How to compile a grayscale 1x1280x1280 YoloV8 model with DFC?
We are using Hailo DFC to compile a grayscale 1x1280x1280 YoloV8n model and end-up with the following error: “yolov8n/input_layer1 has 1 features and given 3 std values. They must be equal.”
What can we do to compile a grayscale model using Hailo DFC?
Thanks for your help,
Klaus
Output
Start run for network yolov8n … Initializing the hailo8l runner… [info] Translation started on ONNX model yolov8n [info] Restored ONNX model yolov8n (completion time: 00:00:00.06) WARNING: failed to run “Gather” op (name is “/model.22/Gather”), skip… WARNING: failed to run “Add” op (name is “/model.22/Add”), skip… WARNING: failed to run “Div” op (name is “/model.22/Div”), skip… WARNING: failed to run “Mul” op (name is “/model.22/Mul_1”), skip… WARNING: failed to run “Gather” op (name is “/model.22/Gather”), skip… WARNING: failed to run “Add” op (name is “/model.22/Add”), skip… WARNING: failed to run “Div” op (name is “/model.22/Div”), skip… WARNING: failed to run “Mul” op (name is “/model.22/Mul_1”), skip… [info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.38) [info] NMS structure of yolov8 (or equivalent architecture) was detected. [info] In order to use HailoRT post-processing capabilities, these end node names should be used: /model.22/cv3.0/cv3.0.2/Conv /model.22/cv2.0/cv2.0.2/Conv /model.22/cv2.1/cv2.1.2/Conv /model.22/cv3.1/cv3.1.2/Conv /model.22/cv3.2/cv3.2.2/Conv /model.22/cv2.2/cv2.2.2/Conv. [info] Start nodes mapped from original model: ‘images’: ‘yolov8n/input_layer1’. [info] End nodes mapped from original model: ‘/model.22/cv2.0/cv2.0.2/Conv’, ‘/model.22/cv3.0/cv3.0.2/Conv’, ‘/model.22/cv2.1/cv2.1.2/Conv’, ‘/model.22/cv3.1/cv3.1.2/Conv’, ‘/model.22/cv2.2/cv2.2.2/Conv’, ‘/model.22/cv3.2/cv3.2.2/Conv’. [info] Translation completed on ONNX model yolov8n (completion time: 00:00:01.07) [info] Saved HAR to: /home/jupyter/hailoTutorial/yolov8n.har Using generic alls script found in /home/jupyter/hailoTutorial/calbdata/hailo_model_zoo/hailo_model_zoo/cfg/alls/generic/yolov8n.alls because there is no specific hardware alls Preparing calibration data… [info] Loading model script commands to yolov8n from /home/jupyter/hailoTutorial/calbdata/hailo_model_zoo/hailo_model_zoo/cfg/alls/generic/yolov8n.alls [info] Loading model script commands to yolov8n from string Traceback (most recent call last): File “/opt/conda/bin/hailomz”, line 33, in sys.exit(load_entry_point(‘hailo-model-zoo’, ‘console_scripts’, ‘hailomz’)()) File “/home/jupyter/hailoTutorial/calbdata/hailo_model_zoo/hailo_model_zoo/main.py”, line 122, in main run(args) File “/home/jupyter/hailoTutorial/calbdata/hailo_model_zoo/hailo_model_zoo/main.py”, line 111, in run return handlersargs.command File “/home/jupyter/hailoTutorial/calbdata/hailo_model_zoo/hailo_model_zoo/main_driver.py”, line 250, in compile _ensure_optimized(runner, logger, args, network_info) File “/home/jupyter/hailoTutorial/calbdata/hailo_model_zoo/hailo_model_zoo/main_driver.py”, line 91, in _ensure_optimized optimize_model( File “/home/jupyter/hailoTutorial/calbdata/hailo_model_zoo/hailo_model_zoo/core/main_utils.py”, line 324, in optimize_model optimize_full_precision_model(runner, calib_feed_callback, logger, model_script, resize, input_conversion, classes) File “/home/jupyter/hailoTutorial/calbdata/hailo_model_zoo/hailo_model_zoo/core/main_utils.py”, line 310, in optimize_full_precision_model runner.optimize_full_precision(calib_data=calib_feed_callback) File “/opt/conda/lib/python3.10/site-packages/hailo_sdk_common/states/states.py”, line 16, in wrapped_func return func(self, *args, **kwargs) File “/opt/conda/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py”, line 1996, in optimize_full_precision self._optimize_full_precision(calib_data=calib_data, data_type=data_type) File “/opt/conda/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py”, line 1999, in _optimize_full_precision self._sdk_backend.optimize_full_precision(calib_data=calib_data, data_type=data_type) File “/opt/conda/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1497, in optimize_full_precision model, params = self._apply_model_modification_commands(model, params, update_model_and_params) File “/opt/conda/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py”, line 1388, in _apply_model_modification_commands model, params = command.apply(model, params, hw_consts=self.hw_arch.consts) File “/opt/conda/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/script_parser/model_modifications_commands.py”, line 324, in apply return norm_adder.add_normalization_layers() File “/opt/conda/lib/python3.10/site-packages/hailo_sdk_client/tools/normalization_layers_addition.py”, line 74, in add_normalization_layers raise NormalizationLayersAdditionException( hailo_sdk_client.tools.normalization_layers_addition.NormalizationLayersAdditionException: yolov8n/input_layer1 has 1 features and given 3 std values. They must be equal
Hi @Klaus,
According to the log file, you are using this model script from the Hailo Model Zoo.
That model script includes on-chip normalization on 3 channels:
Please make a copy of the model script, and modify the normalization command for a single input channel (i.e., single values of mean and standard deviation):
normalization1 = normalization([0.0], [255.0])
Finally, use the new model script for the model conversion.
Let me know if this works.
Thanks for your hint. We changed the normalization line to
normalization1 = normalization([0.0], [255.0]) and this avoided the old error message. But I received an new error message:
[info] Restored ONNX model yolov8n (completion time: 00:00:00.30)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.99)
[info] Translation completed on ONNX model yolov8n (completion time: 00:00:01.76)
run(args)
optimize_model(
File “/opt/conda/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/script_parser/nms_postprocess_command.py”, line 387, in apply
pp_creator = create_nms_postprocess(
File “/opt/conda/lib/python3.10/site-packages/hailo_sdk_client/tools/core_postprocess/nms_postprocess.py”, line 1767, in create_nms_postprocess
pp_creator.prepare_hn_and_weights(hw_consts, engine, dfl_on_nn_core=dfl_on_nn_core)
File “/opt/conda/lib/python3.10/site-packages/hailo_sdk_client/tools/core_postprocess/nms_postprocess.py”, line 1125, in prepare_hn_and_weights
super().prepare_hn_and_weights(
File “/opt/conda/lib/python3.10/site-packages/hailo_sdk_client/tools/core_postprocess/nms_postprocess.py”, line 1089, in prepare_hn_and_weights
self.add_postprocess_layer_to_hn()
File “/opt/conda/lib/python3.10/site-packages/hailo_sdk_client/tools/core_postprocess/nms_postprocess.py”, line 1040, in add_postprocess_layer_to_hn
raise NMSConfigPostprocessException(f"The layer {encoded_layer.name} doesn’t have one output layer")
hailo_sdk_client.tools.core_postprocess.nms_postprocess.NMSConfigPostprocessException: The layer yolov8n/conv41 doesn’t have one output layer
We tried to solve the error “The layer yolov8n/conv41 doesn’t have one output layer” by changing yolov8n.alls to the following content:
nms_postprocess(meta_arch=yolov8, engine=cpu)
allocator_param(width_splitter_defuse=disabled)
quantization_param([conv42, conv53, conv63], force_range_out=[0.0, 1.0])
and received the following error message:
[info] Restored ONNX model yolov8n (completion time: 00:00:00.07)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.43)
[info] Translation completed on ONNX model yolov8n (completion time: 00:00:01.19)
[info] The layer yolov8n/conv39 was detected as reg_layer.
run(args)
optimize_model(
File “/opt/conda/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/script_parser/nms_postprocess_command.py”, line 385, in apply
self._update_config_file(hailo_nn)
File “/opt/conda/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/script_parser/nms_postprocess_command.py”, line 546, in _update_config_file
self._update_config_layers(hailo_nn)
File “/opt/conda/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/script_parser/nms_postprocess_command.py”, line 596, in _update_config_layers
self._set_yolo_config_layers(hailo_nn)
File “/opt/conda/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/script_parser/nms_postprocess_command.py”, line 652, in _set_yolo_config_layers
self._set_anchorless_yolo_config_layer(branch_layers, decoder, f_out)
File “/opt/conda/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/script_parser/nms_postprocess_command.py”, line 698, in _set_anchorless_yolo_config_layer
raise AllocatorScriptParserException(msg)
hailo_sdk_client.sdk_backend.sdk_backend_exceptions.AllocatorScriptParserException: Cannot infer bbox conv layers automatically. Please specify the bbox layer in the json configuration file
Your help is very much appreciated!
Hi @Klaus,
Could you please paste the command you are using for the model conversion?
hailomz compile yolov8n --ckpt “./best.onnx” --hw-arch hailo8l --calib-path /home/jupyter/roboflow/grayscale/valid/images --classes 1 --performance
Hope that helps, @pierrem . Thanks, Klaus
@Klaus the model script you are using tries to add the NMS to the model and it seems something is wrong with it.
The NMS is not really part of the neural network, but it can be added at optimization time to be performed by HailoRT (engine=cpu, in this case).
I see that you changed the nms_postprocess command to use the automatic approach:
This is generally ok, but to be sure it is not causing any issue in this specific case, I would suggest trying with the NMS config JSON file.
nms_postprocess("../../postprocess_config/yolov8n_nms_config.json", meta_arch=yolov8, engine=cpu)
Please try the following:
  • Create a copy of the NMS config JSON
    • Modify the image_dims
    • Set classes to 1
    • Check if the output names changed (it seems like this, from your log), please open the HAR with Netron and adjust the reg_layer and cls_layer name in your config JSON accordingly
  • Create a copy of the model script and modify it this:
    change_output_activation(conv42, sigmoid) # change according to your model
    change_output_activation(conv53, sigmoid) # change according to your model
    change_output_activation(conv63, sigmoid) # change according to your model
    nms_postprocess("<PATH-TO-YOUR-NMS-CONFIG-JSON>", meta_arch=yolov8, engine=cpu)
  • Run the command
    hailomz compile yolov8n --ckpt “./best.onnx” --hw-arch hailo8l --calib-path /home/jupyter/roboflow/grayscale/valid/images --classes 1 --model-script <PATH-TO-YOUR-MODEL-SCRIPT>
@pierrem your hint solved our problem. Thanks a lot, Klaus
Hey, I’m trying the same except with yolov11x and 288x288 input size.
After issuing:
$ hailomz optimize --hw-arch hailo8 --har ./yolov11x.har --calib-path calib/ --model-script custom.alls yolov11x
I get the following error:
  File "/local/workspace/hailo_virtualenv/bin/hailomz", line 33, in <module>
  File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py", line 122, in main
    run(args)
  File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py", line 111, in run
  File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 225, in optimize
    optimize_model(
  File "/local/workspace/hailo_model_zoo/hailo_model_zoo/core/main_utils.py", line 353, in optimize_model
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 2201, in optimize
    result = self._optimize(
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 2020, in _optimize
    checkpoint_info = self._sdk_backend.full_quantization(
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py", line 1196, in full_quantization
    new_checkpoint_info = self._full_acceleras_run(
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py", line 1434, in _full_acceleras_run
    new_checkpoint_info = self._optimization_flow_runner(optimization_flow, checkpoint_info)
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py", line 2088, in _optimization_flow_runner
    optimization_flow.run()
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/tools/orchestator.py", line 239, in wrapper
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py", line 357, in run
    step_func()
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/tools/subprocess_wrapper.py", line 155, in parent_wrapper
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py", line 375, in step1
    self.pre_quantization_optimization()
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py", line 426, in pre_quantization_optimization
    self._collect_stats()
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py", line 503, in _collect_stats
    algo.run()
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/optimization_algorithm.py", line 55, in run
    return super().run()
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/algorithm_base.py", line 154, in run
    self._setup()
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/stats_collection/stats_collection.py", line 76, in _setup
    self.validate_shapes()
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/stats_collection/stats_collection.py", line 86, in validate_shapes
    layer.validate_shape(input_data[key])
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/acceleras/hailo_layers/hailo_io.py", line 209, in validate_shape
    raise BadInputsShape(self.full_name, input_shape, data_shape)
hailo_model_optimization.acceleras.utils.acceleras_exceptions.BadInputsShape: Data shape (288, 288, 3) for layer yolov11x/input_layer1 doesn't match network's input shape (288, 288, 1)
If this is about calibration set, I’m sure those are grayscale images.
Any idea how this can be fixed?
I was able to get a bit further by hardcoding image.set_shape((height, width, 1)) in def yolo_v5 ... in hailo_model_zoo/core/preprocessing/detection_preprocessing.py, but later I’m getting this error:
Calibration:   0%|        | 0/64 [00:00<?, ?entries/s]Traceback (most recent call last):
    run(args)
    optimize_model(
  File "/local/workspace/hailo_model_zoo/hailo_model_zoo/core/main_utils.py", line 355, in optimize_model
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py", line 358, in run
    step_func()
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py", line 376, in step1
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py", line 427, in pre_quantization_optimization
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/flows/optimization_flow.py", line 504, in _collect_stats
    algo.run()
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/algorithm_base.py", line 159, in run
    self._run_int()
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/stats_collection/stats_collection.py", line 41, in _run_int
    stats_collector.collect_stats(
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_model_optimization/acceleras/statistics/stats_collector.py", line 116, in collect_stats
    for preprocessed_data in calib_dataset:
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/tensorflow/python/data/ops/iterator_ops.py", line 797, in __next__
    return self._next_internal()
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/tensorflow/python/data/ops/iterator_ops.py", line 780, in _next_internal
    ret = gen_dataset_ops.iterator_get_next(
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/tensorflow/python/ops/gen_dataset_ops.py", line 3016, in iterator_get_next
    _ops.raise_from_not_ok_status(e, name)
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/tensorflow/python/framework/ops.py", line 7262, in raise_from_not_ok_status
    raise core._status_to_exception(e) from None  # pylint: disable=protected-access
tensorflow.python.framework.errors_impl.InvalidArgumentError: {{function_node __wrapped__IteratorGetNext_output_types_1_device_/job:localhost/replica:0/task:0/device:CPU:0}} Incompatible shapes at component 0: expected [?,288,288,1] but got [2,288,288]. [Op:IteratorGetNext]
We do not recommend modifying the Model Zoo code.
Instead, I suggest creating a new yolov11x.yaml and modify it according to your model’s needs.
The YAML structure is hierarchical. The yolov11x.yaml is based on the yolov8.yaml, which is derived from the yolo.yaml. The input shape is specified in yolo.yaml.
In your local copy of yolov11x.yaml, you can override the input shape in the preprocessing section:
preprocessing:
  network_type: detection
  input_shape:
  - 288
  - 288
  - 1
You should then pass the YAML file as an argument while running the conversion.
