compiler_statistics_path, is_debug, nms_metadata, har, alls_ignore_invalid_cmds)
567 raise e.internal_exception(“Compilation failed:”, hailo_tools_error=compiler_msg) from None
568 else:
→ 569 raise e.internal_exception(“Compilation failed with unexpected crash”) from None
570 finally:
571 if self._output_integrated_pb_graph is None and self._output_hef_data is None:
BackendAllocatorException: Compilation failed with unexpected crash
