I’m trying to convert a custom YOLOv8s model (exported to ONNX) for object detection with the following specs:
- Input size:
1024x768
- Number of classes:
- Standard Ultralytics export
When I run hailomz compile
(or through the Jupyter notebook pipeline), I get a parsing error:
ParsingWithRecommendationException: Parsing failed.
UnsupportedShuffleLayerError in op /model.22/dfl/Reshape:
Failed to determine type of layer to create in node /model.22/dfl/Reshape
Hailo recommends using /model.22/Concat_3
as end node. If I do that by editing the output nodes in the Jupiter Notebook
…then parsing succeeds (and suggests me to remove a lot of output layers agin and so on). But at that point I don’t know how to proceed:
- I’m unsure how to properly configure the rest of the pipeline (e.g., NMS, decoding).
- I’m also concerned that removing postprocess layers may break inference or outputs, as happened yet.
- The official examples don’t cover this edge case with YOLOv8 + custom input size + stripped output node.
Request
Is there someone available (Hailo team or community) who I could privately send:
- the
.onnx
model - the calibration dataset (1024+ real RGB frames)
and in return:
- get the model successfully converted (
.hef
) - along with a minimal working inference script
- and an explanation of how to treat these cases?
It’s just a bounding box of a single object.
Thanks in advance!
