Can we get any documentation as to how exactly TAPPAS’s hailogallery works? I am trying to get multiple embeddings for a single face to work but I can’t find any documentation as to what format hailogallery expects the gallery.json file to be in.
Hey @M_S
I Brought this up with our R&D and they will work on it.
HailoGallery in TAPPAS Framework
Overview
HailoGallery is a component within TAPPAS that enables:
- Saving and comparing embeddings for cross-stream object tracking
- Managing embeddings via local JSON files
- Object tracking using pre-saved embeddings
Key Parameters
- Class ID: Specifies classes to track (default: all classes)
- Similarity Threshold (similarity-thr): Float value (0-1) determining embedding similarity for ID matching
- Gallery Queue Size: Number of embeddings saved per global ID
- Load from Local Gallery: Option to load pre-existing embeddings from JSON file
Gallery JSON File Format
Typical structure includes:
- IDs: Unique object identifiers
- Embeddings: Arrays associated with each object
- Metadata: May include class IDs, timestamps, etc.
Usage Examples
Saving Faces: ./save_faces.sh --network scrfd_10g --cleanProcesses face images, stores embeddings in gallery JSON file
Loading a Gallery:
 Enableload-local-galleryparameter and specify gallery JSON file path
This setup facilitates efficient object recognition and tracking across multiple streams.
Best Regards,
Omri
Is there any new information on this? I figured two months may have been enough time for some more documentation to come out but I haven’t been able to find any.
Thank you
