Getting actual bounding box, for object detection with raspberry pi
Im trying to know the position of detection object in the frame. I need help to understand the format of HailoBbox.
My result:
Frame count: 186
Detection 0: Label = Spantile, BBox = <hailo.HailoBBox(140733461937616)>, Confidence = 0.97
Total detections: 1
Frame count: 187
Detection 0: Label = Spantile, BBox = <hailo.HailoBBox(140733461935024)>, Confidence = 0.97
Total detections: 1
Frame count: 188
Detection 0: Label = Spantile, BBox = <hailo.HailoBBox(140733461937584)>, Confidence = 0.97
Total detections: 1
Frame count: 189
Detection 0: Label = Spantile, BBox = <hailo.HailoBBox(140733461935152)>, Confidence = 0.97
Total detections: 1
FPS: 30.10, Droprate: 0.00, Avg FPS: 30.25
My detection code:
    buffer = info.get_buffer()
    if buffer is None:
        return Gst.PadProbeReturn.OK
    # Using the user_data to count the number of frames
    user_data.increment()
    string_to_print = f"Frame count: {user_data.get_count()}\n"
    # Get the caps from the pad
    # Get the video frame from the buffer if needed
    frame = None
    # Parse the detections and output detailed info
    detection_count = 0
    for detection in detections:
        label = detection.get_label()
        bbox = detection.get_bbox()  # (x_min, y_min, x_max, y_max)
        string_to_print += f"Detection {detection_count}: Label = {label}, BBox = {bbox}, Confidence = {confidence:.2f}\n"
        detection_count += 1
    if detection_count > 0:
        string_to_print += f"Total detections: {detection_count}\n"
    # If frame is used, annotate and convert it
    if user_data.use_frame and frame is not None:
        user_data.set_frame(frame)
    print(string_to_print)
Hey @nasirmohidin93,
To check how to work with the HailoBBox and how to use it, you can refer to the following example code:
These examples will show you how to use and display the detections you get using the HailoBBox.
Please let me know if you have any other questions.
Best regards,
Thanks it is very helpful!
Hi @nasirmohidin93
I have seen the examples, but unfortunately they are beyond my knowledge.
Can you show me your Python script with which you got the x_min, y_min, x_max, y_max of the bounding box.
Thank you
Hello, can someone please help me here. I have seen the examples given. However, I am not able to determine the coordinates of the bounding boxes. - A Python script would be helpful.
Maybe this helps, here is example how to get car box :
        if label == "car" and confidence >= 0.5:
            x1_norm = bbox.xmin()
            y1_norm = bbox.ymin()
            x2_norm = bbox.xmax()
            y2_norm = bbox.ymax()
            x1 = int(x1_norm * width)
            y1 = int(y1_norm * height)
            x2 = int(x2_norm * width)
            y2 = int(y2_norm * height)
            car_detection = (x1, y1, x2 - x1, y2 - y1)
Thank you very much!
Otto
