Issue of Bounding Box Temporarily Remaining When Object Disappears
I have noticed that when the first object class in the object detection model disappears from the screen, the bounding box does not disappear immediately but remains on the screen for about 1 to 2 seconds.
I have currently tested three models: “https://hailo-model-zoo.s3.eu-west-2.amazonaws.com/ModelZoo/Compiled/v2.15.0/hailo8l/yolov8s.hef”, “https://hailo-model-zoo.s3.eu-west-2.amazonaws.com/ModelZoo/Compiled/v2.15.0/hailo8l/yolov8m.hef”, and “yolov8s-hailo8l-barcode.hef”. All three models exhibit the issue I described. (I forgot whether “yolov8s-hailo8l-barcode.hef” was obtained from “hailo-rpi5-examples” or “Hailo-Application-Code-Examples”).
The program I am currently using is located in the hailo-rpi5-examples/basic_pipelines/detection.py file from “https://github.com/hailo-ai/hailo-rpi5-example”.
By the way, this problem occurs regardless of whether it is in the native window display of this program or in a window generated using “–use-frame”.
Below is my current code (hailo-rpi5-examples/basic_pipelines/detection.py):
import gi
import os
import cv2
import hailo
import time
from hailo_apps_infra.hailo_rpi_common import (
    get_caps_from_pad,
    get_numpy_from_buffer,
    app_callback_class,
from hailo_apps_infra.detection_pipeline import GStreamerDetectionApp
    def __init__(self):
        super().__init__()
        self.fps = 0.0
        self.fps_step = 10
        self.last_fps_time = time.time()
    buffer = info.get_buffer()
    if buffer is None:
        return Gst.PadProbeReturn.OK
    user_data.increment()
    frame_count = user_data.get_count()
    fmt, width, height = get_caps_from_pad(pad)
    frame = None
    if user_data.use_frame and fmt and width and height:
        frame = get_numpy_from_buffer(buffer, fmt, width, height)
    roi        = hailo.get_roi_from_buffer(buffer)
    now = time.time()
    if user_data.use_frame and frame is not None:
        label_list     = ["person", "car", "barcode", "QR code"]
        best_detections = {}
        filtered_detections = None
        # print(f"detections:{len(detections)}")
        for det in detections:
            lbl = det.get_label()
            if lbl not in label_list:
                continue
            # track_id
            track_id = 0
            track    = det.get_objects_typed(hailo.HAILO_UNIQUE_ID)
            for i in range(len(track)):
                print(track[0].get_id())
            if len(track) == 1:
                track_id = track[0].get_id()
            # bbox
            bbox = det.get_bbox()
            x1, y1 = bbox.xmin()*width, bbox.ymin()*height
            x2, y2 = bbox.xmax()*width, bbox.ymax()*height
            color = (255,0,0)
            cv2.rectangle(frame,
                        (int(x1), int(y1)),
                        (int(x2), int(y2)),
                        color, 2)
            cv2.putText(frame,
                        f"{lbl}, {track_id}",
                        (int(x1), int(y1)-5),
                        cv2.FONT_HERSHEY_SIMPLEX,
                        0.5, color, 1)
    # FPS display
        if frame_count % user_data.fps_step == 0:
            dt = now - user_data.last_fps_time
            if dt > 0:
                user_data.fps = user_data.fps_step / dt
            user_data.last_fps_time = now
        cv2.putText(frame,
                    f"FPS:{user_data.fps:.2f}",
                    (10,30),
                    0.7, (255,255,255), 2)
        user_data.set_frame(frame)
if __name__ == "__main__":
    Gst.init(None)
    app.run()
Also, I would like to ask where I can find “hailo.HAILO_UNIQUE_ID”?
Please let me know if you need more information regarding this issue.
