Hello everyone! I’m running the Yolo detection program on a Raspberry Pi with Hailo 8 as the acceleration module. After about half an hour of operation, the detection froze . When I restarted, the system failed to detect the Hailo 8 module. Does anyone know why this happened? Is there a hardware issue? Could it be related to voltage or connectivity problems? Or perhaps other factors?(I’ve encountered similar issues when running Hailo 8L.)
error:( the detection froze and I operate to exit it)
HailoRT] [warning] Failed to acquire buffer because the buffer pool is empty. This could be caused by uneven reading and writing speeds, with a short user-defined timeout. (timeout=10000ms)
[HailoRT] [error] Non-recoverable Async Infer Pipeline error. status error code: HAILO_TIMEOUT(4)
[HailoRT] [error] Shutting down the pipeline with status HAILO_TIMEOUT(4)
[HailoRT] [error] CHECK_SUCCESS failed with status=HAILO_TIMEOUT(4) - Can’t handle inference request since pipeline status is HAILO_TIMEOUT(4).
QoS message received from source
CHECK_EXPECTED failed with status=4
CHECK_SUCCESS failed with status=4
[HailoRT] [warning] Failed to acquire buffer because the buffer pool is empty. This could be caused by uneven reading and writing speeds, with a short user-defined timeout. (timeout=10000ms)
[HailoRT] [critical] Failed to acquire from pool in LastAsyncEl0NmsPPMuxEl0YOLOV8-Post-Process element!
[HailoRT] [critical] Dequeueing external buffers failed with status HAILO_TIMEOUT(4)
Error: gst-resource-error-quark: Output window was closed (3), ../sys/xvimage/xvimagesink.c(586): gst_xv_image_sink_handle_xevents (): /GstPipeline:pipeline0/GstFPSDisplaySink:hailo_display/GstAutoVideoSink:autovideosink0/GstXvImageSink:autovideosink0-actual-sink-xvimage
Shutting down… Hit Ctrl-C again to force quit.
Exiting with error…
System shutdown complete
error:(restart)
(venv_hailo_rpi5_examples) junyan@raspberrypi:~/hailo/hailo-rpi5-examples $ source setup_env.sh
Setting up the environment…
Setting up the environment for hailo-tappas-core…
TAPPAS_VERSION is 3.31.0. Proceeding…
You are in the venv_hailo_rpi5_examples virtual environment.
TAPPAS_POST_PROC_DIR set to /usr/lib/aarch64-linux-gnu/hailo/tappas/post_processes
[HailoRT] [error] CHECK failed - Failed to open device file /dev/hailo0 with error 6
[HailoRT] [error] CHECK_SUCCESS failed with status=HAILO_DRIVER_OPERATION_FAILED(36)
[HailoRT CLI] [error] CHECK_SUCCESS failed with status=HAILO_DRIVER_OPERATION_FAILED(36)
Error: Device Architecture not found. Please check the connection to the device.
