Tensors are in different format in hailonet and Hailo async Inference callback
@user313
Thank you for the response. I will try adding copy=False.
I have also issue with yolov8_pose_postprocess due to quantization and please see this thread…
Due to this the points are incorrect. And I am unable to use 16bit precision mode with that. Can you tell me how to fix that? I can update and rebuild the so library. I will also prefer to use library if this issue is solved.
