Failed during compilation with "map at"
Here are my logs the error message is pretty unhelpful. I am guessing its some memory error but not sure? I removed quite a bit of logs to get below post limit.
[info] Finding the best partition to contexts...
e[?25l[info] Iteration #1 - Contexts: 4
[info] Iteration #57 - Contexts: 4
e[?25h
[info] Resources optimization guidelines: Strategy -> GREEDY Objective -> MAX_FPS
[info] Resources optimization params: max_control_utilization=60%, max_compute_utilization=60%, max_compute_16bit_utilization=60%, max_memory_utilization (weights)=60%, max_input_aligner_utilization=60%, max_apu_utilization=60%
[info] context_0 (context_0):
Iterations: 4
Reverts on cluster mapping: 0
Reverts on split failed: 0
[info] context_1 (context_1):
Iterations: 4
[info] context_2 (context_2):
Iterations: 4
[info] context_3 (context_3):
Iterations: 4
[info] context_0 utilization:
[info] +-----------+---------------------+---------------------+--------------------+
[info] | Cluster   | Control Utilization | Compute Utilization | Memory Utilization |
[info] | cluster_0 | 100%                | 25%                 | 30.5%              |
[info] | cluster_1 | 43.8%               | 10.9%               | 14.8%              |
[info] | cluster_4 | 56.3%               | 14.1%               | 20.3%              |
[info] | cluster_5 | 56.3%               | 15.6%               | 32.8%              |
[info] | Total     | 64.1%               | 16.4%               | 24.6%              |
[info] context_1 utilization:
[info] | cluster_0 | 50%                 | 15.6%               | 18.8%              |
[info] | cluster_1 | 75%                 | 20.3%               | 27.3%              |
[info] | cluster_4 | 100%                | 29.7%               | 30.5%              |
[info] | cluster_5 | 75%                 | 21.9%               | 31.3%              |
[info] | Total     | 75%                 | 21.9%               | 27%                |
[info] context_2 utilization:
[info] | cluster_0 | 68.8%               | 17.2%               | 21.9%              |
[info] | cluster_1 | 50%                 | 12.5%               | 17.2%              |
[info] | cluster_4 | 100%                | 25%                 | 36.7%              |
[info] | cluster_5 | 37.5%               | 9.4%                | 14.8%              |
[info] | Total     | 64.1%               | 16%                 | 22.7%              |
[info] context_3 utilization:
[info] | cluster_0 | 68.8%               | 17.2%               | 22.7%              |
[info] | cluster_1 | 6.3%                | 1.6%                | 2.3%               |
[info] | cluster_4 | 62.5%               | 18.8%               | 19.5%              |
[info] | Total     | 34.4%               | 9.4%                | 11.1%              |
[warning] Failed dump best-effort allocation proto: map::at
[info] Successful Mapping (allocation time: 1m 50s)
[info] Compiling context_0...
[info] Compiling context_1...
[info] Compiling context_2...
[info] Compiling context_3...
[info] Bandwidth of model inputs: 15.8203 Mbps, outputs: 47.4609 Mbps (for a single frame)
[info] Bandwidth of inter context tensors: 221.045 Mbps (for a single frame)
[error] Compilation failed with error: 'map::at'
e[?25h
map::at
Any way to get more informative log on this, or how to debug this so I know how to change the model so it will compile?
Hi @smat,
On the running directory you should see a hailo.core.log, it’s a bit cryptic, but we know how to get stuff out of it.
What should I look for? I do see these logs now that you mention them.
Look from the bottom up for an error. You can DM me that file, and I’ll look as well.
