Hello community,
I’d like to share my experience building a minimal working example for owners of the Raspberry Pi 5 + HAILO AI HAT. This HOWTO covers the following:
- How to convert a YOLOv8n model into the
.HEFformat - How to run a simple inference on a test image, displaying the results both visually and in the console
- How to perform a basic comparison of the outputs from both the original and the compiled model
Background
My non-commercial project is focused on object detection and involves guiding a homemade laser to a detected target using real-time camera input. Since this system relies on Raspberry Pi (actually two of them), detection performance has a direct impact on the overall response time.
In an effort to boost FPS, I added the HAILO-8 based AI HAT.
The first logical step was:
- Run inference with my custom-trained YOLOv8n model using the HAILO chip
- Compare the detection outputs (bounding boxes, class IDs, confidence scores) against the original model
- Overlay the results for visual inspection
The Problem
As a result of my own impatience, the lack of structured documentation, and the fatigue that comes from infos being outdated or not matching reality, what seemed like a simple validation task quickly turned into a frustrating experience.
I found myself asking:
- Which parts of the HAILO software stack are actually required, do I need them at all?
- Where can I get them, how do I install them, and where exactly should they go?
- How do I properly convert my YOLOv8n model to
.HEF, and what should I do when it throws conversion errors? - Is there a simple inference script to compare outputs from the original and compiled models?
Sure, maybe I wasn’t looking in the right places. But between outdated blog posts, contradictory forum advice, and a repo jungle, I ended up installing a pile of useless packages, chasing error messages across modules, and reinventing workarounds that probably already exist.
Eventually, I managed to build a minimal working example — and this post is for anyone who’s trying to do the same, without spending days navigating the same rabbit holes.
If you’re reading this and thinking, “It’s all documented!” — then congrats, you found the right docs. I didn’t.
