I would like to write an object recognition code by referring to the address python postprocess writing method below.
Module code
import hailo
from gsthailo import VideoFrame
from gi.repository import Gst
def run(video_frame: VideoFrame):
try:
# Get the ROI from the VideoFrame
roi = video_frame.roi
# Retrieve tensors from the ROI
tensors = roi.get_tensors()
# Debugging: Print available tensor names
print("Available tensors:")
for tensor in tensors:
print(f"Tensor name: {tensor.name()}")
# Locate the specific tensor
output_tensor = None
if tensor.name() == "yolov8n/yolov8_nms_postprocess":
output_tensor = tensor
break
if not output_tensor:
print("Output tensor 'yolov8s/yolov8_nms_postprocess' not found!")
return Gst.FlowReturn.OK
# Convert tensor to a numpy array
tensor_array = np.array(output_tensor, copy=False)
# Ensure the tensor is not empty
if tensor_array.size == 0:
print(f"Tensor '{output_tensor.name()}' is empty. Check the input data and model configuration.")
print(f"Tensor shape: {output_tensor.height()}x{output_tensor.width()}x{output_tensor.features()}")
# Process each detection in the tensor
for detection in tensor_array:
if len(detection) < 6:
print(f"Invalid detection data: {detection}")
continue
# Unpack detection data
xmin, ymin, xmax, ymax, confidence, class_id = detection[:6]
# Filter detections by confidence threshold
if confidence < 0.5: # Example confidence threshold
continue
# Create a bounding box
bbox = hailo.HailoBBox(xmin=float(xmin), ymin=float(ymin),
width=float(xmax - xmin), height=float(ymax - ymin))
# Map class_id to a label (example mapping, replace with your own)
label_map = {0: "person", 1: "bicycle", 2: "car"} # Example class labels
label = label_map.get(int(class_id), "unknown")
# Create a detection object
detection_obj = hailo.HailoDetection(bbox=bbox, label=label, confidence=float(confidence))
# Add detection to the ROI
roi.add_object(detection_obj)
except Exception as e:
print(f"Error during object detection: {e}")
Execution Code
import gi
Gst.init(None)
def main():
device = "/dev/video0"
hef_path = "yolov8n.hef"
python_module = "test.py"
pipeline_str = f"""
v4l2src device={device} ! video/x-raw, width=640, height=480, format=YUY2 ! queue !
videoconvert ! videoflip video-direction=horiz ! video/x-raw, format=RGB, width=640, height=480 ! queue !
videoscale ! video/x-raw, format=RGB, width=640, height=640 ! queue !
hailonet hef-path={hef_path} batch-size=1 ! video/x-raw, format=RGB, width=640, height=640 ! queue !
hailopython module={python_module} ! hailooverlay font-thickness=2 line-thickness=1 ! videoconvert ! autovideosink sync=false
print(f"Pipeline: {pipeline_str}")
pipeline = Gst.parse_launch(pipeline_str)
pipeline.set_state(Gst.State.PLAYING)
bus = pipeline.get_bus()
message = bus.timed_pop_filtered(
Gst.CLOCK_TIME_NONE,
Gst.MessageType.EOS | Gst.MessageType.ERROR
if message.type == Gst.MessageType.ERROR:
err, debug = message.parse_error()
print(f"Error: {err}, {debug}")
elif message.type == Gst.MessageType.EOS:
print("End of stream")
pipeline.set_state(Gst.State.NULL)
if __name__ == "__main__":
main()
The part where the model is read is successful, but the tensor is said to be empty.
Available tensors:
Tensor name: yolov8n/yolov8_nms_postprocess
Tensor 'yolov8n/yolov8_nms_postprocess' is empty. Check the input data and model configuration.
Tensor shape: 2x100x0
Is there a way to solve this
