Joining multiple models into a single context
Following the info in another thread I have successfully combined two small models into a single context HEF.
how-to-quickly-switch-and-execute-two-single-context-hef-models
My application actually requires switching between 3 small models and I am sure they would fit within a single context as they are only 1MB in size each. Is it possible to call Join() twice to combine a third model into the context?
Hi @c_d,
Great job on successfully combining two models! We’re excited to see the full project you’re working on—it sounds promising!
To answer your question: Yes, you can combine multiple smaller models, including a third one, into a single HEF context file by using the Join() function in the HailoRT API. This function lets you integrate multiple models into a shared context, allowing them to execute within the same HEF.
Best Regards
Thanks @omria,
Any hints on how to achieve this? I checked the API docs and join() appears to only work on two networks at a time. Trying to call join() again on an already joined network throws an error:
in join
    raise UnsupportedRunnerJoinException(
hailo_sdk_client.runner.exceptions.UnsupportedRunnerJoinException: Joining runners is only allowed when both contain native graphs, or both contain quantized graphs
@omria Bump, I could use some help with this please. I haven’t worked out how to achieve it yet.
