I want to have create a custom software that takes the realtime feed from the picamer2 and does inference using the yolov8-8l hef on the hailo8l ai kit, and shows the object ddetected output on the screen, similar to what this command does but from my code
rpicam-hello -t 0 --post-process-file /usr/share/rpi-camera-assets/hailo_yolov8_inference.json
I tried this code -
import cv2
import picamera2
import libcamera
from hailo_platform import (
HEF, VDevice, HailoStreamInterface, InferVStreams,
ConfigureParams, InputVStreamParams, OutputVStreamParams,
InputVStreams, OutputVStreams, FormatType
class HailoYOLOInference:
def __init__(self, hef_path):
# Initialize Hailo device and model
self.target = VDevice()
self.hef = HEF(hef_path)
# Configure network groups
self.configure_params = ConfigureParams.create_from_hef(
hef=self.hef,
interface=HailoStreamInterface.PCIe
self.network_groups = self.target.configure(self.hef, self.configure_params)
self.network_group = self.network_groups[0]
# Create network group params
self.network_group_params = self.network_group.create_params()
# Get input and output stream info
self.input_vstream_info = self.hef.get_input_vstream_infos()[0]
self.output_vstream_infos = self.hef.get_output_vstream_infos()
# Print input and output stream information for debugging
print(f"Input stream shape: {self.input_vstream_info.shape}")
print(f"Input stream name: {self.input_vstream_info.name}")
print(f"Number of output streams: {len(self.output_vstream_infos)}")
for i, out_stream in enumerate(self.output_vstream_infos):
print(f"Output stream {i} name: {out_stream.name}, shape: {out_stream.shape}")
# Create input and output virtual stream parameters
self.input_vstreams_params = InputVStreamParams.make(
self.network_group,
format_type=FormatType.FLOAT32
self.output_vstreams_params = OutputVStreamParams.make(
self.network_group,
# Input image dimensions
self.input_height, self.input_width, self.input_channels = self.input_vstream_info.shape
def preprocess_frame(self, frame):
# Resize frame to model input size (640x640)
resized_frame = cv2.resize(frame, (self.input_width, self.input_height))
# Convert color space if needed (BGR to RGB)
preprocessed_frame = cv2.cvtColor(resized_frame, cv2.COLOR_BGR2RGB)
# Normalize pixel values (0-1)
normalized_frame = preprocessed_frame.astype(np.float32) / 255.0
# Ensure the frame matches the expected input shape
assert normalized_frame.shape == (self.input_height, self.input_width, self.input_channels), \
f"Input shape mismatch. Expected {(self.input_height, self.input_width, self.input_channels)}, got {normalized_frame.shape}"
return normalized_frame
def run_inference(self, preprocessed_frame):
# Prepare input data dictionary
# Ensure input is a 4D tensor with batch dimension
input_data = {
self.input_vstream_info.name: np.expand_dims(preprocessed_frame, axis=0)
# Use InferVStreams for inference
with InferVStreams(
self.network_group,
self.input_vstreams_params,
) as infer_pipeline:
# Activate network group
with self.network_group.activate(self.network_group_params):
# Run inference
# Return outputs for all output streams
return {
out_stream.name: infer_results[out_stream.name]
for out_stream in self.output_vstream_infos
def postprocess_results(self, outputs, original_frame):
# Iterate over output streams and convert lists to NumPy arrays
for stream_name, output in outputs.items():
output_array = np.array(output) # Convert to NumPy array
# Now you can safely access .shape and .dtype
print(f"Output stream {stream_name} shape: {output_array.shape}")
print(f"Output stream {stream_name} dtype: {output_array.dtype}")
# If you want to draw something on the frame
result_frame = original_frame.copy()
return result_frame
def main():
# Specify the exact path to your HEF file
HEF_PATH = '/usr/share/hailo-models/yolov8s_h8l.hef'
# Setup Picamera2
picam2 = picamera2.Picamera2()
config = picam2.create_preview_configuration(
main={"size": (1920, 1080)},
lores={"size": (640, 480)},
display="lores"
picam2.configure(config)
# Initialize Hailo inference
hailo_inference = HailoYOLOInference(hef_path=HEF_PATH)
# Start camera
picam2.start()
try:
while True:
# Capture frame
# Preprocess frame
preprocessed_frame = hailo_inference.preprocess_frame(frame)
# Run inference
outputs = hailo_inference.run_inference(preprocessed_frame)
# Postprocess and visualize results
result_frame = hailo_inference.postprocess_results(outputs, frame)
# Display frame
cv2.imshow('Hailo YOLOv8 Inference', result_frame)
# Exit on 'q' key press
break
finally:
# Cleanup
picam2.stop()
cv2.destroyAllWindows()
if __name__ == '__main__':
main()
The documentation is very unclear and there is no clear instructions on what code does what?
