Installation of the Integration tool on Windows
Has anyone else experienced issues with the installation of the integration tool on windows? The instructions suggest running “hailo-integration-tool.exe” for the installation but this did not work for me and required a lot of manual copy and pasting into proper locations to get it working.
is this the error message you got:
“Caught exception: <can’t open C:\Program Files\hailo_integration_tool\template.html>”?
Case not, please elaborate per the exact errors you have seen.
The error mentioned above will be fixed in future release.
In order to work around this issue please create a directory hailo_integration_tool under C:\Program Files, and copy to it the template.html from the directory in which you have extracted the integration tool.
I encounter this error when running the integration tool.exe in Windows. Are there any suggestions?
Please make sure you have installed the correct version of the Hailo-RT library that works with the integration tool. The table below lists the compatibility requirements:
Hailo-RT version Integration tool version
4.18 1.18.0
4.19 1.19.0
4.20 1.20.0
As of today, since integration tool v1.20.0 is not yet available, please revert to Hailo-RT v.4.19, to run the integration tool v1.19.0 .
