slight_smile: ello,
I have a small (12 MB) segformer b0 onnx file.
I managed to create its har file and the quantized model. -![]()
But I am failing in the mapping while creating the final hef file.
here is my trace log:
(hcompiler2) nuchailo1@nuchailo1:~/PycharmProjects/hcompiler2$ hailo compiler mapcoresegformer_small_optimized.har
[info] Current Time: 11:47:29, 08/15/24
[info] CPU: Architecture: x86_64, Model: 13th Gen Intel(R) Core™ i7-1360P, Number Of Cores: 16, Utilization: 0.3%
[info] Memory: Total: 15GB, Available: 9GB
[info] System info: OS: Linux, Kernel: 6.5.0-45-generic
[info] Hailo DFC Version: 3.28.0
[info] PCIe: 0000:57:00.0: Number Of Lanes: 1, Speed: 8.0 GT/s PCIe
[info] Running hailo compiler mapcoresegformer_small_optimized.har
[info] Compiling network
[warning] Failed to add spatial reshapes
[info] Adding collapsed format conversion after conv_feature_splitter1_2
[info] Adding collapsed format conversion after conv_feature_splitter2_2
[error] Mapping Failed (allocation time: 31s)
No successful assignment for: format_conversion11
[error] BackendAllocatorException: Compilation failed: No successful assignment for: format_conversion11
Any idea what can I do to make this process finished successfully?
Thanks in advanced,
David
