How to upgrade to pcie gen 3 in rpi5 with H8L M.2?
hello
i have bought the new raspberry pi 5 with Hailo8L M.2.
does the Hailo8L support the pcie gen 3 ? and how to upgrade to it ?
Hello
yes the Hailo8L with raspberry pi supports the pcie gen 3.
1- open the file /boot/firmware/config.txt for edit
2- under the line dtparam=pciex1 add the following line
dtparam=pciex1_gen=3
3- reboot rpi5
I think you also have to enable it in raspi-config
Both ways are valid. config.txt is the file where the actual configuration settings are stored, while raspi-config is a tool that helps users modify those settings more easily. The changes made using raspi-config are often reflected in config.txt.
