hailomz eval errors using VisDrone dataset
I have a yolo11n model finetuned on visdrone.
I downloaded the validation dataset manually then ran:
python create_visdrone_tfrecord.py -d=/local/shared_with_docker/VisDrone2019-DET-val val
which gave me the following output:
2025-03-10 22:30:22.796868: I tensorflow/core/util/port.cc:110] oneDNN custom operations are on. You may see slightly different numerical results due to floating-point round-off errors from different computation orders. To turn them off, set the environment variable `TF_ENABLE_ONEDNN_OPTS=0`.
2025-03-10 22:30:22.821680: I tensorflow/core/platform/cpu_feature_guard.cc:182] This TensorFlow binary is optimized to use available CPU instructions in performance-critical operations.
To enable the following instructions: AVX2 AVX_VNNI FMA, in other operations, rebuild TensorFlow with the appropriate compiler flags.
2025-03-10 22:30:23.182437: W tensorflow/compiler/tf2tensorrt/utils/py_utils.cc:38] TF-TRT Warning: Could not find TensorRT
  0%|        | 0/548 [00:00<?, ?it/s]/local/workspace/hailo_model_zoo/hailo_model_zoo/datasets/create_visdrone_tfrecord.py:128: DeprecationWarning: tostring() is deprecated. Use tobytes() instead.
  "mask": _bytes_feature(np.array(0).tostring()),
100%|███████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 548/548 [00:00<00:00, 2008.95it/s]
Finished writing, skipped 1378 annotations.
38791 Annotations Found.
0 images are missing annotations.
I try to run using the detail models for yolo11n just to test the dataset, but run into this error:
!hailomz eval yolov11n --data-path=/local/shared_with_docker/.hailomz/models_files/visdrone/2020-05-25/visdrone_val.tfrecord
the full output is here:
<Hailo Model Zoo INFO> Start run for network yolov11n ...
<Hailo Model Zoo INFO> Initializing the runner...
<Hailo Model Zoo INFO> Chosen target is full_precision
[info] Translation started on ONNX model yolov11n
[info] Restored ONNX model yolov11n (completion time: 00:00:00.04)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.17)
[info] In order to use HailoRT post-processing capabilities, these end node names should be used: /model.23/cv3.0/cv3.0.2/Conv /model.23/cv2.0/cv2.0.2/Conv /model.23/cv3.1/cv3.1.2/Conv /model.23/cv2.1/cv2.1.2/Conv /model.23/cv2.2/cv2.2.2/Conv /model.23/cv3.2/cv3.2.2/Conv.
[info] Start nodes mapped from original model: 'images': 'yolov11n/input_layer1'.
[info] End nodes mapped from original model: '/model.23/cv2.0/cv2.0.2/Conv', '/model.23/cv3.0/cv3.0.2/Conv', '/model.23/cv2.1/cv2.1.2/Conv', '/model.23/cv3.1/cv3.1.2/Conv', '/model.23/cv2.2/cv2.2.2/Conv', '/model.23/cv3.2/cv3.2.2/Conv'.
[info] Translation completed on ONNX model yolov11n (completion time: 00:00:00.63)
[info] Appending model script commands to yolov11n from string
[info] Saved HAR to: /local/workspace/hailo_virtualenv/lib/python3.10/site-packages/hailo_tutorials/notebooks/yolov11n.har
[info] Loading model script commands to yolov11n from /local/workspace/hailo_model_zoo/hailo_model_zoo/cfg/alls/generic/yolov11n.alls
<Hailo Model Zoo INFO> Initializing the dataset ...
<Hailo Model Zoo INFO> Running inference...
[info] Setting NMS score threshold to 0.001
Processed: 0images [00:01, ?images/s]
  File "/local/workspace/hailo_virtualenv/bin/hailomz", line 33, in <module>
  File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py", line 122, in main
    run(args)
  File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py", line 111, in run
  File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 403, in evaluate
    return infer_model_tf2(
  File "/local/workspace/hailo_model_zoo/hailo_model_zoo/core/main_utils.py", line 522, in infer_model_tf2
    return infer_callback(
  File "/local/workspace/hailo_model_zoo/hailo_model_zoo/core/infer/model_infer.py", line 58, in model_infer
    for preprocessed_data, img_info in batched_dataset:
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/tensorflow/python/data/ops/iterator_ops.py", line 797, in __next__
    return self._next_internal()
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/tensorflow/python/data/ops/iterator_ops.py", line 780, in _next_internal
    ret = gen_dataset_ops.iterator_get_next(
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/tensorflow/python/ops/gen_dataset_ops.py", line 3016, in iterator_get_next
    _ops.raise_from_not_ok_status(e, name)
  File "/local/workspace/hailo_virtualenv/lib/python3.10/site-packages/tensorflow/python/framework/ops.py", line 7262, in raise_from_not_ok_status
    raise core._status_to_exception(e) from None  # pylint: disable=protected-access
tensorflow.python.framework.errors_impl.InvalidArgumentError: {{function_node __wrapped__IteratorGetNext_output_types_15_device_/job:localhost/replica:0/task:0/device:CPU:0}} Paddings must be non-negative: 0 -27
	 [[{{node PadV2_1}}]] [Op:IteratorGetNext]
/local/shared_with_docker/.hailomz/models_files/visdrone/2020-05-25/visdrone_val.tfrecord'
Hey @natsayin_nahin ,
The error “Paddings must be non-negative: 0 -27” occurs during dataset preprocessing. This indicates an issue with padding calculations in your TensorFlow operations.
This is likely caused by:
  • Mismatched image dimensions in your dataset
  • Calculation errors in padding values
  • Issues in your TFRecord file structure
We recommend:
  1. Verify all images have dimensions compatible with the model’s input requirements
  2. Review your create_visdrone_tfrecord.py script for correct TFRecord generation
  3. Ensure all padding operations use non-negative values
  4. Add debugging code to print image shapes before padding operations
As a possible solution, you could try using the Hailo Model Zoo’s provided scripts for creating properly formatted TFRecord files:
python hailo_model_zoo/datasets/create_visdrone_tfrecord.py train -d /path/to/VisDrone2019-DET-train
python hailo_model_zoo/datasets/create_visdrone_tfrecord.py val -d /path/to/VisDrone2019-DET-val
These scripts are designed to convert the dataset into a format suitable for evaluation, optimization, and compilation with our tools.
If you continue experiencing issues, please share your preprocessing code for more specific guidance.
Hi @omria, not sure if it wasn’t clear from the information provided - but I am using the hailo model zoon script, that is generating the very tfrecord file that causes the eval to fail.
The only difference in my cli command previously mentioned and your suggested one, was that I ran mine from within the hailo_model_zoo/datasets directory
So unless there are some additional preprocessing steps that need to be done on the visdrone dataset, then the issue surely has to be in the script? Since I’m not doing anything custom here
