Hello, I have the following question. I’m performing inference on Arducam frames. The format of the frames is XBGR8888 in Picamera2, which corresponds to a 32-bit RGB format (although this may seem counterintuitive, Picamera2 uses this convention).
The issue is that I need to convert the frames to RGB before passing them to hailo.run(). If I instead set the format to RGB directly and pass the frames as-is, I encounter an error.
I’m working on a Raspberry Pi Compute Module 4 (CM4). Could you please help me understand why this is happening? I’d also like to know if it’s possible to avoid the conversion step in order to save memory.
What is the expected input format for the hailo.run() function?
Thank you
picam2 = Picamera2()
# Configure and start Picamera2.
picam2.video_configuration.main.size = (video_w, video_h)
picam2.video_configuration.main.format = "XBGR8888" # this is RGB in Picamera2
picam2.configure("video")
# Generate control dictionary from yaml file
camera_control_dict = generate_controls_from_yaml(
args.config_file_path)
picam2.set_controls(camera_control_dict)
picam2.start()
while True:
# PREPROCESSING
rgb = cv2.cvtColor(frame, cv2.COLOR_BGR2RGB)
resized_frame = cv2.resize(rgb, (model_w, model_h))
# INFERENCE
results = hailo.run(resized_frame)
# Extract detections from the inference results
detections = extract_detections(
results, video_w, video_h, class_names, score_thresh
