How to download the latest hailo_inintegration_tool tool
I saw on the official website that the latest version available for download is V1.17, but this version does not match the latest hailort_4.21.0 version
Hi @liu_bin,
I looked into this recently and found the following:
The tool you are referring to has been renamed from Hailo Integration Tool to Hailo Accelerator Integration Tool. You can find the latest version by typing “integration” into the software downloads search box.
According to the version compatibility table on the Hailo website, the latest version of the Hailo Accelerator Integration Tool is v1.20, which is compatible with HailoRT 4.20 and is part of the 2025-01 software suite.
However, when I download the User Guide via the “User Guide” button next to the software downloads, the downloaded documentation still shows version 1.18. So it’s not entirely clear to me whether the documentation simply hasn’t been updated yet or whether I’ve overlooked some information.
I assume that there is no version that officially supports HailoRT 4.21.0 yet, as I suspect that the Hailo Accelerator Integration Tool has a different release cycle when I look at the “Date Modified” field of the Hailo Accelerator Integration Tool.
@Hailo, may I ask for confirmation on:
  • Whether the Hailo Accelerator Integration Tool follows a different release cycle than the other components of the Hailo AI Software Suite releases?
  • And whether the latest available user guide is actually version 1.18.0, or whether there is a newer one?
Thank you very much and I hope this helps!
Hi lukascs,
thanks, I will first download the whl file of the integration_tool toolkit. By installing the whl file, I can use the Hailo int tool for testing.
However, the official website of the integration_tool toolkit only has the Hailo Integration Tool - Python package (whl) v1.6 version, and there is no latest version at all.
How can I download the whl file package of the latest integration_tool toolkit?
Hi @liu_bin,
As far as I know, there is no .whl available for the newer versions of the Hailo Accelerator Integration Tool (like v1.18 or v1.20). The latest .whl I’ve seen on the official site is still v1.6.
If you are using the Hailo module on an amd64 Ubuntu operating system, I would recommend using the .deb packages instead. These are available for newer versions and are easier to install on that platform.
If you are using a different platform, I recommend building the tool from source. The Hailo Accelerator Integration Tool is intended to characterize, validate and confirm platform compatibility with the Hailo 8 module. This process is typically required for custom platforms, where prebuilt packages may not be suitable. In such cases, compiling from source is often part of the standard integration workflow.
Also, I would recommend sticking to the version of the Hailo Accelerator Integration Tool that is listed in the compatibility table as being compatible with your HailoRT version. That’s usually the safest way to ensure everything works as expected.
I hope this helps!
Hi lukascs,
Why isn’t the Hailo-int tool available after installing the Hailo Integration Tool - Ubuntu package (deb) for amd64 v1.17?
I hope to use the hao lo int tool for stress testing.
