Failed to parse the model into Hef
Hello everyone in the community
Recently, I have been parsing my model into Hef, but the error is as follows:
[error] Mapping Failed (allocation time: 1m 58s)
Compiler could not find a valid partition to contexts. Most commom error is: Automri finished with too many resources on context_4 with 11/56 failures.
[error] BackendAllocatorException: Compilation failed: Compiler could not find a valid partition to contexts. Most commom error is: Automri finished with too many resources on context_4 with 11/56 failures.
I have tried setting up Performance Params:
But the error is as follows:
[error] Mapping Failed (Timeout, allocation time: 2m 38s)
No valid partition found
[error] BackendAllocatorException: Compilation failed: No valid partition found
Does this mean that my model is too large for the Hailo platform to accept? This problem has been bothering me for several months, and I would be very grateful if anyone could help me!
Fan Xiaoqin
Hey @user61,
This error is due to resource constraints or model size exceeding available memory.
Can you try the following to fix the issue:
1. Enable Context Switching
context_switch_param(mode=enabled)
or let the compiler decide:
context_switch_param(mode=allowed)
2. Manage Memory Usage
allocator_param(automatic_ddr=False)
3. Extend Compilation Timeout
allocator_param(timeout=3h)
4. Optimize Resource Allocation
resources_param(strategy=greedy, max_compute_utilization=0.8, max_memory_utilization=0.75)
5. Enable Multi-Context Merging
context_switch_param(allow_auto_merge_in_multicontext=True)
If the issue persists, can you share a profile or Netron view of the model?
orima,We had a private message before :smiling_face_with_tear:
