'Hailo' object has no attribute 'configured_infer_model'
Hi everyone,
I try to run this object detection with web streaming on flask script :
import cv2
import threading
from picamera2 import Picamera2
from picamera2.devices import Hailo
from flask import Flask, Response
from libcamera import controls
import libcamera
app = Flask(__name__)
output_frame = None
lock = threading.Lock()
def extract_detections(hailo_output, w, h, class_names, threshold=0.1):
    results = []
    for class_id, detections in enumerate(hailo_output):
        for detection in detections:
            score = detection[4]
            if score >= threshold:
                y0, x0, y1, x1 = detection[:4]
                bbox = (int(x0 * w), int(y0 * h), int(x1 * w), int(y1 * h))
                results.append([class_names[class_id], bbox, score])
    return results
def draw_objects(frame, detections, w, h):
    for class_name, bbox, score in detections:
        x0, y0, x1, y1 = bbox
        label = f"{class_name}: {score:.2f}"
        cv2.rectangle(frame, (x0, y0), (x1, y1), (0, 255, 0), 2)
        cv2.putText(frame, label, (x0, y0 - 10), cv2.FONT_HERSHEY_SIMPLEX, 0.5, (0, 255, 0), 2)
    return frame
def detection_thread():
    global output_frame
    with Hailo("yolov10n.hef") as hailo_model:
        print('hailo model : ', hailo_model)
        print("Configured infer model:", getattr(hailo_model, "configured_infer_model", None))
        print("Infer model:", getattr(hailo_model, "infer_model", None))
        model_h, model_w, _ = hailo_model.get_input_shape()
        video_w, video_h = model_w, model_h
        with open("coco.txt", 'r', encoding="utf-8") as f:
            class_names = f.read().splitlines()
    with Picamera2() as picam2:
        main = {'size': (video_w, video_h), 'format': 'XRGB8888'}
        lores = {'size': (model_w, model_h), 'format': 'RGB888'}
        config = picam2.create_preview_configuration(main, lores=lores)
        config["transform"] = libcamera.Transform(vflip=1, hflip=1)
        picam2.configure(config)
        picam2.start()
        while True:
            lores_frame = picam2.capture_array('lores')
            print("Captured frame shape:", lores_frame.shape)
            print("Model input shape:", model_h, model_w)
            results = .run(lores_frame)
            print("Hailo output keys:", results.keys())
            print("Hailo output shape for 'yolov10n/conv19':", results.get('yolov10n/conv19', None))
            detections = extract_detections(results['yolov10n/conv19'], model_w, model_h, class_names, 0.1)
            lores_frame = draw_objects(lores_frame, detections, model_w, model_h)
            with lock:
                output_frame = lores_frame.copy()
def generate_frame():
    global output_frame
    while True:
        with lock:
            if output_frame is None:
                continue
            ret, jpeg = cv2.imencode('.jpg', output_frame)
            frame = jpeg.tobytes()
        yield (b'--frame\r\n'
               b'Content-Type: image/jpeg\r\n\r\n' + frame + b'\r\n\r\n')
@app.route('/video_feed')
def video_feed():
    return Response(generate_frame(), mimetype='multipart/x-mixed-replace; boundary=frame')
if __name__ == "__main__":
    threading.Thread(target=detection_thread, daemon=True).start()
    app.run(host='0.0.0.0', port=2000)
But I get this error : ‘Hailo’ object has no attribute ‘configured_infer_model’
As you can see below
line 59, in detection_thread
    results = hailo_model.run(lores_frame)
  File "/usr/lib/python3/dist-packages/picamera2/devices/hailo/hailo.py", line 167, in run
    future = self.run_async(input_data)
  File "/usr/lib/python3/dist-packages/picamera2/devices/hailo/hailo.py", line 149, in run_async
    bindings = self._create_bindings()
  File "/usr/lib/python3/dist-packages/picamera2/devices/hailo/hailo.py", line 179, in _create_bindings
    return self.configured_infer_model.create_bindings(output_buffers=output_buffers)
AttributeError: 'Hailo' object has no attribute 'configured_infer_model'
Does anyone have an idea of why i get this error please ?
Hey @user82 ,
The 'Hailo' object has no attribute 'configured_infer_model' error typically occurs because of initialization timing issues between Hailo and Picamera2. The Hailo model needs to stay in context while being used with the camera.
Important: Before trying any fixes, ensure you have the latest version of HailoRT installed on your system.
Here’s how to fix the error:
  1. Update your Python packages:
pip install --upgrade picamera2
  1. Modify your detection_thread() function to properly initialize the Hailo model:
    global output_frame
            picam2.start()
            while True:
                with lock:
The key changes:
  • Moved the Picamera2 initialization inside the Hailo context
  • Removed unnecessary print statements
  • Fixed the scope of the hailo_model
Also, make sure your yolov10n.hef file is in the correct directory and is compatible with your Hailo hardware.
Let me know if you still encounter any issues!
