Hi! I am having trouble running models that have been trained on image size 1088, compiled with hailomz on hailo devices. I use this command for compiling my models:
hailomz compile yolov8n --ckpt yolov8n_1088.onnx --hw-arch hailo8l --calib-path dataset_only_20_1088 --classes 8 --resize 1088
I have tried without the resize parameter as well. Also, I have tried with --performance flag. Please note that the calibration dataset that I provide is also 1088x1088 images. I get no errors while compiling.
When I run inference on my hailo device using the .hef model, the output tensors have bounding boxes outside of the boundaries. Example:
[0.27948668599128723, 1.413228988647461, 0.3169996738433838, 1.4515174627304077]
[0.2144680768251419, 1.666332721710205, 0.2797059118747711, 1.6999872922897339]
[0.41739657521247864, 1.6333305835723877, 0.4508034586906433, 1.664322853088379]
[0.6060263514518738, 1.0992581844329834, 0.6771869659423828, 1.180235743522644]
[0.6399933695793152, 1.6056666374206543, 0.7100033164024353, 1.6840683221817017]
[0.7627313137054443, 1.8049031496047974e-05, 1.0805031061172485, 0.10052971541881561]
[0.5417605638504028, -0.0013944879174232483, 0.7329568862915039, 0.2380548119544983]
[1.1810753345489502, 0.14888127148151398, 1.2470234632492065, 0.17751646041870117]
[1.1512645483016968, 0.17490966618061066, 1.218542218208313, 0.19973406195640564]
[1.151106357574463, 0.18052802979946136, 1.2170072793960571, 0.20563937723636627]
As you can see, some points are above 1, and some below 0. I have also tried printing the raw tensor outputs from the model and they show the same thing. What could be the problem? Do I compile the model wrong? Models trained on 640 images work perfectly fine
