Looking for a solution to yolov8n/yolov8_nms_postprocess related errors
yolov8n.hef
import cv2
import os, random, time
from hailo_platform import (HEF, Device, VDevice, HailoStreamInterface, InferVStreams, ConfigureParams,
InputVStreamParams, OutputVStreamParams, InputVStreams, OutputVStreams, FormatType)
yolox_s_leaky input resolution
INPUT_RES_H = 640
INPUT_RES_W = 640
Loading compiled HEFs to device:
hef_path = ‘yolov8n.hef’
video_file = “test1.mp4”
hef = HEF(hef_path)
devices = Device.scan()
with VDevice(device_ids=devices) as target:
configure_params = ConfigureParams.create_from_hef(hef, interface=HailoStreamInterface.PCIe)
input_vstreams_params = InputVStreamParams.make_from_network_group(network_group, quantized=False, format_type=FormatType.FLOAT32)
output_vstreams_params = OutputVStreamParams.make_from_network_group(network_group, quantized=False, format_type=FormatType.FLOAT32)
height, width, channels = hef.get_input_vstream_infos()[0].shape
    source = 'camera'
    cap = cv2.VideoCapture(video_file)
    # check if the camera was opened successfully
    if not cap.isOpened():
        print("Could not open camera")
        exit()
    start_time = time.time()
    frame_count = 0
    while True:
        # read a frame from the video source
        ret, frame = cap.read()
        # check if the frame was successfully read
        if not ret:
            print("Could not read frame")
            break
        frame_count += 1
        # Get height and width from capture
        orig_w = cap.get(cv2.CAP_PROP_FRAME_WIDTH)
        orig_h = cap.get(cv2.CAP_PROP_FRAME_HEIGHT)
        # loop if video source
        if source == 'video' and not cap.get(cv2.CAP_PROP_POS_FRAMES) % cap.get(cv2.CAP_PROP_FRAME_COUNT):
            cap.set(cv2.CAP_PROP_POS_FRAMES, 0)
        # resize image for yolox_s_leaky input resolution and infer it
        resized_img = cv2.resize(frame, (INPUT_RES_H, INPUT_RES_W), interpolation = cv2.INTER_AREA)
            input_data = {input_vstream_info.name: np.expand_dims(np.asarray(resized_img), axis=0).astype(np.float32)}
        print(infer_results['yolov8n/yolov8_nms_postprocess'])
        print("===========================")
        for key in infer_results.keys():
            for cls, results in enumerate(infer_results[key][0]):
                for x,y,w,h,conf in results:
                    if conf > 0.5:
                        x *= orig_w
                        y *= orig_h
                        w *= orig_w
                        h *= orig_h
                        cv2.rectangle(frame, (int(x-w/2),int(y-h/2)), (int(x+w/2),int(y+h/2)), (0,0,255), 2)
        cv2.imshow('frame',frame)
            cv2.destroyAllWindows()
            break
        avg_fps = frame_count / (time.time() - start_time)
        print(f"FPS = {avg_fps}")
An error occurs when running the above code.
(hailo_env) (base) pi@CM3588:~$ python heftest1.py
File “/home/pi/heftest1.py”, line 63, in
print(infer_results[‘yolov8n/yolov8_nms_postprocess’])
KeyError: ‘yolov8n/yolov8_nms_postprocess’
I’m sharing the HEF file I used in my code.
yolov8n.hef
I’m looking for a good solution and would like to ask for your help.
