* Copyright (c) 2021-2022 Hailo Technologies Ltd. All rights reserved.
* Distributed under the LGPL license (https://www.gnu.org/licenses/old-licenses/lgpl-2.1.txt)
// General includes
#include <iostream>
#include <vector>
// Hailo includes
#include "hailo_xtensor.hpp"
#include "common/math.hpp"
#include "common/tensors.hpp"
#include "common/labels/coco_eighty.hpp"
#include "yolov8pose_postprocess.hpp"
#include "xtensor/xadapt.hpp"
#include "xtensor/xarray.hpp"
#include "xtensor/xcontainer.hpp"
#include "xtensor/xeval.hpp"
#include "xtensor/xtensor.hpp"
#include "xtensor/xindex_view.hpp"
#include "xtensor/xio.hpp"
#include "xtensor/xmanipulation.hpp"
#include "xtensor/xmasked_view.hpp"
#include "xtensor/xoperation.hpp"
#include "xtensor/xpad.hpp"
#include "xtensor/xrandom.hpp"
#include "xtensor/xshape.hpp"
#include "xtensor/xsort.hpp"
#include "xtensor/xstrided_view.hpp"
#include "xtensor/xview.hpp"
using namespace xt::placeholders;
#define SCORE_THRESHOLD 0.6
#define IOU_THRESHOLD 0.7
#define NUM_CLASSES 1
std::vector<std::pair<int, int>> JOINT_PAIRS = {
    {0, 1},
    // {1, 3}, {0, 2}, {2, 4},
    // {5, 6}, {5, 7}, {7, 9}, {6, 8}, {8, 10},
    // {5, 11}, {6, 12}, {11, 12},
    // {11, 13}, {12, 14}, {13, 15}, {14, 16}
std::pair<std::vector<KeyPt>, std::vector<PairPairs>> process_single_decoding(const Decodings& dec, const std::vector<int>& network_dims, float joint_threshold=0.5) {
    std::vector<KeyPt> keypoints;
    std::vector<PairPairs> pairs;
    auto keypoint_coordinates_and_score = dec.keypoints;
    auto coordinates = keypoint_coordinates_and_score.first;
    auto score = keypoint_coordinates_and_score.second;
    // Filter keypoints
    for (uint i = 0; i < score.shape(0); i++){
        if (score(i,0) > joint_threshold) {
            keypoints.push_back(KeyPt({coordinates(i, 0) / network_dims[0], coordinates(i, 1) / network_dims[1], score(i,0)}));
    // Filter joints pair
    for (const auto& pair : JOINT_PAIRS) {
        if (score(pair.first,0) >= joint_threshold && score(pair.second, 0) >= joint_threshold){
            PairPairs pr = PairPairs({
                            std::make_pair(coordinates(pair.first,0) / network_dims[0], coordinates(pair.first,1) / network_dims[1]),
                            std::make_pair(coordinates(pair.second,0) / network_dims[0], coordinates(pair.second,1) / network_dims[1]),
                            score(pair.first, 0),
            pairs.push_back(pr);
    return std::make_pair(keypoints, pairs);
// filter keypoints iterates over all decodings
std::pair<std::vector<KeyPt>, std::vector<PairPairs>> filter_keypoints(const std::vector<Decodings>& filtered_decodings, const std::vector<int>& network_dims, float joint_threshold=0.5) {
    std::vector<KeyPt> filtered_keypoints;
    std::vector<PairPairs> filtered_pairs;
    for (const auto& dec : filtered_decodings){
        auto result = process_single_decoding(dec, network_dims, joint_threshold);
        filtered_keypoints.insert(filtered_keypoints.end(), result.first.begin(), result.first.end());
        filtered_pairs.insert(filtered_pairs.end(), result.second.begin(), result.second.end());
    return std::make_pair(filtered_keypoints, filtered_pairs);
float iou_calc(const HailoBBox &box_1, const HailoBBox &box_2)
    // Calculate IOU between two detection boxes
    const float width_of_overlap_area = std::min(box_1.xmax(), box_2.xmax()) - std::max(box_1.xmin(), box_2.xmin());
    const float height_of_overlap_area = std::min(box_1.ymax(), box_2.ymax()) - std::max(box_1.ymin(), box_2.ymin());
    const float positive_width_of_overlap_area = std::max(width_of_overlap_area, 0.0f);
    const float positive_height_of_overlap_area = std::max(height_of_overlap_area, 0.0f);
    const float area_of_overlap = positive_width_of_overlap_area * positive_height_of_overlap_area;
    const float box_1_area = (box_1.ymax() - box_1.ymin()) * (box_1.xmax() - box_1.xmin());
    const float box_2_area = (box_2.ymax() - box_2.ymin()) * (box_2.xmax() - box_2.xmin());
    // The IOU is a ratio of how much the boxes overlap vs their size outside the overlap.
    // Boxes that are similar will have a higher overlap threshold.
    return area_of_overlap / (box_1_area + box_2_area - area_of_overlap);
std::vector<Decodings> nms(std::vector<Decodings> &decodings, const float iou_thr, bool should_nms_cross_classes = false) {
    std::vector<Decodings> decodings_after_nms;
    for (uint index = 0; index < decodings.size(); index++)
        if (decodings[index].detection_box.get_confidence() != 0.0f)
            for (uint jindex = index + 1; jindex < decodings.size(); jindex++)
                if ((should_nms_cross_classes || (decodings[index].detection_box.get_class_id() == decodings[jindex].detection_box.get_class_id())) &&
                    decodings[jindex].detection_box.get_confidence() != 0.0f)
                    // For each detection, calculate the IOU against each following detection.
                    float iou = iou_calc(decodings[index].detection_box.get_bbox(), decodings[jindex].detection_box.get_bbox());
                    // If the IOU is above threshold, then we have two similar detections,
                    // and want to delete the one.
                    if (iou >= iou_thr)
                        // The detections are arranged in highest score order,
                        // so we want to erase the latter detection.
                        decodings[jindex].detection_box.set_confidence(0.0f);
            decodings_after_nms.push_back(Decodings{decodings[index].detection_box, decodings[index].keypoints, decodings[index].joint_pairs});
    return decodings_after_nms;
float dequantize_value(uint8_t val, float32_t qp_scale, float32_t qp_zp){
    return (float(val) - qp_zp) * qp_scale;
void dequantize_box_values(xt::xarray<float>& dequantized_outputs, int index,
                        xt::xarray<uint8_t>& quantized_outputs,
                        size_t dim1, size_t dim2, float32_t qp_scale, float32_t qp_zp){
    for (size_t i = 0; i < dim1; i++){
        for (size_t j = 0; j < dim2; j++){
            dequantized_outputs(i, j) = dequantize_value(quantized_outputs(index, i, j), qp_scale, qp_zp);
std::vector<xt::xarray<double>> get_centers(std::vector<int>& strides, std::vector<int>& network_dims,
                                        std::size_t boxes_num, int strided_width, int strided_height){
        std::vector<xt::xarray<double>> centers(boxes_num);
        for (uint i=0; i < boxes_num; i++) {
            strided_width = network_dims[0] / strides[i];
            strided_height = network_dims[1] / strides[i];
            // Create a meshgrid of the proper strides
            xt::xarray<int> grid_x = xt::arange(0, strided_width);
            xt::xarray<int> grid_y = xt::arange(0, strided_height);
            auto mesh = xt::meshgrid(grid_x, grid_y);
            grid_x = std::get<1>(mesh);
            grid_y = std::get<0>(mesh);
            // Use the meshgrid to build up box center prototypes
            auto ct_row = (xt::flatten(grid_y) + 0.5) * strides[i];
            auto ct_col = (xt::flatten(grid_x) + 0.5) * strides[i];
            centers[i] = xt::stack(xt::xtuple(ct_col, ct_row, ct_col, ct_row), 1);
        return centers;
std::vector<Decodings> decode_boxes_and_keypoints(std::vector<HailoTensorPtr> raw_boxes_outputs,
        xt::xarray<float> scores,
        std::vector<HailoTensorPtr> raw_keypoints,
        std::vector<int> network_dims,
        std::vector<int> strides,
        int regression_length) {
    int strided_width =-1;
    int strided_height = -1;
    int class_index = 0;
    std::vector<Decodings> decodings;
    std::vector<PairPairs> joint_pairs;
    int instance_index = 0;
    float confidence = 0.0;
    std::string label;
    auto centers = get_centers(std::ref(strides), std::ref(network_dims), raw_boxes_outputs.size(), strided_width, strided_height);
    // Box distribution to distance
    auto regression_distance =  xt::reshape_view(xt::arange(0, regression_length + 1), {1, 1, regression_length + 1});
    for (uint i = 0; i < raw_boxes_outputs.size(); i++)
        // Boxes setup
        float32_t qp_scale = raw_boxes_outputs[i]->vstream_info().quant_info.qp_scale;
        float32_t qp_zp = raw_boxes_outputs[i]->vstream_info().quant_info.qp_zp;
        auto output_b = common::get_xtensor(raw_boxes_outputs[i]);
        int num_proposals = output_b.shape(0) * output_b.shape(1);
        auto output_boxes = xt::view(output_b, xt::all(), xt::all(), xt::all());
        xt::xarray<uint8_t> quantized_boxes = xt::reshape_view(output_boxes, {num_proposals, 4, regression_length + 1});
        auto shape = {quantized_boxes.shape(1), quantized_boxes.shape(2)};
        // Keypoints setup
        float32_t qp_scale_kpts = raw_keypoints[i]->vstream_info().quant_info.qp_scale;
        float32_t qp_zp_kpts = raw_keypoints[i]->vstream_info().quant_info.qp_zp;
        auto output_keypoints = common::get_xtensor(raw_keypoints[i]);
        int num_proposals_keypoints = output_keypoints.shape(0) * output_keypoints.shape(1);
        auto output_keypoints_quantized = xt::view(output_keypoints, xt::all(), xt::all(), xt::all());
        xt::xarray<uint8_t> quantized_keypoints = xt::reshape_view(output_keypoints_quantized, {num_proposals_keypoints, 2, 3});
        auto keypoints_shape = {quantized_keypoints.shape(1), quantized_keypoints.shape(2)};
        // Bbox decoding
        for (uint j = 0; j < uint(num_proposals); j++) {
            confidence =    xt::row(scores, instance_index)(0);
            instance_index++;
            if (confidence < SCORE_THRESHOLD)
                continue;
            xt::xarray<float> box(shape);
            xt::xarray<float> kpts_corrdinates_and_scores(keypoints_shape);
            dequantize_box_values(box, j, quantized_boxes,
                                    box.shape(0), box.shape(1),
                                    qp_scale, qp_zp);
            common::softmax_2D(box.data(), box.shape(0), box.shape(1));
            auto box_distance = box * regression_distance;
            xt::xarray<float> reduced_distances = xt::sum(box_distance, {2});
            auto strided_distances = reduced_distances * strides[i];
            // Decode box
            auto distance_view1 = xt::view(strided_distances, xt::all(), xt::range(_, 2)) * -1;
            auto distance_view2 = xt::view(strided_distances, xt::all(), xt::range(2, _));
            auto distance_view = xt::concatenate(xt::xtuple(distance_view1, distance_view2), 1);
            auto decoded_box = centers[i] + distance_view;
            HailoBBox bbox(decoded_box(j, 0) / network_dims[0],
                           decoded_box(j, 1) / network_dims[1],
                           (decoded_box(j, 2) - decoded_box(j, 0)) / network_dims[0],
                           (decoded_box(j, 3) - decoded_box(j, 1)) / network_dims[1]);
            label = common::coco_eighty[class_index + 1];
            HailoDetection detected_instance(bbox, class_index, label, confidence);
            // Decode keypoints
            dequantize_box_values(kpts_corrdinates_and_scores, j, quantized_keypoints,
                                    kpts_corrdinates_and_scores.shape(0), kpts_corrdinates_and_scores.shape(1),
                                    qp_scale_kpts, qp_zp_kpts);
            auto kpts_corrdinates = xt::view(kpts_corrdinates_and_scores, xt::all(), xt::range(0, 2));
            auto keypoints_scores = xt::view(kpts_corrdinates_and_scores, xt::all(), xt::range(2, xt::placeholders::_));
            kpts_corrdinates *= 2;
            auto center = xt::view(centers[i], xt::all(), xt::range(0, 2));
            auto center_values = xt::xarray<float>{(float)center(j,0), (float)center(j,1)};
            kpts_corrdinates = strides[i] * (kpts_corrdinates - 0.5) + center_values;
            // Apply sigmoid to keypoints scores
            auto sigmoided_scores = 1 / (1 + xt::exp(-keypoints_scores));
            auto keypoint = std::make_pair(kpts_corrdinates, sigmoided_scores);
            decodings.push_back(Decodings{detected_instance, keypoint, joint_pairs});
    return decodings;
Triple get_boxes_scores_keypoints(std::vector<HailoTensorPtr> &tensors, int num_classes, int regression_length){
    std::vector<HailoTensorPtr> outputs_boxes(tensors.size() / 3);
    std::vector<HailoTensorPtr> outputs_keypoints(tensors.size() / 3);
    // Prepare the scores xarray at the size we will fill in in-place
    int total_scores = 0;
    for (uint i = 0; i < tensors.size(); i = i + 3) {
        total_scores += tensors[i+1]->width() * tensors[i+1]->height();
    std::vector<size_t> scores_shape = { (long unsigned int)total_scores, (long unsigned int)num_classes};
    xt::xarray<float> scores(scores_shape);
    int view_index_scores = 0;
        // Bounding boxes extraction will be done later on only on the boxes that surpass the score threshold
        outputs_boxes[i / 3] = tensors[i];
        // Extract and dequantize the scores outputs
        auto dequantized_output_s = common::dequantize(common::get_xtensor(tensors[i+1]), tensors[i+1]->vstream_info().quant_info.qp_scale, tensors[i+1]->vstream_info().quant_info.qp_zp);
        int num_proposals_scores = dequantized_output_s.shape(0)*dequantized_output_s.shape(1);
        // From the layer extract the scores
        auto output_scores = xt::view(dequantized_output_s, xt::all(), xt::all(), xt::all());
        xt::view(scores, xt::range(view_index_scores, view_index_scores + num_proposals_scores), xt::all()) = xt::reshape_view(output_scores, {num_proposals_scores, num_classes});
        view_index_scores += num_proposals_scores;
        // Keypoints extraction will be done later according to the boxes that surpass the threshold
        outputs_keypoints[i / 3] = tensors[i+2];
    return Triple{outputs_boxes, scores, outputs_keypoints};
std::vector<Decodings> yolov8pose_postprocess(std::vector<HailoTensorPtr> &tensors,
                                int regression_length,
                                int num_classes)
    if (tensors.size() == 0)
        return decodings;
    Triple boxes_scores_keypoints = get_boxes_scores_keypoints(tensors, num_classes, regression_length);
    std::vector<HailoTensorPtr> raw_boxes = boxes_scores_keypoints.boxes;
    xt::xarray<float> scores = boxes_scores_keypoints.scores;
    std::vector<HailoTensorPtr> raw_keypoints = boxes_scores_keypoints.keypoints;
    // Decode the boxes and keypoints
    decodings = decode_boxes_and_keypoints(raw_boxes, scores, raw_keypoints, network_dims, strides, regression_length);
    // Filter with NMS
    auto decodings_after_nms = nms(decodings, IOU_THRESHOLD, true);
 * @brief yolov8 postprocess
 *        Provides network specific paramters
 * @param roi  -  HailoROIPtr
 *        The roi that contains the ouput tensors
std::pair<std::vector<KeyPt>, std::vector<PairPairs>> yolov8(HailoROIPtr roi)
    // anchor params
    int regression_length = 15;
    std::vector<int> strides = {8, 16, 32};
    std::vector<int> network_dims = {640, 640};
    std::vector<HailoTensorPtr> tensors = roi->get_tensors();
    auto filtered_decodings = yolov8pose_postprocess(tensors, network_dims, strides, regression_length, NUM_CLASSES);
    std::vector<HailoDetection> detections;
    for (auto& dec : filtered_decodings){
        HailoDetection detection = dec.detection_box;
        std::pair<std::vector<KeyPt>, std::vector<PairPairs>> keypoints_and_pairs = process_single_decoding(dec, network_dims, 0.0f);
        std::vector<KeyPt> scaled_keypoints = keypoints_and_pairs.first;
        // Create an empty xarray with the correct shape
        // xt::xarray<float> landmarks = xt::empty<float>({18, 3});
        xt::xarray<float> landmarks = xt::empty<float>({int(scaled_keypoints.size()), 3});
        // Fill the xarray with the data from the vector
        for (size_t i = 0; i < scaled_keypoints.size(); ++i) {
            landmarks(i, 0) = scaled_keypoints[i].xs;
            landmarks(i, 1) = scaled_keypoints[i].ys;
            landmarks(i, 2) = scaled_keypoints[i].joints_scores;
        hailo_common::add_landmarks_to_detection(detection, "centerpose", landmarks, SCORE_THRESHOLD, JOINT_PAIRS);
        detections.push_back(detection);
    hailo_common::add_detections(roi, detections);
    std::pair<std::vector<KeyPt>, std::vector<PairPairs>> keypoints_and_pairs = filter_keypoints(filtered_decodings, network_dims);
    return keypoints_and_pairs;
//  DEFAULT FILTER
void filter(HailoROIPtr roi)
    yolov8(roi);
I have changed JOINT_PAIRS
    {0, 1},
and
xt::xarray<uint8_t> quantized_keypoints = xt::reshape_view(output_keypoints_quantized, {num_proposals_keypoints, 2, 3});   // 17 -> 2(My custom keypoints)
I am using hailo-rpi5-examples/compile_postprocess.sh at main · hailo-ai/hailo-rpi5-examples · GitHub to compile.
There is another issue as well. I am getting the two points values are almost same.
